Question about KitchenAid KGSK901SSS Gas Range
When I start the oven, the stove top ignitors spark, but I don't see any spark in the oven.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
In your model, maybe everything sparks when one item is turned on. That might not be a problem.
Two possibilities: The spark board is defective or the gas valve is defective. Each one cost about 150 each. The gas valve is the one that we usually see go first.
Ohms out the gas valve: middle wire to wire on the left; middle wire to wire on the right. If the values are not close or one reading shows 'open' then replace the gas valve.
Posted on Oct 20, 2013
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: stove top burner ignitors will not turn off
This tip I wrote to help people with the problem of the spark not shutting off...the clicking non-stop is a common problem.
Gas Range2_bing.gif Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on May 04, 2010
KevinWhite
  • 1902 Answers
SOURCE: hi, i have a kitchenaid
Hello & Welcome to FixYa
Please check this parts image, you will have to test the oven temperature sensor(part#29) and door latch(part#22) before replacing the electronic control(part#33). You can test the temperature sensor first, if it reads between 1080-1120 ohms then it is fine and the electronic control needs replacement. It cannot be the spark module as the stove top works fine and it cannot be the main board as oven and stove top are fine. Please get back to me if you have any other questions.
Kevin
Posted on May 10, 2011
oldTech2332
  • 2341 Answers
SOURCE: I havef a KitchenAid Gas Range Model KGSS907...
Typically the burner come off by removing the burner caps and inside the burners are 2 screws that hold the burner base to the top..yes you could swap igniters on all burners they will be the same. If by swapping the igniters it still doesnt work the things that could be the problem are;
the spark module espically if the igniter that doesnt work on that burner suddendly work on a different burner
the spark switch on the gas valve for that burner..typically all burners spark when one it turned on but the only one that lights is one that has gas flow to it..so turning on a different burner first and leave it set to light setting by turning on the one that doesnt light it will light if that spark switch is the problem
of course a cracked igniter
a broken wire from the spark module to that igniter taht doesnt work..its not that uncommon that the insulation will sometimes wear off a wire off so the electric that should be going from the spark module to the igniter is instead being grounded by that wire touching the metal on the frame uninsulated
Good luck,i hope i have been able to help you fix your range,
GENE
Posted on Aug 27, 2011
Need a manual for Simpson Ezi Set Upright GAS Oven/Stove. Think the Model No. is 62F851W. The stove top has 4 burners. There is a griller in the oven. The griller and oven have piezo(?) ignition. ...
Thank you I have contacted simpson directly to obtain your manual from the manufacturer I will look for there response tommorow and message you my contact mail information when it is sent from them. And if you have to use a match on top to light the burners you would first assure that you have spark if you have no spark then you would look at the spark modulator which is what most stoves use to send the current to the electrodes to create the spark. If you did have spark you would then need to check each electrode or ignitor to assure that they were not cracked and they were functioning properly. If you have any questions message me back or I will be posting as soon as simpson responds to my contact of them.
Thank you
Rick
Dec 07, 2011 | Refrigerators
Hoping someone can point me in the right direction. Oven won't light, but the stove top burners are fine. Don't smell any gas or any indication the oven is attempting to light....
next time send the brand name and model number so i can look up your machine,if it's a gas stove most likely it will be a bad ignitor,even if the ignitor glows it still could be bad,if the flame doesn't ignite and the ignitor is glowing change it out,if it isn't glowing pull out the ignitor and check it with a meter,common problem.
May 07, 2011 | Ovens
We are cranking up this BRAND NEW Vulcan flat top. Weh have the convection oven below up and running, but we can't even see a pilot light for the flat top. Advice anyone? Culinary-yours Chef Geir
older ovens have pilots but the newer machines are electronic ignition,there are ignitors in the oven and electrodes or ignitors on the top burners,when you turn the knob for the burner you should hear a clicking sound and see a spark around the burner,that's what lites the burner,the gas comes in and the spark ignites it,i don't know much about your machine but it can't be any different from other stoves.if none are sparking there should be a spark module in there or they could have separate modules,if you send the full model number i can look it up for you
Oct 30, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
Oven quit working . Stove top burners work just
if its an electric start. then the problem is usually the ignitor for oven. if you change this yourself, be carefull they are very fragil. hold on to igniter by its base. slide ignitor into steel case then install. and hook up the 2 wires for ignitor.
May 14, 2010 | Ovens
Stove top burners won't light.
Susan, there is no pilot flame on the Spectra models of ranges. However, the possibility that the electronic ignitors have gotten soaked and are shorting out is quite likely.
You should disconnect the power to the oven and remove the burner grates, burner caps, and the burner assembly cores to expose the ignitor posts. Check to see if there is any remaining water there and clean off and dry the ignitors and burners completely, as they might have something on them causing them to short out against the stove top, rather than spark properly, as they should.
Once you've cleaned and replaced the stove top parts, restore power and try to light each burner, one at a time. If none of them spark or light, then you need to check to make sure you haven't tripped a breaker for the stove or a GFCI outlet that the outlet that the stove might be plugged into, somewhere in the Kitchen.
Hope you find this Very Helpful and best regards!
Sep 10, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool counter top gas stove electronic ignitor sparks all the time,had to unplug to make it stop
The spark ignitor has failed. Have it replaced and that should stop all the extra clicking. Hope this helps. Good luck.
Aug 27, 2009 | Whirlpool Ovens
Oven does not light.
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working. If the ignitor did not appear to function and it is the spark type, it may be out of adjustment which generally requires professional service or it may require replacement. If the ignitor is the glow type, you can test it for resistance with a multimeter.
The ignitor has two wires connected to it.Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading anywhere between 50 and 600 ohms. If you get a reading of zero or infinity, the ignitor is definitely bad and will need to be replaced.
Jul 25, 2009 | GE JGRP17 Gas Single Oven
Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Magic chef oven does not work
Stove top works but oven does not light. This is an electric spark ignition unit.
Sep 07, 2008 | Ovens
KitchenAid KGSK901SSS Gas Range Logo
81 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
