Question about Refrigerators
Amana side by side, SXD27q2w, Ice maker tube, located in the freezer keeps freezing. I have 45psi on the water. I think it may be the solenoid, It is almost like it is letting water pass very slowly a drop at a time, and they are not leaving the trough fill tube, they freeze keep building ice in the tube and freeze solid. I have replaced hoses, new fittings, I am lost. Could the solenoid be letting water pass at a rate that would cause this. I just got an idea gonna try it, but if anyone can help. thank you.
    Sergeant:
  • 304 Answers
Solenoid has rubber valves that can sometimes leak water valve needs to be replaced
Posted on Oct 19, 2013
  • 2 more comments
  • dale osborne
    dale osborne Oct 19, 2013
    thank you, I disconnected the line and let it hang into a bucket, slow drip. so I took the valve apart and the seals were worn. now to find them. thank you.
  • Day Coker Oct 19, 2013
    You would be better of replacing the whole assembly go to repairclinic.com use your model number to find the water inlet valve
  • dale osborne
    dale osborne Oct 20, 2013
    I found the valve at amazon and ebay, 32 and change, I was kicking your idea around, haven't been able to find all of the washers and seals, and don't like spending a bunch of time on it. so i am gonna get a new one. thank you.
  • Day Coker Oct 20, 2013
    Glad I could help!
4 Suggested Answers
SOURCE: amana side by side ice dispenser leaking water
icemaker wont dump ice
Posted on Jun 19, 2008
mikedurland
  • 481 Answers
SOURCE: ice maker tube freezing up
  • change the water valve on the back of the machine.
  •  the water valve is slowly leaking water up to the icemaker where it freezes and builds up ice, blocking the water flow.
Posted on Jul 05, 2008
  • 351 Answers
SOURCE: Water supply tube keeps freezing off water supply.
its hard to tell but most likely the valve is not closing all the way. but it could be the ice maker calling for too much.... www.whirlpoolpartssurplus.com
Posted on Jun 23, 2009
I have an Amana SD125F-L refrig-freezer. The rubber tube which carries water from inside the freezer wall to the ice maker tray frequently freezes solid with ice. After thawing with a hair dryer, it...
Hi Jan, the problem is a bad ice maker water valve. Pull the refrigerator out and look for the plastic water line that's going to the tube that's freezing. Follow that tube to the faulty water valve. The problem is, its leaking water slowly to the ice maker and it freezes up . Easy fix : Good luck
Appliance Repair Tucson, AZ
Refrigerator Repair service 520-888-7039
Aug 15, 2013 | Amana Refrigerators
GE TFH27PRSA ice maker water fill tube and receving bucket on ice maker keeps freezing closed. No other problem with unit including water despenser to door. Once the tube freezes closed, water is leaking...
all is normal with the defrost heater getting red hot.
as far as the inlet tube freezing, you most likely need a new water inlet valve. it may not be closing all the way and water is slowly dripping into the icemaker and freezing up right away. a new valve should fix your issue. here is the part that you need. http://www.repairclinic.com/SSPartDetail.aspx?s=t-TFH27PRSA-%3d%3di1032629&PartID=1032629
Aug 21, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water icing in ice maker tubing
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
Aug 12, 2009 | Amana ASD2526VES Stainless Steel Side by...
Ice maker is freezing up
The solenoid valve can leak slightly to make your problem. To check it, undo the tube from the solenoid to the freezer with the solenoid unplugged, and the water pressure on. Any leakage is bad, replace it.
Sep 04, 2008 | Whirlpool GD5SHAX Side by Side...
Ice maker
ON YOUR MODEL YOUR HAVE A MULTI-COIL WATER INLET VAVLE WHICH CAN BE ORDERED AT WWW.REPAIRCLINIC.COM OR FROM FOX APPLIANCE PARTS IN ATLANTA, GA
Nov 04, 2007 | Amana Easy Reach AFD2535DE Bottom Freezer...
Automatic ice maker doesn't fill with water
Probably the double water inlet solenoid valve on the back of the cabinet (one for the water and one for the ice, one component). Or a blockage in the water supply line, and even on one occassion the pipe feeding the ice machine was not in situ and water runs down the back of the freezer. Easiest way to check is to locate this part (back RHS) and switch the ice and water over and see if this has an impact. If you are not a practical person do not touch the back section (compressor side). Hope this helps.
May 26, 2007 | Amana ARSE665BS Side by Side Refrigerator
Ice maker freezing up
If it is only the fill tube that is freezing up, or getting full of ice, than your water valve is leaking (letting drops of water thru to your ice maker and filling the icemaker fill tube up and freezing). If this is the case, replace the dual water valve (part # 1071263) located in the back of the refrigerator, just follow the water line from your wall into the refrigerator. Make sure you turn off the water to the refrigerator and also unplug it. The dual water valve is the one that has two water lines, one going to the icemaker and one going to the water dispenser. On this model, I think you only have one water valve. On some you have two, the primary water valve and a secondary water valve (the dual valve). If this is your case, I would highly recommend you replace both. As far as the Refrigerator side freezing things up, I think that is a whole different issue. Please post back.
Oct 16, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
67 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
