Question about John Deere Garden
How do I replace an entire tie rod assembly outer on a John Deere 4600 Diesel Tractor
  • John Deere Master
  • 2,478 Answers
Remove nuts and cutter pins from tie rods.
Posted on Oct 21, 2013
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
wireguy212
  • 1627 Answers
SOURCE: ELECTRICAL PROBLEM
Can't get you a diagram but i can tell you most electical problems on these tractors can be solved by replaceing the key switch/modual or cleaning corrosion from fuse holders.
Posted on Nov 10, 2009
How do I fix john deere 620I gator steering assembly
then why do you not look for the bent rod and unbend it or replace it .
May 26, 2016 | John Deere 2010 Gator XUV 4x4 620i
Replace a fanbelt on john deere 4020 diesel tractor
Most older models had the adjustment on the alternator. loosen it and push it toward the engine. remove & replace the belt. Pull the alternator away from the engine until the pulley cannot be turned by hand due to the tension. Tighten the adjustment bolt to secure it. Don't overtighten the belt.
Sep 22, 2014 | John Deere 4020 Gas & Diesel Tractor...
HOW DO I ALIGN THE FRONT WEELS ON A D130
loosen up tie rod unhook tie rod from spindele turn tie rod in hook tie up to spindle see if straight if not repeat till straight make sure tie rod end is not bad replace if is make sure spindle not bent replace if it is
Sep 04, 2014 | John Deere D130 22HP V-Twin Foot Pedal...
The rod on my John Deere tractor fell off that makes it steer...how do I fix it ?
sounds like the ball joint on the steering link is worn and dropped out some models have replaceable ball joints and some you must replace the entire steering rod in either case check all ball joints for wear and replace as they are worn as well
Oct 25, 2012 | John Deere Garden
Remove spindle john deere 3020 tractor
Remove bolts or clamp on top of spindle. Next remove steering tie
rod. It should slide out.
Sep 26, 2012 | John Deere 3020 Gas & Diesel Tractor...
What would cause my John Deere Sabre 25hp 54"cut to be hard to steer ?
Your tractor has a simple worm gear turning another worm gear system.Either the one of the spindles in the front wheels is sticking or the worm gear is not meshing or you need to replace the worm gear on the steering shaft it's self.Also,if the tie rods are not set right then the wheels may turn hard,set the tie rods so that they have 1 to 1 and 3/4 inches of tow in in the front wheels.
Sep 12, 2010 | John Deere 420,1020,2010,2020,2510,2520...
L120 JOHN DEERE
There should be adjustments on the tie rod ends connecting to the front axles. Loosen set bolt, make the adjustment and re-tighten set bold.
May 27, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Jul 04, 2009 | John Deere 3010,3020 Tractor Basic...
Garden Logo
96 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
