Question about Kenmore Elite HE4 Electric Dryer
Elecrical burning smell with gas dryer. Otherwise working fine.
  • Bill Sheridan
    Bill Sheridan Oct 20, 2013
    Excelllent suggestion Jim! Appreciate the thoroughness and additional good ideas.
    Novelist:
    Scholar:
  • 100 Answers
Unplug your dryer and turn off the gas. Open up the back of the machine, and if you can do this at night or if your in a low light room, turn the lights off, (you should be in dark now) (have a working flashlight in your hand). Once the back is off the unit, and you have positioned everything so your not tripping over components of the dryer, you got your flashlight in hand, plug in the dryer again, hit the start button (do not turn on gas) and let the unit run for a little while, (no lights, do not turn on flash light now) while your watching any wires or components near wires, that might start to glow RED. If you see no glowing,, then then turn your flashlight on and search the interior of the whole machine for blackening componets, from a electrical short or from possible flame or pressurized heat being blown from the unit through a cracked cover or tubing. Also check the unit for any discolored wires.
Once you have discovered the source of the heat in relationship to the wires, replace the wire, replace the defective tubing or if the wires are just leaning, touching, a hot surface, then bend the wires so that they are safely away from the heat source. Try and figure out why the wires got close to the heat source. Sometimes Cats, or Rodents like to hide in the back of dryers and they gnaw on wires and push them around while they are making a nest or place to sleep. Simply use common sense, do not discount anything, and expect anything. Good luck... Oh yes, since you have the dryer out, take your ducting hose and clean it thoroughly. Fires in the home are a main source in dryers due to lint not being completely blown out of the unit and safely away from the heat source.
kindly,
Jim
Posted on Oct 20, 2013
SOURCE: smells like somethings burning, more
did the drum stop turning,when motors overheat they smell realy bad.
Posted on Nov 01, 2008
aborcass
  • 2651 Answers
SOURCE: Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Posted on Nov 16, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: I have a Kenmore Series 90 gas dryer. Works fine.
The only source of a gas leak from inside the dryer itself is the gas valve. They can sometimes leak a little gas when you first turn the gas on after hooking it up. If your gas pressure is normal (and I'm guessing the plumber checked it) and your other gas appliances are working properly, the dryer gas valve is faulty and should be checked by a qualified appliance servicer.
Posted on Apr 15, 2009
vickygomar
  • 460 Answers
SOURCE: There is a gas smell by my washing machine and dryer.
Ceck the follow instruction just to veryfy what kind of problems your dryer has. You dont have to buy anything just check all the information that is given to you
http://www.youtube.com/watch?v=rQV-z4f7fvA
Your ratting is very important to me
Was this helful?
Posted on May 22, 2009
heatman101
  • 43501 Answers
SOURCE: burning chemical smell coming from the gas dryer
You first thought was probably the correct one...the fumes from the new paint may take a few days to disspate enough not to react with the heat of the dryer...I would give it a few dyas to clear before looking any further...
heatman101
Posted on May 28, 2010
My frig. agq600fs gas dryer drum will not turn.
Good bet it's the motor!
Disconnect electric plug.
Have to get access to back of the dryer, remove a few screws.
Look at motor and belt, motors sometimes over heat - Burn Up.
Motor could be replaced, depending on the age and how long you have had it!
Nov 29, 2013 | Frigidaire AGQ6000ES Gas Dryer
Kenmore whirlpool dryer won't start and has a bad burning smell
You may have an overheat sensor that is burning up. The dryer won't start because the heat would be uncontrollably high otherwise
Jan 29, 2013 | GE Profile DPSF495EW Dryer
LGR7647 will dry fine but smells like gass only when it runs.
make sure the air shutter on the gas nozzle isnt completely blocked or changed positions as the flame needs oxygen to make combustion complete otherwise the gas wont burn completely and you will get a black smoke that smells like raw gas
Dec 06, 2012 | Dryers
DRYER DRUM SPINS BUT LOUD BANGING NOISE AND ELECRICAL BURNING SMELL. UNIT ABOUT 15 YRS OLD
drum rollers/glides may be the idler arm, if is located next to the motor:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Feb 23, 2011 | Kenmore 63942 Dryer
We purchased this product a month ago and it seems to be giving off a burning type of smell which we can smell both outside the vent and in the dryer itself. it seems to work fine
If it smells like an oily burn then it is just the oil burning off of the new parts in dryer, this is common. If it smells like electrical burning then call the manufacturer for repair. Could be a wire burning and if it is new it is covered under warranty.
Jun 14, 2010 | Whirlpool WED5800S Electric Dryer
I hooked up wires as described. I smell elecrical
If the dryer has been sitting for a while, that may just be dust or lint that has gotten stirred up inside the dryer and ended up on the heating element. This is normal and it will go away. This often occurs after the dryer has been moved or cleaned.
However, just in case, you may want to review your power cord installation one more time. The following link explains:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Verify your installation paying particular attention to how to you have terminated the Ground and Neutral wires. Make sure the terminals are tight and not loose. Loose connections can cause arcing and excessive current which results in burned wiring or melted insulation. If it is correct, make sure you don't have any heavy accumulations of dust or lint inside the dryer cabinet. If the odor does not go away within a day, stop using the appliance and let me know. I hope this helps you.
Dec 05, 2009 | Estate EED4300SQ Dryer
Gas dryer drum will not spin
the flint element might need to be replace...(pilot light) I had the same problem the dry had a burned smell...which meant that the element wasn't working properly and finally the drying wound't heat anymore
Jan 01, 2009 | Kenmore 98702 Stacked Washer/Dryer
Gas dryer with gas smell and no heat
It sounds like your GLOW BAR gas igniter is bad. This is an electric powered heater coil that , when it glows red hot, ignites the gas burner. This part normally fails at least once during a dryers normal service life. If you are handy, you may be able to replace the part yourself. Otherwise, have a technician look at it. If you want to DIY, go to an appliance parts store . Remove and observe the GLOW BAR from your gas dryer. If one of the metal element appears to be burned open,replacement is necessary.. Show the part, along with your dryer maker, model, and serial number, to the store employee. This person can give you helpful info along with a new part. If the GLOW BAR is NOT burned out, seek out a technician.
Aug 29, 2008 | Bosch Nexxt WTMC3521UC Gas Dryer
Kenmore Elite HE4 Electric Dryer Logo
81 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
