Question about Hunter Ceiling Fan Control Switch
How do I change the lightbulb in the HC-1131 ceiling fan... the globe will not come off and the whole shaft turns if I try to lift and turn the only part that looks like it comes off
    Scholar:
  • 64 Answers
I appologize in advance for not having absolute, 100% certainty if this will work with your particular model of fan, but it appears that most fans of that style have a threaded globe glass covering. The difficulty most people encounter, is that if the globe is even mildly warm from the fan motor running, it will be near-impossible to grip, much less to turn.
In all related cases I had read about, the solution was to allow about 12 to 24 hours of power to the fan being completely off to allow it to cool, then try turning the globe to unscrew it. Most suggest "clockwise" but I have no way of knowing if they mean clockwise from the perspective of looking up at the globe, or clockwise relative to the fixture itself.
Some also suggest that rubber gloves to improve grip or friction may also help to turn the globe.
Posted on Oct 19, 2013
Richie_asg1
  • 1036 Answers
SOURCE: hunter ceiling fan
Motors work with magnets. These may be permanent, or more commonly elecromagnets. These are the rotor, and the field magnets. Another type of motor just uses a field magnet and iduces flux in the rotor.
Either way, it sounds like one of the main coil windings has either burnt out or mechanically broken.
If you want to remove it and test the coils with a meter (check resistance of each) this should show the fault.
If a coils burn't out. it's scrap .
Posted on Jun 11, 2008
  • 75 Answers
SOURCE: help me fixe my ceiling fans
Start over again!
Make sure that the HANGER BRACKET is properly and securely attached to the ceiling joists.
Then make sure that the HANGER BALL of the fixture is properly seated in the HANGER BRACKET.
Make sure the SUPPORT PIN is properly seated in the grooves in the top of the hanger ball.
Make sure that ALL the BLADES are firmly SECURED with TIGHT screws both at the BLADE ARMS AND at the MOTOR.
Remove the BALANCING WEIGHTS from the blades.
Make sure that the DOWN-ROD is indeed VERTICAL and not BINDING.
Turn on the fan in the SLOW mode and let it operate for a few minutes. Is the "shake and noise" issue still present? If NOT, turn it to 'medium speed and if still no problem turn it to high speed.
However, If the problem is STILL present, turn the fan OFF. Look closely and carefully at the LEVEL of the blades. You should be able to determine if one or more of the blades appears to be out of level. Use the minimum amount of balancing weight on the blades, and not every blade may need a weight. You do not want to contribute to the problem here.
If, after you have gone through all of the steps suggested here, the problem persists, then you have done about all you can do as a consumer to make this fan operate satisfactorily.
DOCUMENT the actions you have taken in an effort to remedy the issue on your own.
At this point load it up and return it to the place you purchased it for replacement or refund.
Good luck. :)
Posted on Apr 26, 2009
SOURCE: I have a Hunter Fan purchased in 2003. It has the
Called Tech Support
Posted on Oct 08, 2009
matt2414
  • 247 Answers
SOURCE: The lightbulb in our ceiling fan fixture blew.
check the wiring connections to 2 light fixtures,sounds like a short between these 2,but I would check each individual lamp.
Posted on Mar 23, 2010
mcdevito75
  • 1970 Answers
SOURCE: lights flicker on and off. Fan works fine
mcdevito75 here, If the wireing in your home / apartment is old and especially if you have an A/C unit or refrigerator on the same circuit as the celing fan lights may flicker with these other appliances going on. --------------- You can also check the wall switch that turns the fan lights on.
Posted on Jul 21, 2010
How do I replace the light bulb on ceiling fan for Airworks. Can't twist it off!!!
Try putting on rubber gloves and turn the globe clockwise. The globe has a very smooth surface and is impossible to turn with bare hands because you cant get a grip on it.
You can read the whole forum below:
Replacing Ceiling Fan light bulb PhD required
Nov 16, 2016 | Dryers
I am unable to remove the glass globe on the fan to replace a burned-out light. Do you turn to right or left to remove. Is there a trick to it?
is this a ceiling fan perhaps if so there are 4 little screws that hold gloobe up try lifting the globe some while you loosen screws
Mar 08, 2015 | Dryers
How to remove the glass globe to change the lightbulbs on a Hunter Breeze L05BN ceiling fan?
there are probalby small screws usually 4 around the globe that hold it in unscrew them slowly and carefully as easy to lose /drop
Jan 24, 2015 | Hunter Dryers
How to replace a ceiling hc 1131 wiring harness
Hampton Bay is a low-end fan for Home Depot only. GOOD LUCK!
Aug 17, 2014 | Hampton Bay 24002 Ceiling Fan
I have a HC-1131 fan that will no work. No brand name lable but believe it to be a Concorde. Any suggestions for repair?
First we need to know what make/model of fan you have. Second, what's the problem? Does it have a remote?
Oct 04, 2013 | Hunter Ceiling Fan Control Switch
Replaceing bulb on ceiling fan
Turn off the fan before you climbing the ladder to remove the dead bulbs
  • Note whether a screw secures the shade or if the lightbulb holds the shade in place.Unscrew the lightbulb counterclockwise. If the bulb is securing the shade, grasp the shade with one hand while removing the bulb.Install the new lightbulb by turning clockwise into the socket. If the bulb holds the shade in place, keep the shade in position with one had while screwing in the bulb with the other.
  • ceiling light
  • May 15, 2012 | Hampton Bay 24002 Ceiling Fan
    How do you change the lightbulb on the turbo ceilng fan. can't see how the globe comes off
    there are usually screws that are around the top of the globe or you have to twist the globe gently.
    Dec 31, 2010 | Westinghouse Turbo Swirl 78145 Ceiling Fan
    Broken Ceiling fan Globe
    This is not the best idea, but you could buy another one and change the broken globe with the new one. Then take it back fo a refund.
    Nov 24, 2017 | Hampton Bay Dryers
    How do I change the light bulb
    I think that the plastic round will pop out of the center--held in by tabs?
    Mar 02, 2009 | Broan-NuTone QT100L Fan
    Need to change glass globe in hampton bay fan
    I had the exact same problem. To solve it, I had a friend hold the area of the fan that the globe screws into. I wore rubber dish gloves to get a good grip and pushed up slightly on the globe as I turned counter-clockwise. My friend held the other part and turned clockwise a little as well. It took a lot of pressure for it to finally come loose and then we just turned it about another 90 degrees and the globe slips right out of the groove.
    I couldn't believe how hard this was to do.
    Jan 23, 2009 | Hampton Bay 24002 Ceiling Fan
    Dryers Logo
    381 people viewed this question
    Top Hunter Dryers Experts
    Paul Bade
    Thomas Perkins
    Thomas Perkins
    Are you a Hunter Dryer Expert? Answer questions, earn points and help others
