Question about JVC HD-56G786 56" Rear Projection HDTV
I can turn the tv but there is no picture or sound, but i can get picture from dvd and no sound
I'm hooking up an APEX Digital TV and when playing a DVD, the picture is fine, but there is no sound. When on TV mode, sound is fine. Suggestions on how to fix this?
  • Turn everything off. Turn on TV and Select dvd input (Source). Wait 10 or so seconds. Turn on DVD player. Works for me with similar problem. Good luck -
  • John
Jan 17, 2016 | Apex Digital Televison & Video
My bauhn TV screen stopped working. DVD plays sound but no picture. Can the TV be reset or rebooted
You can try unplugging the units--no picture often means the DVD has a dirty or failed optical unit.
Aug 30, 2012 | Televison & Video
I can't get a picture on tv when turn on dvd player why? brand new, never used before.
have you connected the DVD into the right plugs, also are you using the correct AV channel on the TV?
RED WHITE YELLOW yellow is video red is L sound White is r sound. check both TV input and DVD output
Aug 14, 2009 | RCA DRC8335
I have a 32" TV/DVD combo westinghouse LCD TV. When I turn the TV on I get no picture. There is sound. DVD player does not show picture either, I have sound but no picture.
This is a backlight or inverter Problem. Based on the model you have, I am guessing the inverter is defective.
Inverter is defined as the board in the TV that supplies power for the flourescent lights inside the LCD TV that provide backlighting for the TV's Display
Jun 22, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
TV has sound, but no Picture
Does your sound go thru the tv or a sound system ??? when ya turn tv off then on does it show anything like its coming on ??
Nov 16, 2008 | Curtis-Mathis CM19011 TV
No picture yes sound
I was told that this problem could be the power board.
Jun 17, 2008 | Televison & Video
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
No picture while playing DVD or VHS tape
Your unit has it seems to have developed a video problem. it could be in the video switching IC or the video processor. Its going to need a trained technician, who knows how to use an ocilliscope to find the video problem.. Good Luck
Aug 02, 2006 | Insignia IS-DVD1001 DVD Recorder/VCR
JVC HD-56G786 56" Rear Projection HDTV Logo
22 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
