Question about Aiwa CA-DW635 Boombox
Unit will not turn on with either AC or batteries. Where is the fuse located at?
  • 2,113 Answers
It is not a fuse but a burned diode
Posted on Oct 22, 2013
Dear all expert's and learner's my problem is with
check to see if it's under warranty first, some have lifetime, Look for reset button or hole, Did you buy brand new batteries of use some older ones?
Does your AC turn on at all? If not could be your AC unit, some t'stats are wired to get there power from the AC unit also and have batteries as a back up for the clock and memory. If the AC unit went out then it will not power the t-Stat. check your breaker and fuses.
Sep 23, 2014 | Hardware & Accessories
LG ac remote is not working, batteries have been replaced
Probably the fuse to the indoor unit must replace it. It's on the pcboard and it's from glass. Turn of the power and replace it.
Dec 31, 2013 | Heating & Cooling
Older Toshiba laptop runs on battery, but not AC cord.
on some older laptops the battery has to be installed for it to turn on.
if the battery don't hold a charge it's no good.. but you need it to get power from plug.
Jan 04, 2013 | Toshiba Computers & Internet
Air conditioner comes on comes out hot
the belt driven aircondisioning unit is located under the hood. there are usualy metal lines coming off of it and one should have a valve in it ...looks like a tire,air valve. when car is running, turn the AC on. the unit has a two part clutch that the belt will turn. when the AC is off...the pump or compressor will engage and the hole belt driven piece will rotate when the AC button is on. , when it is off....or not getting power to the clutch , the pully will spinn but the inside clutch will not.
iff the unit engages and turns when the AC is turned on, and still blows hot air, then you may have a leak in your refrigerant line. iff it dosnt engage, then check your fuses .if everything is good to go..then it is mostlikly a vacume issue located in the dash behind the AC switch and display that moves the vent from hot to cold....
Jun 08, 2012 | 2003 Chrysler Town & Country
Unit beeps when turned on for a couple of seconds then shuts down
If the AC green LED on the front panel does not light when plugged in the AC input Fuse may be blown. In the bottom of the AC Supply socket is a fuse that can be pulled out and replaced. There is a spare fuse in the square of the rectangular fuse holder
Jul 11, 2010 | Computers & Internet
2004 suzuki aerio a/c unit not responding cant find out the fuse location for it,checked unit is charged no leaks
Check the A/C relay under the hood near the battery. Had the same problem on my 2004 Aerio. Around $30 at the dealer.
Jul 19, 2009 | 2003 Suzuki Aerio
Television suddenly turned off and won't turn back on.
ur AC fuse might be burn out or SMPS (power supply unit) might be damage. to check the first case, open the cabinet and locate for the fuse following the AC cable. if it burns out change it else take it to a authorized service man.
May 03, 2009 | Toshiba 36A43 36" TV
Fellowes 425AP wont power up
When moving UPS batteries you need to unplug them from the unit internally to keep them from discharging completely. If the battery is beyond 2 y/o it is probably shot.
I would NOT replace the battery however in a "possibly-bad" unit. The cost of purchasing an entirely new unit (locally, without shipping cost) is just too inexpensive.
Jan 31, 2009 | Fellowes 99052 UPS 425VA Battery Backup...
Aiwa CA-DW635 Boombox Logo
66 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
