Question about Samsung Digimax S630 Digital Camera
Removing protected pictures
I have a samsung s630 digital camera and there are a few protected pictures that i would like to delete and i can not figure out how to do it.
  • mark deegan Sep 26, 2008
    Duh!
    How Do You Unprotect Them?
Uhh.. you unprotect them then you delete it?
Posted on Oct 30, 2007
How to take and delete pictures?
Digimax is just a trade name formed from "digital" and "maximum."
You may download a copy of the manual from Samsung Digimax S630 Digital Camera User Manuals Guides
Sep 15, 2016 | Samsung Digimax S630 Digital Camera
After I import pictures from my Samsung S630 camera on the computer how do I get them off the memory card
You may delete them one by one on the Camera: Go to "view" and delete
Or You may delete them all by browsing to the menu > Format memory card.
Mar 16, 2011 | Samsung Digimax S630 Digital Camera
How do I unlock protected pictures?
You have to unprotect it first. It's a bit confusing because the menu item probably only says "Protect..." but it also takes care of unprotecting too. Go into the menu for "Protect..." and navigate to the protected one. Whatever button you press to switch the protected status (it's the SET button on my Canon) you can use it to turn the protection off as well. When you exit the protection mode, you can delete it.
Update! I just tried this on a Samsung S630 - hopefully the process will be similar for you (the camera certainly looks the same). You have to be in playback mode. Press the menu button, and go to Playback. Move to 'Protect' and select that mode. You can navigate through the pictures, and on mine, T(elephoto) locks it, and W(ide) unlocks it. In any case, the on-screen instructions should tell you what key it is.
If this doesn't work for you, don't mark it unhelpful (yet) but say so, and I'll find a user manual for your exact model.
Jan 31, 2011 | Samsung S85 Digital Camera
I have the samsung s630 and i have taken some pictures on it before i got a memory card. i want to save them to my memory card, but when i insert the memory card those photos wont show up. how do i get...
If you remove the card from the camera and connect the camera to your computer with the USB lead, you should see the camera's internal memory as a disk drive on the computer. If there is a memory card inserted, you will see that memory instead.
Unlocking individual pictures is done with the same function that locked them. It is probably on a menu available when you are viewing the pictures on the camera.
Oct 20, 2010 | Samsung S630 Digital Camera
Retrieving deleted picture on samsung s630 camera
First do not panic! It is possible to recover your pictures if you take care. Take the card from the camera (powered off) and if it has a "write protect" tab then lock it now. Do not try and write anything to the card or you risk causing more problems.
You can either plug in you camera to the PC as it should appear as a “Removable Drive” or put the card in a card reader attached to your PC.
Next, if you are comfortable with using a PC then you can download a FREE utility that will recover your photos from the following link:
http://www.cgsecurity.org/wiki/PhotoRec
If you need something a little more "user friendly" then you will need to buy the software. If you search the web for photo recovery software you will find many.
One I have used successfully is RescuePro that used to be bundled with some Sandisk products. Now you can get it from the link below:
http://www.lc-tech.com/software/prwindetail.html
You can try the demo to see what you can recover before buying.
Remember - Do NOT try & write anything back to the card until you can recover your pictures to your PC safely!
Please take a moment to rate this solution & let us know if the information given was useful to you – Good Luck!
Informatica
Sep 02, 2008 | Samsung Digimax S630 Digital Camera
My camera is taking fuzzy pictures...
on the ting that spins go to program then hit the delete then go down to the sixth one and then to the 3rd one witch is coudy that how mine got fix
Jul 25, 2008 | Samsung S630 Digital Camera
S630 digital
Switched to Picassa instead of Wizard and for some reason it downloaded photos and videos. So I obviously had the wrong program to download from the camera.
Jul 08, 2008 | Samsung S630 Digital Camera
HOW DO I DELETE PICTURES?
To DELETE ALL the pictures:
- Press on the PLAY mode button (to view pictures)
- Press MENU
- Keep on scrolling until you see PLAYBACK menu tab
- Scroll down to DELETE option
- Use arrow keys to select ALL
- Press MENU/OK to confirm
Hope this helps.
Dec 15, 2007 | Samsung Digimax S630 Digital Camera
Protected pictures
you have to unprotect them first... sometimes if you juts format the card (insert into your PC) this will delete protected files as well..
Sep 27, 2007 | Samsung Digimax S630 Digital Camera
Samsung Digimax S630 Digital Camera Logo
69 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
