Question about Vehicle Parts & Accessories
HOW CAN I ATTACH A TOILET (WC PAN) ONTO A MOBILE HOME FLOOR
    New Friend:
    Problem Solver:
  • 9 Answers
Very carefully
Posted on Oct 20, 2013
How does the cistern fit onto the toilet and connect to the water outlet. Does it got onto the toilet seat if so how do you connect the water supply?
normally the cistern is mounted to the wall and the pipe to the bowl (pan) is just connected by a rubber grommet at the pan inlet and a threaded nut that compresses a rubber ring in the cistern end
water supply is via a hose from the isolator tap next to the an up to the pipe under the cistern
Aug 26, 2017 | Home
There is a leak at the FOOT of my valsir toilet onto the floor what do I do ?
You are going to have to do some investigations...
It could be any of these..
#1 Pan to waste pipe connection
#2 Water flush to pan connection
#3 Cistern to water flush connection
#4 Cold water connection
#5 Cistern overflowing
#6 Condensation
If the cold water valve/washer is faulty then the constant flow of cold water is going to create a lot of condensation.
If the leak only appears after you have flushed the toilet then it is likely to be #1, #2 or #3
Just a matter of elimination..
Apr 22, 2017 | Home
How to replace flush system of johnson suisse wc
Our Jonson Swisse toilet is leaking into the pan, Replaced the flapper seal, cleaned all components, and overflow is not leaking.
Have run out of ideas.
Can you assist?
Regards
Ivan
Feb 26, 2014 | Home
Mobil home duct work , A-frame leaking into duct work and onto electrical parts below the fan and also into the belley of the mobile home.
It's either freezing up due to indoor fan not running or running fast enough,dirty coil or filter,or low on refrigerant. It could also be a clogged up drain or cracked or rusted drain pan.
Jun 05, 2013 | Heating & Cooling
We have installed an american standard duel flush toilet that uses a fluidmaster valve. Problem! The refill tube is mounted on a float attached to the overflow pipe. When the toilet is flushed the nozzle...
The overflow pipe should be attached to a small clip that holds it in position over the over flow pipe. If it is loose or attached to the outside it will do what yours is doing.
Apr 28, 2017 | American Standard 2480.516 FloWise Dual...
The little hose that attaches to and pours water into the long vertical tube (to fill the tank) has slipped off twice and sends water over the side of the tank and floods my bathroom floor. The little...
to get a new one would require a new fill valve for your toilet, or a local plumber might have one rolling around on his truck.
try a paper clip, one thats a little bigger than the tube. slide it onto the tube, then clip it onto the fill tube like you would a piece of paper, this works in most cases.
Aug 17, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
Toilet on uneven floor
I believe that I qualify... over 300 toilets installed in the past 15 months!!
I would go with the wax rings... but I would press the ring into the base of the toilet before installing the toilet....that way you are sure to have a good seal to the toilet....
If you actually read the directions, the manufacturer will tell you to press the wax ring onto the toilet....then install it onto the floor drain.
I guess that a PLAIN wax ring placed on the floor drain (since it is recessed) before placing the rubber-sleeve equipped ringed toiled is a good safety measure... I have done that an it work about 37 times out of 40.
Good question - BTW.. and well worded. THANKS for being specific and precise!!
Dec 31, 2009 | Jacuzzi BK37959 White Era?? Two-Piece...
Vehicle Parts & Accessories Logo
44 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
