Question about Garden
Exmark mower I have an exmark walk behind with the 0 degree turning system and it powers down when i turn right, how do i fix it?
  • Justin
    Justin Oct 19, 2013
    Already cleaned the carb four times.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
You mean it dies or the engine slows down ???
Posted on Oct 20, 2013
Testimonial: "When i turn right, with the brake or if i physically turn it without the brake, it throttles down just like it would if i were to put it at half throttle. It's such an odd issue. I can usually fix engine problems with ease..."
  • 11 more comments
  • Justin
    Justin Oct 21, 2013
    It's beyond me...
  • Behind_Blue_Eyes
    Behind_Blue_Eyes Oct 22, 2013
    disconnect the throttle cable from the engine and get back to me... oh and what engine do you have ??? I
  • Behind_Blue_Eyes
    what I mean is disconnect the throttle cable and test the unit at full throttle. this means you have to manually apply the throttle
  • Behind_Blue_Eyes
    does it only do it with the pto engaged ???
  • Justin
    Justin Oct 22, 2013
    Only does it when blades are engaged.
  • Justin
    Justin Oct 22, 2013
    Will find engine model and test at full throttle later today, full throttle works fine, its a great machine, already cleaned the carb four times. it just throttles down when i turn right when blades are engaged
  • Justin
    Justin Oct 22, 2013
    It's really weird
  • Justin
    Justin Oct 23, 2013
    Worked the throttle manually, if i were to tape it so the throttle was all the way open it would fine.
  • Justin
    Justin Oct 23, 2013
    I took the air filter housing off and watched the throttle as i turned right with the blades engaged... the throttle actually began to close while turning right and opened back up when i turned left. It's beyond me...
  • Behind_Blue_Eyes
    Behind_Blue_Eyes Oct 23, 2013
    well if it doesn't do it with the throttle cable attached but does when it's attached do you think there is a problem ???
  • Justin
    Justin Oct 23, 2013
    it does do it when the cable is attached
  • Justin
    Justin Oct 23, 2013
    so yes there is a problem
  • Justin
    Justin Oct 23, 2013
    i figured it out, the throttle cable was stretched
How do I fix an exmark mower that won't start
cold be 1 of many things you got the make listed but no model walk behind , rider . check fuel filter ans hoses leading to the fuel pump I had 1 collapse on me last year .
Apr 25, 2015 | Garden
Exmark walk behind 36 12.5k S/N 19143 parts list
you have a walk behind microwave? Maybe this is the wrong category?
Dec 20, 2014 | Microwave Ovens
Why exmark loses power when blades are turned on
Check for clogged deck.also inspection of mower deck belt. Check for glazing or cracks in belt. That will slow blades down.
Jul 28, 2014 | Kohler Engines NEW 25HP KOHLER ENGINE...
Exmark Walk behind will not start.
Sounds like a bad flywheel or there are usually two magnets on the inside of the flywheel sometimes these magents fall off and with out they magnets you will not be able to produce the forces to start the mower hope this helps
Apr 26, 2014 | Garden
Exmark 44
When you say 'going forwaed', is that while mowing or does it do it without the blades engaged or 'not mowing'?
Jun 13, 2013 | Kohler Engines NEW 25HP KOHLER ENGINE...
I have an Exmark walk behind commercial lawnmower which is stuck in high gear. How do I fix it?
if it is the older style that has a pulley to change sizes not a trans then look at the pulley with the coil spring on it they get stuck take it apart to clean the sliding area careful the spring has a little tension on it
Jul 15, 2012 | Encore EXMARK LAWN MOWER HEAVYDUTY STEEL...
How can I move my exmark zero turn lawn mower when it won't start?
on the rear of the machine there is a release lever for each side pull that back and down to lock it in place
Jul 12, 2012 | Garden
My huskvana wht 3615 walk behind mower constantly pulls to the right how do i fix this
The right wheel shaft may have slipped its pin, allowing the left wheel to provide more power. I had a similar problem with a DR Mower. Farmerbear at FixYa.com
Sep 29, 2010 | Husqvarna 36" Wh3615 Walk Behind Mower...
Metro walk behind bogging down
the springs that control carby is there leaves or grass stopping it from moving ,some lawn mowers have bad desinge for air flow off ****
Jun 02, 2010 | Encore EXMARK LAWN MOWER HEAVYDUTY STEEL...
Garden Logo
102 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
