Question about Tools & Hardware - Others
Need pipe for 9736d800 coleman fireplace - Tools & Hardware - Others
The fireplace no longer produces a flame, i do not have the manual to trouble shoot and fix it
Gas Fireplace Manual - Gas Fireplace Instructions: Mendota ...
mendotahearth.com/gas-fireplace-stove-owners-manual.php
Mendota gas fireplace manuals and gas fireplace instructions for Mendota ...Mendota Gas Fireplace Insert FullView Model FV33i PF2 - Installation Manual
[PDF]FIREPLACE HEATER - Crane
crane-usa.com/assets/.../Fireplace_Heater_2013.pdf
by C Care - ‎Cited by 2 - ‎Related articles
your fireplace heater, please contact Crane. Customer ... This instruction manualapplies to the following models of the Fireplace Heaters product line: Color.
Nov 29, 2015 | Heating & Cooling
Where can I find parts for coleman electric fireplace model#FL-28R?
try searching through google.com that's how I find things .
Mar 04, 2015 | Coleman Heating & Cooling
Fresh air kits
What model of FMI fireplace is this? Is the home a new home that is insulated with a spray foam insulation or anything tighter than regular batt and blow insulation? What part of the country is the house built in? With this information it can be helpful to find a solution for your problem. I work for a fireplace distributor that FMI is one of the lines we carry. Our company has been in the fireplace installation, service, and distribution business for over 35 years. If you give me some more information I might be able to help you find a solution or guide you to the right path. Thanks.
Apr 16, 2014 | FMI Home
Majestic gas fireplace
Either the vent pipe is clogged or maybe you need to have the restrictor plate checked to see if it is proper size for your system.
Jan 09, 2014 | Home
36ECMII pilot light won't light
If you go to this link http://fmisupport.hcents.com/supportdocs/54024F.pdf it will take you straight to the owner's manual.
Now the gas log set is completely seperate from the fireplace. You would need to find out the model of the gas log set as any manufactuer of vented gas logs can go in this fireplace. Just for clarification the brand is actually Coleman but it was made by FMI. Now, the SPVBPD is a direct vent gas log set that was only designed to go into either the Amity, Oxford, or Victor hearth gas stoves. If you have the SPVBPD burner in a 36ECMII then you honestly need to remove that log set, as it was a burner only rated for direct vent fireplaces, and get a set of 18" LP vented logs. If you look at the link below you will see the owner's manual for the SDVBND. These logs need to be removed and you can go with any 18" vented log set. I suggest Peterson (http://www.rhpeterson.com/realfyre/vented-series/)
as they have the widest selection of logs and biggest array of dealers. Good luck.
Desa Tech SDVBND Owner Operation And Installation Manual
Jan 04, 2014 | Fmi Fireplaces SDVBPD Direct Vent Propane...
My problem is I have a electric fireplace the insert is a colemen and the heater stoped I bought it a Costco about 4 years ago
It may need repairing, do not take risks trying to fix it without an expert. But its 4 years old so its better to replace it with new.
Dec 15, 2013 | Leisure HOMEPRIDE Electric Fireplace...
Our coleman fireplace insert starts to warm and then shorts out
Not sure if you have an electric fireplace or a gas fireplace. But, from the way you worded the description of your problem, I'm going to assume that it's electric. I'm also assuming that all the other features of the fireplace work, but the heater doesn' t. If that is the case, below is what the Owners Manual recommends doing.
5. Flame effect operates, but heater does not blow warm air
The TEMPERATURE button is a thermostat control for the heater. Each preset temperature setting has a different thermostat setting as shown to the right:
The heater will NOT activate if the room temperature is above the thermostat setting. If the ambient room temperature is 78° F the user will need to select Setting 3 in order for the heater to be activated. It is normal in warmer climates and in rooms with higher ambient temperatures for the heater to not activate on the lower settings due to the thermostat control. 5a. Try increasing the temperature setting. See drawing:
temp-control-fig.jpg 6. If unit heater does not function, but Power and Heater switches are in the "ON" position and thermostat is set on "HI" 6a. Turn all switches to the "OFF" position and unplug the unit from the wall outlet for 5 minutes. After 5 minutes plug the unit back into the wall outlet, and operate as normal.
Mar 01, 2011 | Coleman Heating & Cooling
What causs downdraft on a stove?
Purchase a extension pipe along with a cap. These caps allow the exhaust to escape but discourage reverse air flow they look like and upside down funnel.
Dec 08, 2009 | Blue Rhino Outdoor Wood Burning Fireplace...
My heater on my coleman electric fireplace Model #FL28R the fan works but not the heater . . please help!
HI,
Sorry for my english, I,m french. I'm from Québec, Canada.
I have the same problem with my fireplace. Same model.
Do you have the manual or the papers who came with the fireplace. My electrician need it. May you scan or fax to me?
Thank you very much.
Jacques Blanchet
Fax: 1-819-762-0130
email: jacques.blanchet@cableamos.com
Dec 05, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Lost assembly manual
http://www.coleman.com/coleman/manuals/ This link should take you to where you can get the manual from.
The rest of the Coleman info is below:
This automatic response has been generated to let you know we have received your message.)
Thank you for contacting Coleman, The Outdoor Company. We appreciate your interest in Coleman products and will be in touch as soon as possible.
You can now order repair parts http://www.coleman.com/coleman/parts/PartsDefault2.asp
find the FAQs
http://www.coleman.com/coleman/faq/home.asp
and close-out items http://www.coleman.com/coleman/ColemanCom/category_main.asp?CategoryID=31000
through our web site as well as view new Coleman products as they become available http://www.coleman.com/coleman/colemancom/prodlist2.asp
You can also locate dealers of Coleman products in your area and register to receive new product information direct from Coleman.
Product manuals are also available
as are product videos,
http://www.coleman.com/coleman/media/prodvideos.asp
a buying guide
http://www.coleman.com/coleman/guide/guide.asp
and warranty information.
http://www.coleman.com/coleman/warrantyinfo.asp
May 18, 2008 | Coleman Patio Fireplace 5068-700 Grill
Tools & Hardware - Others Logo
41 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
