Question about Bosch 2003 Volkswagen Jetta GL 2.0L Professional Preferred
Hi! i have a 2003 2.0L jetta. i was driving it everything was fine, i stopped the engine went for groceries when i wanted to start it the epc light when on and the car didnt start. we push it to start it and it worked, so i got it back home. we scanned it for codes, didnt find any codes and ive check the signal on the starter, the 12v signal was there so ive changed the starter because everything else was turn the fuel pump and computer of the car. Now that ive changed the starter it still wont start ... im out of ideas for now ... i need help lol
    New Friend:
    Problem Solver:
  • 5 Answers
I takes it your car is a manual shift and if so then you need to
Replace the starter switch that is on the clutch the winds the signal to the computer to start engine.
Posted on Oct 19, 2013
I have a 2003vw jetta the epc light is on and the will not come out of park nor the stop lights come on,I have already changed the brake switch and still won't work..
EPC light should have nothing to do with the shift interlock,(EPC is traction control) should be a small cap or plug on the console, near the shifter that has the interlock disengage button,usually done with a key,check shift interlock in the owners manual.
Oct 04, 2015 | Cars & Trucks
I have a 2000 vw jetta. It's a v6 and is
You got a lemon. Most likely one of the coils is giving out if your model has two or a connector may be loose somewhere. You'll have to get it checked out.
Sep 10, 2012 | Cars & Trucks
EPC LIGHT WONT STOP in my 02 Jetta
When was the last time you changed your Air filter( A dirty filter can put MAF sensor out of range). How about the fuel filter (Fuel starvation). These filters should be changed every 30,000 miles . It is normal for all of the dash lights to come on if the engine stops running. Is the Jetta a Diesel or Gas. Perform The OBDII scan again to see if current faults are present. Do the cheapest fixes first. Also check oil often. The low oil sensor will trigger engine shut down if more than 1 quart low
May 21, 2017 | Volkswagen Jetta Cars & Trucks
White smoke at stop light almost no power, Engine light then EPC light, engine light went off ,I make it to dealer they say water in fuel. Could it be something else, I had the gas stations logs and...
sounds to me like u have a leaking engine cylinder head gasket or water in the fuel. the best thing to do is get some fuel out of your tank and let it sit, the water will separate out if it is present
May 19, 2010 | 2008 Volkswagen Jetta
2005.5 Jetta: EPC, exhaust, and battery lights on, car stalling
your battery or you alternator is not performing properly depriving the engines ignition system of the volage necessary to keep the engine running. the EPC light came on because raw fuel was sensed by the o2 sensors
Mar 21, 2010 | 2005 Volkswagen Jetta
My epc light went on in my 2002 volkswagen jetta
Take it to the dealer, the EPC warning light - and even more the failsafe run which doesn't allow you drive faster than 20mph) is an indication of serious motor troubles. They can read the ECU faultcodes, which should be a good startingpoint for troubleshooting the cause ...
You could do some basic troubleshooting like checking the air filter, the oil level, the spark plugs, etc. You didn't fill it up with bad gas, did you ? And does the engine make strange noises/vibration when running idle ? In case you fixed some obvious cause, you can dis- and reconnect the battery to erase the engine's faultcode. If it's not fixed, the EPC (and failsafe run) will simply come on again.
My advice would be not to drive it untill it's fixed to prevent more potential damage.
Aug 17, 2009 | 2002 Volkswagen Jetta TDI
2005 New Jetta and My EPC light
need to recalibrate the throttlebody
Jun 22, 2009 | 2005 Volkswagen Jetta
Bosch 2003 Volkswagen Jetta GL 2.0L Professional Preferred Logo
70 people viewed this question
Top Bosch Electronics - Others Experts
Mike
ray gallant
Are you a Bosch Electronics - Other Expert? Answer questions, earn points and help others
