Question about Uniden Cordless Phone
Setting how many rings before getting into answering machine
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
What model?
Posted on Oct 19, 2013
2 Suggested Answers
  • 81 Answers
SOURCE: We just bought a new
If you have changed the setting on the base station and that did not work, power your base station off completely and try again if that does not work you have an out of box defect and need to exchange it.
Posted on May 06, 2011
1739 digital answering machine setting number of rings before it answers
After setting the number of rings, press PLAY/STOP to save the setting and exit the menu. Full details are on page 2 of the manual.
Jul 31, 2012 | AT&T ATT1739 Digital Answering Machine
How do you change the number of rings before machine turns on?
When the AT&T 1717 digital answering machine is powered off it will answer an incoming call after 10 rings, it will announce "machine is off" then beep twice, dial 0 to turn it on. The machine is now ready to answer calls. This 10 ring setting is factory set and cannot be modified. To set the number of rings to answer for normal operation press <SET UP> button and hold for 2 seconds, machine will announce current ring setting. Press and release <ANNC/SKIP> or <MEMO/REPEAT> until you hear the number of rings you want. Press and release <PLAY/STOP> to exit. The ring settings available are 2, 4, and toll saver. When set to toll saver machine will answer after 4 rings when there are no new messages and after two rings when is anew message. Here is a link where you can download manual, http://safemanuals.com/user-guide-instructions-owner-manual/AT%2526T/1717-_E
Dec 09, 2010 | AT&T 1717 Digital Answering Machine
I want the fax to work with an identa ring. How do I program this? As it is now I have to turn on the fax to receive. Does this HP work with identa ring?
The following set up assumes you have one conventional phone line, but two different phone numbers. One being your regular phone number and the other a distinctive ring for your fax machine
If that is what you have then this is how you set up the phone. Its important to know what type of distinctive ring your phone company will send to your phone. If it doesn't work you can talk to them about getting a different one than their default distinctive ring.
2 Set the HP all-in-one to answer incoming calls automatically.
Press the Auto Answer button until the light is on.
3 Change the Answer Ring Pattern setting to the pattern that has been assigned to your fax number by the telephone company, for example, double rings or triple rings.
For information on changing this setting, see Change the answer ring pattern
(distinctive ringing).
Note Your HP all-in-one is factory-set to answer all ring patterns. If you do not set the correct ring pattern assigned to your fax number by the telephone company, your HP all-in-one might answer both voice calls and fax calls or it might not answer at all.
4 (Optional) Change the Rings to Answer setting to one ring or two rings.
For information on changing this setting, see Set the number of rings before answering.
5 Run a fax test. For information, see Test your fax setup.
Your HP all-in-one will automatically answer incoming calls that have the ring pattern you selected (Answer Ring Pattern setting) after the number of rings you selected (Rings to Answer setting). Then it will begin emitting fax reception tones to the sending
fax machine and receive the fax.
If it is easier or you want to know other options which may be more applicable to your phone setup. You can find that information here.
http://h10032.www1.hp.com/ctg/Manual/c00235090.pdf
Jul 09, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I need to set the rings
Rings to Answer:
THIS SETTING ALLOWS YOU TO SELECT THE NUMBER OF RINGS BEFORE THE UNIT ANSWERS A CALL.
1. The unit announces, "Rings to Answer (the current rings to answer setting). To set rings to answer press NEXT. Press SET to continue.
2. To chantge the rings to answer, press and relase the NEXt OR GREETING/PREVIOUS button and the unit announces a number, such as "2,3,4," or "2, toll saver, 5."
3. After choosing a number, press and release the STOP/SET button to store the rings to answer. The unit confirms the setting and enters Message Length menu.
Taken directly from the instruction booklet that came with my GE 29888GE1 instructions.
Hope it works for you ! jp
Mar 02, 2009 | GE 29888GE1 Digital Answering Machine
Increase the number of rings
the default setting is 5 rings. if you need to change that:
set the ring to answer to higher number, however, that will put the machine in manual answering of fax.
the better setting is to rest the phone or the answer machine to a lower number of rings.
Jan 13, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
How can i change the ringer on my fax machine?
Setting Ring Delay:
The Ring Delay setting determines the number of times the fax machine rings before it answers. If you have extension phones on the same line as the fax machine, keep the Ring Delay at a default setting of 4:
1 Press Function/Set, 2, 1.
2 Press < or > to select how many times the line rings before the fax machine answers (00 – 04) and press Function/Set. If you select 00, the line doesn’t ring at all.
3 Press Stop to exit.
Hope that's clear enough :)
Chris (ziraffa)
Dec 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Hangs up after 2 seconds into recording message
SETTING THE RINGS TO ANSWER
This setting allows you to select the number of rings before the answering system answers a call.
At idle status, hold down the volume "UP" button over two seconds to enter the ring times setting of answering. The answering system announces, "ring time two" (the default is 2).
To change the rings to answer, press and release the "PREVIOUS" button (<<) or the "NEXT" button (>>) and the answering system announces a number such as "2, 1, toll save, 9...” OR "2, 3, 4...", if you select the toll save and the digit LED light shows a “γ”, the answering system announces “toll save”.
After choosing a number, press the “PLAY/STOP” button one time to store the rings to answer, and the answering system confirms the setting and returns to the idle status.
NOTE: when the machine fails to operate properly, just unplug the power for 10 seconds, and redo the settings.
Aug 03, 2008 | Emerson Em1200 Answering Machine
How can I change the Rings to Answer setting to one ring?
If you turn on the Auto Answer setting, you can specify how many rings occur before
incoming calls are automatically answered.
The Rings to Answer setting is important if you have an answering machine on the
same phone line as the device, because you want the answering machine to answer
the phone before the device does. The number of rings to answer for the device
should be greater than the number of rings to answer for the answering machine.
For example, set your answering machine to a low number of rings and the device to
answer in the maximum number of rings. (The maximum number of rings varies by
country/region.) In this setup, the answering machine answers the call and the device
monitors the line. If the device detects fax tones, it receives the fax. If the call is a
voice call, the answering machine records the incoming message.
To set the number of rings before answering via the control panel
1.
Press Setup.
2. Press Basic Fax Setup, and then press Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press the left or right
arrow button to change the number of rings.
4. Press OK to accept the setting.
Get manual at http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf
Jul 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
NUMBER OF RINGS TO ANSWER FAX
same phone line as the HP All-in-One, because you want the answering machine to
answer the phone before the HP All-in-One does. The number of rings to answer for
the HP All-in-One should be greater than the number of rings to answer for the
answering machine.
For example, set your answering machine to a low number of rings and the HP All-in-
One to answer in the maximum number of rings. (The maximum number of rings
varies by country/region.) In this setup, the answering machine will answer the call
and the HP All-in-One will monitor the line. If the HP All-in-One detects fax tones, the
HP All-in-One will receive the fax. If the call is a voice call, the answering machine will
record the incoming message.
To set the number of rings before answering from the control panel
1. Press Setup.
2. Press 4, and then press 2.
This selects Basic Fax Setup and then selects Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press or to
May 14, 2008 | HP Officejet 4315v All-In-One InkJet...
Brother MFC8840D only 4 rings before fax pickup?
The TAD (TELPHONE ANSWERING DEVICE) must answer within four rings (the recommended setting is two rings). The MFC cannot hear CNG tones until the TAD has answered the call, and with four rings there are only 8 to 10 seconds of CNG tones left for the fax ?handshake?. message. do not recommend using the toll saver feature on your external answering machine if it exceeds five rings.
Sep 15, 2007 | Lexmark X8350 Print, Scan, Copy and Fax...
Uniden Cordless Phone Logo
16 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
