Question about Telex TR300-7127-XXXXX Single-channel VHF Beltpack Transceiver
I have a 2003 Ford Windstar. Replaced brakes and bled them. Brakes still mushy. What next?
Change brake fluid completely and bleed out starting at the furthest point to the nearest point to master cyl.Let sit overnight and bleed nearest point to master cyl as air rises to highest point.
Posted on Oct 19, 2013
Brakes will not work. Still mushy after bleeding.
Check your hose that goes to your master cylinder you may have vacuum leak there. Let me know what did you find!
Oct 19, 2013 | 2003 Ford Windstar
I have a 2004 Chevy Malibu. I have replaced the front brake pads, calipers and rotor and bled the brakes but they are still mushy. I heard that they have to be gravity bled. My question is: Do the brakes...
no,to gravity beed just open bleeder remove master cylinder cap & dont let it go empty.
if you only opened the front you may just need to bleed the front.some times pumping up
brakes before bleeding will help start the gravity bleed.
good luck
Jun 22, 2011 | 2004 Chevrolet Malibu
We had a recall 03 windstar ABS light was on all time we had front and back brakes replaced ford checked said rear axle ok but, light is still on and brakes make a terrible noise and sometimes they go to...
I own a 2001 Windstar. Your noisy brake problem could be nothing more that new brakes being broken in. I have done many brake jobs on my 2001 Windstar as well as other vehicles that I have owned. To prevent this problem from occuring, I apply a thin film of Disc Brake Quieter directly to each brake pad during the installation process. This quiets the brakes during the break in period. I hope this helps.
Jan 09, 2011 | 2003 Ford Windstar
2002 sebring, I changed all disc brakes and pads, then front calipers, bled brakes , but pedal is soft.
could be an air pocket if you didnt bleed them correct or the cap is off the resivior or you have some sought of leak
Oct 16, 2009 | 2003 Ford Windstar
1997 FORD F250 XLT 4WD - Had a hard brake pedal with hardly any brakes while standing on them. Replaced booster and wheel cylinders at same time now the pedal is mushy and no brakes.
They need to be bleed again all four wheels but your vacuum pump may be bad since diesels don't have vacuum then have to have a pump, check that the booster one way check valve is good if you can blow thew it both ways it's bad, to bleed start from the wheel farthest away from the master cylinder pump the brakes 5 times and hold down then open the bleed valve keep doing this until you get clear fluid out of each wheel once you have done that if it is still mushy and you know you have vacuum re bleed with engine running this will help push more out with power assist. most like the hard brake pedal had to do with no vacuum check out the pump. You may also have to reset the 2 way check valve if you need help with this let me know.
May 27, 2009 | 1998 Ford F150 Regular Cab
98' Ford Windstar has a spongy brake
Have you had anyone try to clean and adjust the rear brakes? You will need a shop to scan the van for ABS codes first to cure the ABS light.
Mar 02, 2009 | 1996 Ford Windstar
Telex TR300-7127-XXXXX Single-channel VHF Beltpack Transceiver Logo
26 people viewed this question
Top Telex Radio Communications Experts
Mike Charette
Andrew Taylor
Andrew Taylor
Are you a Telex Radio Communication Expert? Answer questions, earn points and help others
