Question about Garden
How do you remove the spool from the Craftsman Electric Wacker Model#358 799 200
4 Suggested Answers
SOURCE: removing spool from homelite 13 inch electric trimmer
The entire cap does not come off. You push the buttons in on each side and only the very top of the cap comes off.
Posted on Jul 23, 2009
SOURCE: Can't remove spool from Black & Decker GH1000
UNscrew the cetral screw with a flatheaded screwdriver, then put the flate blade of the screwdriver in through the side slot where the cap clips in, and gently pry up on the spool from underneath it.
Posted on Nov 04, 2010
hunter19_46m
  • 7482 Answers
SOURCE: 17" 32cc gas weed wacker
Hi pmbaugardne...
Please take time to rate me
Posted on Sep 19, 2011
Brand new weedwacker model#316-711370 first time started right up ran for awhile then just stopped,wont start at all now
#34 craftsman weed wacker manual
45.55.157.141/craftsman-weed-wacker-manual.html
100+ items - pdf download about #34 craftsman weed wacker manual ... Books Title
File Code
Craftsman Weedwacker Manual from Sears com
Free Craftsman Trimmer User Manuals ManualsOnline com
Aug 04, 2015 | Cars & Trucks
Craftsman weedwacker model 316711970
If you go to searsparts.com and put in your model number it will show you a drawing of your weed wacker. Not sure of what you are looking for. Hope this helps.
Jul 09, 2015 | Craftsman 29cc 4Cycle Straight Shaft...
Manaul for Craftsman electric trimmer 358.783522. I went on the Sears Parts website and could not find the manual. Do you have any other suggestions on where to locate it? The Craftsman webiste was of...
I see the manual listed after part number 25 in this Sears Parts Direct.com website. It is inexpensive and if you can view a complete parts breakdown of the unit here, maybe you won't even need to order a manual. Usually they are a free download. Here is your model:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-358783522/0247/1503820/10059474/00001?blt=06&prst=0&shdMod=358783522
Apr 13, 2011 | Craftsman Garden
I have an electric Weed Wacker and when I press the trigger to start it, I hear the engine going but the head does not spin. Is there a way I can fix this myself? If so, how? Do i need to take this to a...
The shaft houses the cable that drives the spool to spin. It sounds like the cable has snapped in two. It is easiest to remove the spool amd pull out the cable to see. Replacements are sold at most gardening centers
Aug 10, 2010 | Sport & Outdoor - Others
I am trying to change the string on a Craftsman Weed Trimmer
Usually you "Push in" as you turn them. Or...there is a knob with a male thread shaft screwed into place holding it all tight. Hold the spool steady as you try to turn the knob off. Or...there is simply a "nut" to take off. But for the most part the newer wacker spools usually just "push in and turn/twist" out. Simple. to reinstall it or replace it with a new one simply push and twist it the opposite removal direction. FYI most lines can be manually "rewound/refilled" by yourself and reused over and over until they really wear out. There are little tricks to doing a rewinding but it isn't anywhere near difficult to do...or learn. Usually the price of a replacement spool is 5 times the cost of rewinding them yourself. Comon its easy! If ya want I'll help ya thru it.
May 10, 2010 | Craftsman Garden
I need part for a Craftsman Weedwacker
You can either go to sears, or craftsman website or even easier if you can get one off of ebay
Aug 18, 2009 | Garden
Cannot undo the string compartment to put new string in. There may still be string in the compartment but I cannot get into it. This is a 12 inch Toro electric wacker.
There sould be a knob that turns counterclockwise to take spool off. If not there sould be two taps that push in and pull down on what they call the spool head. Hopefully this will help you.
May 14, 2009 | Toro& Electric String Trimmer
Replace pull cord on ryobi model cs30 weed wacker
Good fix, mrfixit-jerr! Also, if you remove the rear cover (4 screws) you can stabilize the crankshaft by inserting a screwdriver between the lobe of the shaft and the counterweight.
Apr 03, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Double spool on Weed Wacker
This isn't a solution to the problem. However, I think you should talk to someone at Home Depot or Lowes or wherever you bought the model, and see if the string is in there correctly; if it is, then u'r weed wacker must have some other mechanical problem. Sometimes it is just best to buy a new one. The more expensive models are the best.
Aug 10, 2008 | Electrical Supplies
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
