Question about Avid Juicy Ultimate Hydraulic Disc Brake , 160mm, Front
Brakes still mushy after bleeding. - Avid Juicy Ultimate Hydraulic Disc Brake , 160mm, Front
    Problem Solver:
  • 18 Answers
If they don't go firm after few days then there is probably still air in the system. At least this applies to car brakes. I haven't done bike brakes but I would suggest to repeat the bleeding process. Check carefully for leaks and there might be a gasket problem. This I can say from a car braking system experience.
Posted on Jan 17, 2014
Mushy brakes on 2008 Chevy 4wheel drive pickup
mushy brakes can be from air in the system or weak rubber brake lines expanding under pressure. I would try bleeding the brakes starting at the longest line first
Nov 22, 2014 | Cars & Trucks
I have a 2003 Ford Windstar. Replaced brakes and bled them. Brakes still mushy. What next?
change brake fluid completely and bleed out starting at the furthest point to the nearest point to master cyl.Let sit overnight and bleed nearest point to master cyl as air rises to highest point.
Oct 19, 2013 | Telex TR300-7127-XXXXX Single-channel VHF...
Brake and e brake warning lights stay on happen when i blew a brake line.
If brakes are mushy then you still have air in the lines.Did you bleed all 4 wheels?have wife push brake pedal down once and hold then bleed hold down one and bleed and so on if this has a quick takeup master cylinder pumping 3 or 4 times then bleed wont work
Jun 14, 2012 | Chevrolet Cars & Trucks
2007 dodge sprinter van brake bleeding
SOME SPRINTERS HAD RECALLS ON MASTER CYLINDERS YEARS 2006-2009 CHECK DEALER FOR MAYBE RECALL,IAM NOT SURE WHY YOUR BLEEDING THE BRAKES IF YOU HAD OPENED A LINE OR CHANGED A CALIPER THERE MABE AIR IN THE LINES-I ALWAYS USE A PRESSURE BLEEDER OR YOU CAN GRAVITY BLEED SYSTEM BY OPENING EACH BLEEDER SCREW UNTILL GOOD FLOW THEN CLOSEING-IF BLEEDING FOR MUSHY PEDAL CHECK BRAKES AND THICKNESS OF ROTORS-ARE THEIR ANY CODES -IS THE ABS LIGHT ON-IF ALL CHECKS OUT GO TO MASTERCYLINDER
Dec 30, 2011 | 2007 Dodge Sprinter
Brakes are mushy added brake fluid still mushy.
you probably got air in the lines and need to bleed the brakes.
Dec 05, 2010 | 1993 Oldsmobile Cutlass Supreme
Brakes r mushy,i changed the master cylinder better for a week then mushy again then good again for about a week,have been doing this for 6 weeks,fluid doesnt go down,cant find no leaks, but air comes out...
Did you bench bleed the master cylinder? You should try bleeding the lines going to the master cylinder too, just bleed them same way you would a caliper, only your loosening the lines a bit, not a bleed screw. Then of course, for good measure, bleed each wheel.
Let me know how it turns out.
Apr 01, 2010 | 2006 Hyundai Elantra
Brakes mushy, fluid a little bit low, but filled
if you can not find a leak then try to bleed your brakes somtimes thell loose pressure but if your fluid goes low then you most likey have a leak the smallest hole anywhere in the brake system will cause this
Jul 09, 2009 | 1994 Pontiac Bonneville
1997 FORD F250 XLT 4WD - Had a hard brake pedal with hardly any brakes while standing on them. Replaced booster and wheel cylinders at same time now the pedal is mushy and no brakes.
They need to be bleed again all four wheels but your vacuum pump may be bad since diesels don't have vacuum then have to have a pump, check that the booster one way check valve is good if you can blow thew it both ways it's bad, to bleed start from the wheel farthest away from the master cylinder pump the brakes 5 times and hold down then open the bleed valve keep doing this until you get clear fluid out of each wheel once you have done that if it is still mushy and you know you have vacuum re bleed with engine running this will help push more out with power assist. most like the hard brake pedal had to do with no vacuum check out the pump. You may also have to reset the 2 way check valve if you need help with this let me know.
May 27, 2009 | 1998 Ford F150 Regular Cab
Brakes are mushy on my 2000 Ford Focus.
i would say your brakes are getting worn out because if the m.c. is low the only reason its low is because your brakes are worn down the fluid doesnt just disappear unless you have a leak just take look and see if anything is wet underneath.
May 11, 2009 | 2000 Ford Focus
Avid Juicy Ultimate Hydraulic Disc Brake , 160mm, Front Logo
67 people viewed this question
Top Avid Cycling Experts
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
John Egan
John Egan
Are you an Avid Cycling Expert? Answer questions, earn points and help others
