Question about Greenworks 1700 PSI 1.4 GPM Electric Pressure Washer 51012
When the 1700 psi electrical model is plugged in it trips a circuit breaker. Did not do that before.
    Scholar:
  • 29 Answers
Greenworks 1700 psi - Pressure Washer Problem and Solution:
Problems:
1. The main problem is the water outlet connector between the pump and the pressure hose. It's made of plastic. So water ran to the motor, switch and capacitor.
2. The 2 connectors to the capacitor may be rusted by now. So it build high current when plug-in and pressing the power-on button. Caused the power breaker to trip.
3. The motor is stuck caused the power breaker to trip too.
"These were the problems I encountered."
Solutions:
1. Disassemble the top cover by removing 10 pcs Philip screws on the left and right side at the bottom. Note: you need a 1 foot long Philip screw driver to do this job. Next, removed 4 hex screws at the middle.
2. Check the capacitor: Mine, was pushed out from the cover and the 2 connectors were rusted. Just in case, replaced the 2 connector instead of salvaging them. Pile the 2 connectors of the big capacitor. Note: This big capacitor is lethal, that it can harm/shock you if it is charge: (230Vac), make sure is completely discharge, by checking the DC voltage from Digital multimeter. To discharge place a light bulb as load between the 2 connectors. Check and measure the capacitance or use an ESR meter to make sure the capacitor is in working condition.
3. check the motor: Try to spin the propeller/small blade by hand. If it doesn't move or spin do this: Remove the black plastic cover and used allen / hex driver. If it doesn't move /spin try this: tap the shaft (where the hex located) with the hammer softly, then spin it. If it doesn't move tap again with little harder until the motor spin using your hand rotation.
4. The main problem is the water outlet connector (model no.:34117365) causing all these problems. It was made of plastic. Don't try to glue or repair it. I tried JB weld and didn't work. Imagine 1700psi coming out of this connector. Use the Sears replacement part no. 33101365 - a solid metal. use for craftsman pressure washer. It's the perfect replacement. Cost $8.52 and about $19.00 with shipping.
5. Assemble and check out other outlet(s) for leakage. If found one, the outlet connecting to the soap line. I used plastic tie.
This pressure washer belongs to my neighbor. Asked if I can fix it for I fixed their 3 computers long time ago. It was a challenge for me, because I didn't have experience in fixing pressure washer before. But it everything works now. Good luck.
Roan
Electronics Tech
Posted on May 22, 2014
Tip
Circuit Breaker Keeps Tripping
Your circuit breaker keeps tripping and you are wondering why it would do that. There actually can be many things that can cause a circuit breaker to trip, or shut off. I will give you some reasons why circuit breakers trip and also some circuit breaker troubleshooting tips.
The first thing to remember about a circuit breaker is that they are first and foremost a safety device. The protection provided by the circuit breaker is also two fold. The circuit breaker will protect against overcurrent, or in other words, it will keep you from melting down the wires by placing too high of a load on any circuit. This would cause the wires to overheat and start a fire.
The other way a circuit breaker protects you is that the circuit breaker senses very quickly if there is current flowing to the ground with out it going through a load. This means that there is a shock hazard or a fire hazard. The circuit breaker will interrupt the current and shut off to prevent damage from happening.
If your circuit breaker is tripping off then you need to find out why this is happening. By eliminating the load on the circuit you can start to narrow down the possibilities. If there are a number of things plugged into the circuit then unplug something till it will stay on.If you can get the load low enough so that the circuit breaker stays on then you are okay and just need to spread the load out over a couple of circuits to prevent the overloading.
If you cannot stop the circuit breaker from tripping, unplug loads until you narrow the problem down to one thing. Once you narrow it down to one thing that is tripping the circuit breaker then you can find out why the load is tripping the circuit breaker.
Now if the load that is still plugged in is an appliance like a washing machine, then you need to find out if the cause of the tripping is the motor or if it is something like a wire that is rubbed through and is shorting out. If it is the motor the circuit breaker will often trip right when the motor goes to start up.
If the circuit breaker trips immediately when power is applied then you probably have a bad wire or connection. Poor connections are common in appliances such as an oven or a dryer where high amounts of current can be pulled at one time and the heat will make the connection get hot and eventually fail.
There are so many different possibilities for circuit breakers tripping that it is impossible to cover them all. There is one tool that will make the detective work of finding a short or problem much easier.This tool is called an "OHM" meter. One of these can be purchased at most any hardware or electrical store. Many big box stores and even a Wal-Mart also have them. There are many very inexpensive models available.
By using an OHM meter you can check the resistance of a circuit. The idea is that if a circuit has NO resistance to ground then it is bad and the electric can flow to the ground unhindered. This is a dangerous situation and must be corrected. In motors the flow of current between phases with no resistance, is also a reason why a circuit breaker will trip.
Above all remember that you need to verify and make sure that all electric is shut off to any piece of equipment that you are working on. Isolating and finding electrical problems can be very time consuming and frustrating. It will take time and patience to methodically eliminate the possible causes of a circuit breaker that keeps on tripping or a circuit breaker that will not reset. Through careful checking you can one by one eliminate the possibilities and find the cause of your circuit breaker not staying on.
on Oct 03, 2010 | Hammering
Simoniz S2000 XE02 internal cct breaker keeps tripping after 30secs tried to get a parts break down but that info is really ****** and nothing on line anywhere. Any idea what causes the cct breaker to...
First be very careful because the unit is protected by a ground fault internal circuit interrupter and may trip if there is a short circuit to ground. Even a very small short circuit will trip the circuit breaker.
Something else: If you are plugging it into an already existing ground fault outlet then that may also cause one of the breakers to trip.
Like I first mentioned, if you don't know what your doing be very careful. Electricity and water are not friends, especially if the circuit breaker is tripping.
Good luck,
Marty
Jun 26, 2014 | Coleman Powermate DuraBuilt 1400 PSI...
Rancilio silvia trips circuit breaker
There is an electrical short within the machine, ...don't doubt it - the results of your experiments prove that it has an electrical fault and that your tripping circuits are doing exactly what they should to keep you and your property safe.
The machine needs servicing by a registered Rancilio electrician, don't go inside yourself, its highly likely that the part causing the tripping is dangerous and will need to be replaced.
Apr 19, 2013 | Rancilio Silvia Espresso Machine
Lights went out breaker was thrower switched breaker to on several times when I came in tv would not come on electricity is good to it so is their a fuse and where is it on tv or is there a nother place on...
Pull the TV plug out of the electrical outlet. In fact, pull all plugs from all nearby receptacles. Try the circuit breaker. If it still trips, pull more plugs from the receptacles untill the circuit breaker no longer trips. Reverse the process to isolate the plug that is causing the circuit breaker to trip. Repair broken item.
Apr 12, 2013 | Televison & Video
WASHER TURNS ON FOR COUPLE OF SECONDS THEN TRIPS BREAKER.PROBLEM WITH MOTOR ???.
Is it tripping the breaker on your home's electrical panel? If this is the case, you need to know what that breaker is also feeding, how much amperage it can handle, and what the load demand is. Your washer needs 1700W which is around 15 Amps. If you're on a 15 Amp breaker that is already supplying power to something else, such as incandescent light bulbs, then you're going to trip the breaker each and every time. You'll want to plug it into a 20 Amp circuit that's being used by little to no other electrical devices. A quick alternative is to unplug or power off all other devices before using the washer... or plug it into the same outlet that you use your blow dryer.
Jul 18, 2011 | Black & Decker 1700 PSI Electric Pressure...
I "won" a Rainmate from
No, not that I'm aware of. But, the problem itself, may be in the electrical receptacle. A loose wire, a bad connection or interior damage could all cause the circuit breaker to trip. Or it may simply be the case, of line that air purifier is plugged into, is simply overloaded, because of other electrical appliances are on the same circuit of tripped the circuit breaker. Most air purifiers have their on circuit breaker or fuse built-in to the unit. And that, will usually trip before the circuit breaker in the breaker panel of your home.
Here's how you test that theory: Plug the unit into another outlet, that is on an entirely different circuit than the original one and turn it ON. If this trips a different circuit breaker, then you know it's an internal problem with the unit. If it doesn't trip the circuit breaker, the problem is with the original receptacle or the line that feeds that receptacle and it's circuit breaker.
Hope this helped you to troubleshoot and solve the problem.
Jun 13, 2011 | Rainbow Rainmate Air Purifier
I have have my sunbeam electric heater model number sfh090 for a month now and it just stopped working and wont turn on or anything! i tried leaving it unplugged for a while then plugging it back in but...
Have you tested the receptacle that the heater is/was plugged into, to make sure it's working and a circuit breaker hasn't been tripped?
If not, plug a lamp into the receptacle to see if it works. If it doesn't, check your home's circuit breaker panel for a tripped breaker. If you find one, make sure there's nothing still plugged into the offending receptacle and reset the breaker. Then, plug the heater in and turn it on. Does it trip the breaker again? If it does, there's some type of short in the electrical system of the heater. If it doesn't trip the breaker, but still doesn't work, return it to the place of purchase for a replacement. However, you must have your Proof of Purchase Receipt to do this.
Hope this helps solve your problem.
Feb 17, 2011 | Sunbeam Heating & Cooling
When plugged in, no power, dead and not functioning
Have you checked the receptacle that the heater is plugged in to, to see if it's still working? You can do this by unplugging the heater and plugging a lamp into the receptacle and turning on the lamp. If that fails, then there's a circuit breaker tripped in your home's circuit breaker panel. Check that and if you find one, make sure nothing is plugged into the offending receptacle and reset the circuit breaker.
Now, plug the heater back in. Does it work or does it trip the circuit breaker? If it trips the circuit breaker the heater has an electrical problem, that may or may not be able to be repaired.
Since you didn't mention what brand and model heater you have, there's not much more I can do to help you trouble shoot the problem.
Never the less, I hope this helps steer you in the right direction.
Feb 15, 2011 | Heating & Cooling
Trips circuit breaker
If the unit is new then the unit may be over-sized for the electrical circuit. If the unit is not new then the compressor may be failing
Apr 19, 2010 | Amana PTH153B35AJ Air Conditioner
Greenworks 1700 PSI 1.4 GPM Electric Pressure Washer 51012 Logo
1,289 people viewed this question
Top Greenworks Garden Experts
Ed60062
Level 1 Expert
Marc Taylor
richie46
Are you a Greenworks Garden Expert? Answer questions, earn points and help others
