Question about Mercedes 250 d turbodiesel heater case. . air conditioner case with
Interior climate controll switch. Need to know how to remove or replace it. where is all the screws situated on the centre panel.
  • 25 Answers
Its a computer part. can not change it by yourself
Posted on Oct 20, 2013
How do I remove the driver side door panel on a 1994 Lincoln Mark VIII
Remove mirror mount cover assembly.
Remove inside door handle cup (22634).
Remove door lock control bezel.
Remove window control bezel.
Remove interior lamp lens.
Remove screw from interior lamp assembly body.
Remove screw from window control bezel opening.
Disconnect mirror, lock switches and memory seat on driver side from bezels and wire harness.
Disconnect window switches from window bezel and wire harness.
Lift front door trim panel (23942) vertically, out of weatherstrip and over lock rod.
Disconnect interior lamp (13776) from wire harness.
Remove front and rear door trim retention hooks into door inner panel.
To install, reverse Removal procedure, paying special attention when inserting inner door trim into weatherstrip. Rock inner door trim into weatherstrip and push downward until lower trim belt character ditch lines up with score mark on inner door panel.
Aug 16, 2014 | 1994 Lincoln Mark VIII
Heater switch replacment
Hello! it's my job to make things as easy for the customer as possible...Therefore I must ask why you want to replace the heater switch? Is it because you have lost one or two of the switch speeds? Your vehicle is noted for loss of the Blower Motor Resistor...
Changing the Heater switch means removal of the Climate Control Assembly which is not the easiest of jobs...I've included the process...But are you sure the blower resistor is OK? If you have lost 1,2, or all blower motor speeds it's more than likely the Resistor pack. And a lot easier to change...
Guru...saailer
Remove climate control:
  1. Remove the instrument cluster finish panel...
  1. Remove the 3 climate control assembly screws...
  1. Disconnect the climate control assembly vacuum connector...
  1. Disconnect the 5 climate control assembly electrical connectors...
  1. Remove the climate control assembly..
Removal of blower motor Switch:
  1. Remove the blower motor switch knob.
  1. Remove the blower motor switch.
    1. Remove the screw.
Removal of blower motor Resistor:
Blower Resistor is under the battery tray...
MOTORCRAFT Part # YH1698 ...cost $25
Guru...saailer
Dec 22, 2011 | 2007 Ford Econoline
How do you take of the dash paneling to install a new aftermarket cd player?
  • Disconnect the negative battery cable from the Jeep Cherokee battery with the 10 mm wrench.
  • 2 Remove the five screws on the top edge of the dash panel with a Phillips-head screwdriver.
  • 3 Pry the trim panels surrounding the climate control knobs away from the dashboard with the trim panel removal tool.
  • 4 Remove the trim panel that surrounds the headlamp switches (located to the left of the steering column) with a trim panel removal tool.
  • 5 Remove the two screws behind the trim panel that surrounds the headlamp controls with a Phillips-head screwdriver.
  • 6 Pull the dash panel that surrounds the stereo and covers the instrument panel of the Cherokee, away from the dashboard by hand.
  • 7 Remove the two screws from the stereo mounting bracket. One screw is on the bottom left corner, the other screw is on the top right corner. Each screw can be removed with the 10 mm socket and drive.
  • 8 Pull the factory stereo from the stereo mounting dock.
  • 9 Disconnect the stereo wiring from the back of the factory unit.
  • 10 Connect the Jeep Cherokee factory stereo wiring to a wiring harness adapter. Connect the wiring harness adapter leads to an aftermarket stereo. Slide the aftermarket stereo into the stereo mounting bracket and replaced two screws at the opposite corners with the 10 mm socket and drive.
  • 11 Replace dash panel that stretches across the top of the steering column.
  • 12 Replace the two screws at the top of the headlamp control switch. Replace the trim panel around the headlamp switch.
  • 13 Replace the trim panel that surrounds the climate control knobs.
  • 14 Replace the five screws on the top edge of the dashboard with a Phillips-head screwdriver.
  • 15 Replace the negative battery cable over the negative battery terminal and tighten the cable to the negative lead post with the 10 mm wrench
  • Dec 24, 2010 | 2006 Jeep Grand Cherokee
    Hello I have a general electric dryer model DBSR463EG6WW serial number TR775112A and was wondering how do I bypass the start switch because it is broken
    please there is no need to start your dryer without the switch. you can easily replace the switch yourself just follow this instructions below to replace your switch. things you will need are philip and hex and nut screwdrivers, putty knife and Replacement "start" switch. then Disconnect the dryer from the electrical outlet. Slide the dryer out from the wall and disconnect the dryer vent from the dryer's back panel.
      1. Loop a piece of string behind the "Start" button and pull forward on the string to pop the knob off the switch's post.
      2. Access the interior of the control panel. Depending on your model of dryer, there are several ways to access the interior of the control panel. On older dryers, there will be an access panel along the back of the control panel that can be removed once all of the retaining screws have been removed. On newer dryers, the control panel is held in place by screws in the front or spring clips. Remove the plastic end caps on the control panel and remove the screws underneath. If your dryer has no end caps, slide a putty knife under the corners of the control panel and lift up on the knife to release the clips. Rotate the control panel toward the rear of the dryer to access the interior.
      3. Unplug the wires from the switch by sliding them off the contact terminals on the switch. Make a note which wire connects to which terminal so you can easily connect them to the new switch.
      4. Press the release tab to unlock the switch and slide it out of its socket. If you have an older dryer, remove the retaining screw to remove the switch. Slide a new switch into the socket and press it down until the release tab locks into place. If you removed a retaining screw, replace the screw. Reconnect the wires.
      5. Rotate the control panel back down on the dryer or replace the rear access panel. Replace the knob and reconnect the dryer vent. Plug the dryer back into the electrical outlet.
    Dec 24, 2010 | Dryers
    Heater only works on #1 setting after I replaced resitor pack
    resistor is working but switch is bad. You can get a new switch from autozone for $20. Here is autozone procedure for pulling the control panel. Let me know if you have questions.
    1. Disconnect battery negative cable from battery and properly isolate to prevent accidental reconnection.
    2. Remove or disconnect the following:
      Audio unit Instrument panel console bezel retaining screws
    3. Pull the instrument panel console bezel forwards and disconnect the electrical connectors.
    4. Detach the temperature and air distribution blend door Bowden cables from the climate control assembly.
    5. Remove the climate control assembly.
    To install:
    1. Install or connect the following:
      Climate control assembly Bowden cables to climate control assembly Climate control assembly electrical connectors Instrument panel console bezel and securely tighten the screws Audio unit Negative battery cable
    Dec 16, 2010 | 2000 Ford Focus
    How do I remove a car radio from a 2007 yukon
    Unclip and remove radio trim panel.
    (Figure A)
    Remove (2) 8mm screws securing
    switch panel below climate controls.
    Unplug and remove switch panel.
    (Figure B)
    Remove (2) 8mm screws securing climate
    controls. Unplug and remove climate
    controls. (Figure B)
    Remove (4) 9/32” screws securing
    radio. Unplug and remove the radio.
    (Figure C)
    5
    Continue to kit assembly.*Note: Refer also to the instructions included with the aftermarket radio.
    Disconnect the negative battery terminal
    to prevent an accidental short circuit.
    Aug 26, 2010 | Pioneer AVIC-N2 Car DVD Player
    Flasher Relay replacement
    The Flasher Relay for the Series 1 Mazda Premacy is situated in the centre of the vehicle behind the Cigarette lighter. To access it you have to remove the central dash surround, radio, CD deck and climate control panel. If you have small hands you can then access the rely to replace it. If you have larger hands expect to find it a little more awkward.
    May 08, 2009 | Mazda MPV Cars & Trucks
    Ac switch light
    Illumination Bulbs — A/C Switch
    Removal
    1. Disconnect the battery ground cable (14301).
    1. Remove the shift console panel. Refer to Section 01-12 for the removal and installation procedure.
    1. Remove the three climate control assembly screws.
    1. Disconnect the climate control assembly electrical connector.
    1. Depress the tabs on the air door shafts and remove the three climate control cable ends. Pull the climate control assembly from the vehicle.
    1. Remove the A/C switch electrical connector.
    2. Depress the tabs on the A/C switch and remove the A/C switch from the climate control assembly.Twist and pull out to remove the A/C switch miniature bulb from the A/C switch.
    Jan 09, 2009 | 1997 Ford Aspire
    Climate control interior light replacement
    You need to remove the console upper panel, and the center inst panel finish. Remove the screw under the middle knob, and the 4 screws behind the upper compartment door. Disengage the 4 clips and the 4 claws. Pull it straight out. Release the 2 claws that holds the heater control to the inst panel. You should now be able to access the bulbs. This should help you; repost if you have any problems.
    Oct 10, 2008 | 2004 Toyota Corolla
    Mercedes 250 d turbodiesel heater case. . air conditioner case with Logo
    35 people viewed this question
    Top Mercedes-Benz Vehicle Parts & Accessories Experts
    Matthew Spark
    Matthew Spark
    Timllfixit
    Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
