Question about Kenwood KAC-5204 350 Watt Max Power Stereo Amplifier with Variable LPF
Kenwood KM-208 150W/chan power amp is dead. Can't find owner's manual to locate the fuse. Can someone tell me where the fuse for this thing is? Where can I download a manual from a safe website? I tested the power cord by plugging in a CD player to the unswitched outlet on back, and it worked. When I tried the switched outputs neither of them worked when I pressed the power button, and nothing happened anywhere on the amp. That's as far as I could get with troubleshooting. The fuse is the obvious next step, but I can't find it. Is it under the cover somewhere?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
Its probably under the plastics near the power cord, itll be a cylindrical fuse.
Posted on Nov 15, 2013
4 Suggested Answers
  • 631 Answers
SOURCE: Amp powers up (switchable) but has absolutely no output
If possible return the amp to the seller for a refund (before you tamper with it).
If that's not possible, the amp will need to be repaired. Do you want to try to repair it yourself?
For the head unit, you need to check the shield ground first. The following page will show you how to perform the test.
Shield Ground Test/Repair
Let me know if you have any other questions.
Posted on Sep 19, 2008
  • 5 Answers
SOURCE: Kenwood KAC-8103D Power Amplifier wont turn on
it sounds to me like its burnt.but with some amps the screws that hold it in place have to be screwed into the car chassisfor grounding. be careful not to srewe into hidden wires.
Posted on Apr 15, 2009
housejess
  • 317 Answers
SOURCE: amp lights up, but no power to outputs.
channels mey be burned....does the amp smell like burnt electronics
Posted on Nov 07, 2009
Where are the Quantum 600 Fuses Located?
Ron,
With a gifted power wheelchair, the usual culprit is a pair of dead batteries usually size 22NF deep cycle batteries. The pediatric chair may have U-1 (35 amp hour batteries) There are fusible links connected to both batteries at the + terminal. There are additional fuses under the rear cover in booted holders in the belly area in the rear near the controller. These power take off harnesses are fused but probably do not relate to your primary dead battery problem. Remove the front cover of the base and pull out the battery tray. Remove the batteries, test, and replace.
The owner's manual can be found here. It also includes basic service. Hope this helps.
http://www.pridemobility.com/pdf/owners_manuals/us_jazzy/us_q600_series_om.pdf
Jul 22, 2016 | Quantum 6000 Power Chair - Used Electric...
HAVE A 1989 TOYOTA UHAUL TRUCK DOES THE TURN SIGNALS HAVE A SEPERATE FUSE OTHER THAN HAZZARD LTS AND IF SO WHERE TO LOOK THANKS TERRY
While it is always better to have the REAL documents...
(from Toyota... reading the OWNERS manual =good start).
BBB industries (plus technical service bulletins, pretty good)... and autozone have "SOME" popular
USA schematic drawings available on line...
Registration required for both...
The best thing to do is get the factory drawings.
Finding the fuses LOCATION: Owners manual:
Without the specific model & year it is difficult to say where your fuse would be... there is TYPICALLY a recess or storage slot between the steering wheel and the door that can be revealed
by pulling off the cover (FORCE NOTHING (read the manual)).
autozone.com drawings & locator
("safety" systems only = marginally acceptable):
Save 20 On Online Ship To Home Orders Of 100 Or More
BBB Industries Premium Alternators Starters Power Steering Products
Jul 10, 2016 | Toyota Cars & Trucks
Kenwood ka 996 integrated amp. The standby light will dont turn off. I also need to see if someone will tell how everything should be hooked up.
the standby light should be on if the unit is not 'ON' if you want the 894 to turn on when you power up the 996, then you will have to plug the ac for the 894 into the 'switched' ac outlet on the back of the 996
what specific problems do you have with this system
Mar 07, 2013 | Audio Players & Recorders
Kenwood KM-209 Power Amp- wont power on
The KM-209 amp does have an impedance switch on the rear & if you are running a high load with multiple speakers connected to both A & B outputs you could be seriously damaging the amp. Look at all your speakers and see what impedance they run on (usually 4 or 8 ohms.) and switch the amp to the corresponding impedance.
Feb 12, 2013 | Audio Players & Recorders
Don't know how to hook up kenwood ka-994
Check the bellow link for the user manual of kenwood KA-994. In page number 4 of the user manual You can see how to make the connections to the receiver
Manual
Ajin
Mar 09, 2012 | Audio Players & Recorders
Kenwwod DPX303 dead, Worked yesterday and today wont power on. Fuses are all OK . Hit the reset button no change. Any Ideas? Rgds R
There may be multiple fuse boxs in your car, you need to make sure to check all of them listed in your owners manual. Checking involves a voltmeter and not just checking the 2 fuses you think supply power to the radio, there may be multiple fuses that supply the necessary power to the radio. Yellow and red at Kenwood need to see 12 volt positive with the key on and the black needs to have ground in order to turn on. If all three have correct voltage then pull the harness from kenwood and check small 10 (red) or 15 (blue) fuse held in and protected by the harness. Good luck!
Feb 28, 2010 | Kenwood DPX303 CD receiver
No manual for my amp.
  • Class-D Monoblock Amplifier
  • Bass Boost Level and Frequency Remote Included
  • Variable Low-Pass Filter: 50 - 200 Hz (24 dB/Oct.)
  • Variable Input Sensitivity: 200mV - 5V
  • Phase Shift: 0° / 180°
  • Variable Infrasonic (Subsonic) Filter: 0/15Hz/25Hz (18 dB/Oct.)
  • High- and Low-Level Inputs
  • 1 Ohm Stable
  • RMS Power Output:
    • 500 watts x 1 chan. @ 4 ohms
    • 900 watts x 1 chan. @ 2 ohm
  • Preamp Outputs: 1 Pair
  • Bass Boost: 0 - 18 dB @ 40 - 100 Hz (Variable)
  • Dimensions: 15" L x 11-5/16" W x 2-3/8" H
Oct 05, 2009 | Kenwood KAC-9152D Car Audio Amplifier
No power to fuel pump fuse 2000 beetle . car won't start,.changed fuel pump relay . No power to either leg of fuse 28, the fuel pump fuse. Can anyone tell me where fuse #2 a 50 amp fuse is located??
Most fuel injected cars have an "impact' switch that cuts power to the uel pump in the event of an accendt. It can trigger if the car has had some sort of impact. It is usally in the rear under a panel and it should be mentioned in your owners manual.
The 50 amp fuse will be in the power ditribution panel, which should also be in the owners manual... Lee
Sep 28, 2009 | 2000 Volkswagen Beetle
The Red & Black wires connected to my AMP touched
You blew the inline fuse on the AMP power wire. If it was not fused "inline" you may have blown a fuse internal to the amp. Look on the amp(or consult the manual) for the location of fuses "internal" to the amp.
May 01, 2009 | Kenwood KAC-7202 Car Audio Amplifier
Kenwood KAC-5204 350 Watt Max Power Stereo Amplifier with Variable LPF Logo
131 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
