Question about Janome Sewing Machines
How to thread a twin needle - Janome Sewing Machines
    Champion:
  • 208 Answers
Thread the machine with two threads as normal, you will find you have a space for the thread to go each side of the tension discs, do not put your stitch width more than two and a half
Posted on Oct 19, 2013
MakikiChris
  • 84 Answers
SOURCE: brother XR65 twin needle threading
hi roscoepc1.....The threading pattern is identical to single needle. The only changes are that you now are threading 2 spools of thread, one thread for each needle. The only change that I reccommend, but not neccessary, is that while threading through the tension dial, lay your threads between separate discs, and not together between the same pair of discs. Your tension dial contains either 3 or 4 discs.......please update your post if you have any further information or questions.....good luck my friend
Posted on Aug 05, 2007
Mimito7
  • 128 Answers
SOURCE: howto thread a twin needle on Janome 6019
Hi there. If you have an acessory kit with your machine, there should be a plain spindle with a smaller bottom on it. There should also be a small hole on the top or back of your machine where your thread goes.. And yes you can thread both strands of thread thru the same areas till the needle.
Posted on Apr 28, 2009
  • 7 Answers
SOURCE: how do you thread a brother pacesetter 6000 for
Two reels of thread on the top,make sure the threads go seperate sides in between the tension discs, thread both needles but remember not to put the stitch width more than 2.
Posted on May 06, 2009
  • 161 Answers
SOURCE: how do I thread the machine using a twin needle?
its basically the same as a normal needle, but nearest the needle most machines have a way to divide the thread before the needle hole. Some machines have a left and right thread guide a couple of "steps" before the needle, but at some point they have to travel together, and this doesn't seem to be a problem. Make sure you lessen the tension as there is still only one bobbin thread, and triple check the needle is in the middle and that you are on straight stitch or you might break it!
Posted on Sep 14, 2010
chris592
  • 86 Answers
SOURCE: I need instruction and project manuals.
You can find it here:
http://ifixmachines.com/index.php?page=shop.product_details&product_id=687&option=com_virtuemart&Itemid=54
Posted on Nov 16, 2010
Can I use a twin needle on a Singer Trafition? It seems to only sew one line of stitches.
Probably depends on the model. Was a twin needle included with your starter kit?
This one indicates it will take a twin needle:
2277 TRADITION
Your owner's manual or the product specifications are probably the best source for information.
Instruction Manuals
BTW, you are using 2 spools of thread, right? You need to thread both needles with separate spools (do not twist the threads when threading!).
Double Needle Tips Video Demos
How to Use Twin Needle on Your Sewing Machine
Be sure to verify the machine is set to straight stitch. Any zig-zag could break one or both needles!
You also will have to thread the needles manually as the needle threader will not work on twin needles.
ALWAYS RAISE the presser foot when threading the top thread!
Jun 22, 2017 | Singer Sewing Machines
Thread breaks on the 2340CV Brother. Doing two needle and the right needle is breaking at the needle. Change needle and retreaded several times
Probably depends what that needle is hitting that is causing it to break. Make sure the presser foot and the needle plate hole are large enough to accommodate the twin needle. Twin needles come in different widths so if yours is too wide, it would break. However, it could be possible that your machine is slightly out of alignment that does not show up until you try to use a twin needle. Also, make sure that your thread is not causing the needle to break--could be misthreading. Some machines have separate guides and tension disks for twin threads. Those that don't have that accommodation may have more difficulty using a twin needle.
Mar 07, 2017 | Sewing Machines
I just need instructions to thread a Bernina Virtuosa 160 for pintucking
Your owner's manual should have instructions for using a twin needle.
Most machines can use a twin needle. However, some machines have two tension disks so one can separate the two threads and get equal tension. (The Bernina 930 has two tension disks, so am assuming your newer machine does also.) Look at the top of your machine where the tension mechanism resides and see if there is a right and left side. In either case, do NOT thread both threads at the same time as the threads can become twisted. When threading the machine, ALWAYS RAISE the presser foot, thread one thread completely. If threading the left side of the tension disk, also thread the left needle. Then thread the second thread, making sure to use the other side of the tension disk and needle.
Just a reminder to be careful using any zig-zag or decorative stitches since a twin needle requires a narrower stitch width to avoid broken needles.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&ved=0ahUKEwiawf-507_RAhVHwlQKHQrnAXgQFgg4MAQ&url=http%3A%2F%2Fwww.itsastitchonline.com%2Fmastery_on_the_web%2Fmastery_153qe_163_1-4-02.pdf&usg=AFQjCNHHww3jbxbLXZYNj6vuCZE4-kVa8g&cad=rja
Stitching Odyssey How to use your twin needle
How to use twin needle So Sew Easy
Bernina Instruction Manuals
Jan 13, 2017 | Bernina Sewing Machines
How to use a twin needle on my SR2000 toyota sewing machine
First, verify that your machine can use a twin needle. Most machines take will use a twin needle will have separate thread guides and duel thread spool pins.
To thread it, thread one thread all the way through one of the needles and then thread the second thread through to the second needle. This will help keep the threads from twisting.
Toyota RS2000 Instruction Manual
Aug 25, 2016 | Toyota Sewing Machines
How to thread with double needle
You'll need to use two separate spools of thread. Machines that take a twin needle will usually have separated thread guides and two separate tension disks. Just make sure the threads are not twisted when threading. Might be better to thread one all the way through and then thread the second.
How To Use Twin Needles
Be sure to check the width of your stitch when using a twin needle. Because the needles will be wider than a single needle, it is very easy to hit the needle plate if setting it too wide.
Jun 11, 2016 | Elna 1010
How do I thread my twin needle on my SQ9185 machine correctly so as not to break the needle again. The diagram in the manual is a little "sketchy".
with twin needles
you thread the first needle like you would a single needle and then you thread the 2nd needle then same way
make sure the setting are fixed for a twin needle
Feb 28, 2015 | Brother Sewing Machines
Thread a twin needle
The same as a regular needle a twin goes in the same. it has only one stem 8_29_2014_5_48_42_am.jpgnotice above the read is on stem this goes into the same area as a regular needle.
Jul 03, 2014 | Janome Sewist 625e
Would like to know how to thread a twin needle on a Pfaff 7570
put the twin needles in the needle holder and then thread the first
needle like you normally would then add a second spool or cone
of thread then thread the machine the same way you did with the first
needle and then thread the second needle
Jan 27, 2013 | PfaFF Creative 7570
Sewing Machines Logo
163 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
