Question about Kenmore Vacuums
Front end wobble - Kenmore Vacuums
    Sergeant:
    Champion:
  • Kenmore Expert
  • 357 Answers
Weebles wobble but they dont fall down ...... ( you didn't give enough details if you want help with a problem )
Posted on Oct 21, 2013
The main belt on my hoover model u6634-900 windtunnel keeps comming off the motor shaft
  • A list of things to check (unplug vacuum FIRST):
    1. All contact surfaces for belt are clean of build up, that can push belt in one direction
    2. Brush roller is not flip end for end (the pulley on the motor shaft should line up straight with the worn area of the brush roller).
    3. The guard on the bottom (covering the belt and brush sides) is clean and free of build up.
    4. The ends of the brush roller are free of build up and the bushings that slide in the end are inserted in the correct direction, this can cause the brush roller to set at an angle and cause the belt to slide in one direction.
    5. You have the correct replacement belt, I have found the wrong belt placed in the packaging for my vacuum at the factory once before (check manufacturers website).
    6. If the brush roller is extremely worn, it could be time to replace but this is very unlikely.
    7. Rotate the motor shaft by hand and see if there is any wobble, the pulley could be on crooked or bearing has failed causing slop in the motor shaft.
Jun 21, 2014 | Hoover Vacuums
Tubes falling apart, wobbly attachments - brand new Henry
Unusual, but try cleaninig the connections with a drop of white spirit or meths. also when putting the connections together give it a little twist as you push it together.
May 29, 2012 | Numatic Henry Bagged Canister Vacuum
My fan is installed and it wobbles it is anchored properly from the box but the pole has a little play from the top not tightly secured The eletrician had to change the downrod was is on the fan at the...
Hi marilynh57....
Try removing the fan blades and putting them into different positions.
This will sometimes solve your wobbling problem as some fan blades are heavier than others and this causes the wobble you experiance.
Please take time to rate me
Aug 17, 2011 | Vacuums
When I use my mixer it wobbles. At first I thought I didn't have it locked down, but it was and still bounces as if I was kneading dough. What do I need to do?
not sure about the wobbling discription,but make sure that your unit is sitting on allpoints of contact
Then make sure that all pats are tight and secure
Jul 09, 2011 | Vacuums
My Miele S558 vacuum stops working about every 20 seconds (it used toi be every 45 secondsor so) I was told its probably a contact problem, and a replacement hose seems to be the resolution.
Make sure your bag is not full and your filters are clean and unblocked, could be over heating, hence cutting out.
Also test your mains lead, wobble it when its on at the plug and the body end to see if ts cuts out
Sep 28, 2009 | Miele Vacuums
Majestic filter queen vacums
Your belt is either stretched or the wrong size or the brush bushings are worn and allowing the brush to wobble or the motor is loose in its housing. You need to check all.
Rotate the brush and try to wobble it from the pulley end.
Flip the belt inside out, it if appears cupped, cracked or shiney and slips easily on and off the brush it is stretched. Generally this unit needs anew belt evrey 6 months, broken or not, they get hot and stretch. Do not buy a new belt by matching size, a worn belt can be 20-30% oversized and not broken but totally useless.
The motor shaft should be cleaned with W/D 600 grit sand paper. Motor should have no wobble in the shaft
Sep 09, 2009 | Vacuums
How do I change the belt on my vacuum
Turn the carpet head upside down and look for visible screws at the front edge of the bottom plate. Inspect for others further back .Once removed the plate should hinge forward and separate from the base.
Clean burned rubber from motor shaft and spin brush roll when replacing belt to check for wobble or hair and fibre wound in to ends of brush.
Sep 05, 2009 | Vacuums
Hoover Wind Tunnel 2 Making Noise While Operating
sounds like your brush roller bearings are going bador cloged up with carpet strands if you can take the bottom open and remove the brush roller look at the ends and see if you see any melted plastic or see if the ends feel loose like wobble back and forth.once you take the roller out turn the vacuum on and see if you hear the same noise.also check the belt and see if it looks burnt on the inside of the belt. and does it look stretched out .the belt might be stretched out and fluttering when running.feel free to cal me and maybe i can help you further with it.i'm not one of the techs .i'm just trying to help people.i don't charge for my advise
Apr 05, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover u8147-900 upright vacuum
Either the brush rolls are bad, at the ends, or the gear/motor asm. is bad.
Dec 29, 2007 | Hoover U8147-900 WindTunnel V2 Bagless...
Vacuums Logo
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
