Question about Scotts Company Scotts Turf Builder Classic Drop Spreader 73730
Need the guage scale to set the flow of the fertilizer
Why should you go for a gynaecology clinic for your fertility treatment. Which is the best fertility and gynaecology clinic?
At first, let me answer about your last question i.e., Which is the best fertility and gynaecology clinic?
I would like to tell you about the best fertility clinic with highest success rates and the best team of doctors from around the world. Fertility Clinic London. You should definitely go for the fertility clinic if you are facing some problems related to your pregnancy. The fertility clinic in London offers a state of the art of IVF laboratory providing patients with the highly advanced care in the safest and most comfortable of settings.
At there clinic they ensure the continuity of personal care by the same consultants throughout the treatment.
Sep 21, 2016 | Health & Beauty
What is In-vitro fertilization?
In-Vitro Fertilization (IVF) is a procedure that involves surgical removal of an egg from the woman's ovaries and fertilizing it with the laboratory. The fertilized egg or embryo is then placed back into the woman's womb to grow and develop.
Indications of IVF :-
  • Originally designed for treatment of women with blocked Fallopian tubes.
  • Endometriosis and pelvic adhesions.
  • Ovulatory disorders.
  • Sub-optimal parameters.
  • Unexplained infertility.
For more information regarding the IVF treatments you may check their official website :
IVF Clinic London
Sep 19, 2016 | Health & Beauty
I have scott drop spreader and I want how it will setting for fertilizer
Check the fertilizer bag for instructions. It will tell you the number to set it at for a drop spreader and a broadcast spreader.
Aug 14, 2011 | Scotts Company Garden
I know it uses r 22 but what should the low side presure be
This depends on the outside temp . But a suction pressure of 55-65 is good. If you are using a set of guages and you read the outside of the guages scale you will see a temp scale you need to have the suction pressure set to about a 40-45 degree temp on the scale. Be certain that you purge a bit of gas when hooking up your guages or you will allow iar inot your system and it will make matters worse.. Hope this helps let me know.. Jon
Aug 01, 2011 | Heating & Cooling
I have had my Rinnai tankless for about 8 years without problems. Recently I am noticing that the water temperature is fluctuating from the set temperature to a cooler temp and then back up to the set...
The Rinnai will shut off it can't maintain the temperature you have set to within +/- 3 degs so I'd guess that might be the problem. The cause can be a few options. Check water flow first; any filters you have in tapware, main water flow etc. get cleaned. The Rinnai has a water line filter in the incoming supply, middle pipe under the heater just after the isolating valve. Gas supply could be the other option mainly being a possible intermittent fault in the gas regulator. Hard to check this one short of just changing it. Final option is some sort of electronic malfunction, pretty rare. I'd start with the water flow issue as you can do this yourself. Checking the gas will need a good technician with digital gas pressure guage to check incoming and working gas pressures; it might just need to be recalibrated. Just hasd a thought about the heat exchanger being scaled up if you are in an arera where water scale is a problem but this would normally take far less than 8 years to be a problem. Sorry can't be of more help; hard when it might be a few different causes.
May 28, 2011 | Rinnai Water Heaters
I have lost my instructions for my hand held spreader. The numbers on the side that control the outlet of whatever is in the spreader--do these indicate the number of pounds per 100 sq. ft?
Below is a list of spreader settings. You may want to call Scotts at 800-543-8873 and verify the product you are using is able to be used in a hand held spreader.
  • For fine grass seed (blue, rye, fescue) use setting 1
  • For coarser seed (tall fescue) use setting 2
  • For light fertilizer (Scotts fertilizers at a regular rate) use setting 3
  • For heavy fertilizer (Scotts fertilizers at a heavy setting) use setting 4
  • For pelletized fertilizer and ice melt products use setting 5
Hilary @Scotts
May 16, 2011 | Scotts 71133 Handgreen II Hand Held...
Heater not producing enough heat. How do I determine the difference between poor exchange from the heater core and a faulty thermostat without throwing my money in the wrong direction. At idle the engine...
temp should stay about half while driving sounds like you have a bad thermostat if guage is half way at idle do you have heat feel both heater hoses should be about same temp if one is cooler not flow coolant
Jan 19, 2010 | 1988 Volkswagen Jetta
Have air conditioner that freezes up after setting it on the lowest setting. checked the freon on the unit and the suction pressure was at 42 on the 22 scale & about 70 on the psi scale, low side. no...
if it's freezing up, chances are the freon is low, but read the info on the panel near the taps or the compressor to find out how much you should have. you need r-22 (if that is what it takes), guages, a thermometer for dry and wet, a temperature sensor for the tubing, and an epa license for moving freon. and there has to be a high side tap. the lower the pressure, the lower the temp, but if the temp after the metering device is below 32 f, it'll freeze. also if the condensate drain is clogged and the air flow across the evaporator coils is restricted.
Jul 30, 2009 | Whirlpool Heating & Cooling
Flow control lever doesn't open hopper door
your fertilizer is got clumps in it. I have experienced the same when using TSC fertilizer (cheap and wet).
Mar 22, 2009 | Agri-Fab 175lb Agri - Fab Tow Broadcast...
Scotts Company Scotts Turf Builder Classic Drop Spreader 73730 Logo
32 people viewed this question
Top Scotts Company Garden Experts
john h
Nick Olsen
lnbn1975
Are you a Scotts Company Garden Expert? Answer questions, earn points and help others
