Question about AEG Washing Machines
Error code e59 - AEG Washing Machines
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: Kenmore Super Capacity 3.5 error code E59
see the error code E59= E59 equals no tachometer signal for 3 seconds.
This means that the motor is not signaling to the washer normally and may be caused by a variety of failures within the motor, basket or the control board. Generally speaking, the E59 error requires the service of a Frigidaire professional for resolution due to the technical nature of the ERROR.
God bless you
Posted on Aug 02, 2012
GLTF2940ES3 - Frigidaire Front load washing machine e59 error code
http://www.ehow.com/info_12127418_frigidaire-gltf2940fs1-not-spin-error-e59.html
May 02, 2014 | Frigidaire GLTF2940ES Front Load Washer
Error code e59
E59 is not a normal code on Bosch dishwashers.. Can you specify a model?
Apr 08, 2014 | Bosch Dishwashers
FAFW3801LW3 has error e59
Hi Rosie,
I understand that you're receiving an E59 error code on your Frigidaire washer, model# FAFW3801LW3 and are looking how to run the diagnostic test. While there isn't too much information about actually running the diagnosis, I would recommend contacting the manufacturer and seeing if they are able to assist.
-Best Regards-
Jan 23, 2014 | Frigidaire FAFW3801LW Front Load Washer...
What e59 means
Hello Ninemi,
I see that you are receiving an E59 on your Frigidaire Affinity washer. E59 states that "No Tacho" Signal for 3 seconds. I would recommend giving the appliance a hard reset. You will do this by either unplugging it or switching the circuit breaker off that the washer is attached to. When you do this you will want to leave it off for 3-5 minutes. Once the 3-5 minutes has elapsed, bring power back to the washer and try to restart it. If you are still receiving an E59 error code, I would suggest contacting your local authorized technician to diagnose and see why you keep receiving this error code.
-Best Regards-
Jan 22, 2014 | Frigidaire Affinity FAFW3511K Washer
Frigidare errow code e59 display
Hi Emily,
I see that you are receiving an E59 on your Frigidaire washer. E59 states that "No Tacho" Signal for 3 seconds. I would recommend giving the appliance a hard reset. You will do this by either unplugging it or switching the circuit breaker off that the washer is attached to. When you do this you will want to leave it off for 3-5 minutes. Once the 3-5 minutes has elapsed, bring power back to the washer and try to restart it. If you are still receiving an E59 error code, I would suggest contacting your local authorized technician to diagnose and see why you keep receiving this error code.
-Best Regards-
Jan 21, 2014 | Frigidaire Washing Machines
Frigidaire E57
Hello Daniel Huntley - Typically error code E59 indicates that that washer is not detecting a tacho signal for about three seconds. Contact a professional to move forward accurately. Certified technicia will need to remove the belt from the motor, spin the motor pulley, diagnose the speed control board and etc.
Jan 07, 2013 | Frigidaire Affinity ATF8000FE
God bless you
Aug 01, 2012 | Kenmore 3.5 cu. ft. Front Load Electric...
I am getting a E59 and the drum won't spin
E59 is a fault code , check your user manual for code explanation , but no spin is often related to no /or insufficient drain stage , generally caused by drain filter blockage or pump failure . Check , clean and replace filter + try again .
Nov 03, 2009 | Frigidaire ATF6000ES Front Load Washer
E59 Error on Frigidaire front loader - won't spin
I finally solved this same problem on mine error code E59 and the main symptom of the drum never spinning even right at the beginning of the load cycle. I did Test 12 based on the following link: (MAKE SURE THE POWER CORD IS UNPLUGGED TO THE MACHINE)http://manuals.frigidaire.com/prodinfo_pdf/Webster/134542000.pdf. I found that the motor was fine which meant the problem was with the speed control board. On my speed control board there are 3 locations that connectors plug into it. Make sure these are all firmly connected. One of the three is a very weak press fit connection clamping over the edge of the circuit board. This had wiggled loose on my machine from all the dancing across the concrete floor in the basement this machine does. I pressed this connection in firmly, put everything back together and it started working like new!
Good luck.
Jon
Sep 25, 2009 | Washing Machines
1988 cadillac eldorado engine code e59
code e59 is a vcc temp sensor circuit problem detected. does the cruise work? I would have to research this curcuit if you require further assistance. It has been a while since dealing with those cars.
Aug 31, 2008 | Cadillac Eldorado Cars & Trucks
Washing Machines Logo
82 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
