Element 46" ELDFW464 We cannot get our picture to adjust to were you can see the entire picture. The zoom, standard, etc., is not the problem. We do have a pop up box upon tv powering on saying lost hdcp connection? How do I fix this problem
SOURCE: Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
Posted on May 30, 2008
mistersony
  • 320 Answers
SOURCE: Cannot view the full picture
First, you have to tell me how the cable box is connected to the TV, by HDMI or component. If it is connected by HDMI, the cable box settings will override the picture size settings on the TV. It may be as simple as resetting the picture size on the cable box, but I am not familiar with the type of cable boxes that Comcast uses.
Posted on Oct 19, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: rca 46 inch lcd tv, no sound
Go into the menu and change the HDMI Audio settings - the manual will give you a breakdown on this. HDMI is a little glitchy - if you were using red/gree/blue cables before switching to HDMI, you might want to consider going back to them - just an opinion.
Posted on Jan 03, 2009
  • 210 Answers
SOURCE: lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
Posted on Dec 12, 2009
Testimonial: "Your response was quick pointed me in the right direction I might need help with ID of components to continue"
  • 8457 Answers
SOURCE: Black shadow boxes on 46 in Samsung 46 in LCD HDTV.
Ur backlight video board is dying,must replaced to solved this problem.Part and labors about $500.
Posted on Dec 15, 2009
My Element Electronics 46" LCD tv model ELDFW464 has sound but no picture.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 21, 2017 | Element Electronics Televison & Video
How do you adjust tv picture to fit entire screen
If you are connecting a computer to your TV and you are seeing the edges cut off it is most likely due to the zoom on your TV. First, make sure that your computer matches the resolution on the TV, then go into the TV menu and find the screen sizing setting and make sure it isn't set to stretch, zoom, etc.
Feb 07, 2016 | Televison & Video
I have a 70" element TV bought used no remote how do I get the DVD player to work? What channel ??? tv av component etc.....
How do I hook up my tv,dvd player,vcr, and cable box?
askville.amazon.com > Entertainment > Television
Dec 3, 2009 - Recent Questions About: hook tv dvd player vcr cable box · Entertainment > ... Exclusive Coupons To Get 30% Off ... Check the back of your TV to see which type of hookups are available and use the appropriate cables.
Element 46" Class LCD 1080p 60Hz HDTV, ELDFW464 ...
www.walmart.com/ip/Element-46-Class-LCD.../17188433
Walmart
Rating: 4 - ‎190 votes
The Element 46" 1080p HDTV features a brilliant full-HD picture for your viewing ...ShippingPass. H&R Block Tax Software 15, Deluxe + State. $34.70 .... I really cant stand having to use another remote...thats the point of having a .... Just a regular DVD player and it works perfectly fine with the TV. ..... Get to Know Us.
5 Easy Ways to Hook Up a DVD Player (with Pictures)
Jan 10, 2016 | Televison & Video
Can,t get a normal picture on screen all I get is a zoom picture
You will need to get into the tv's menu and change the "settings" area under display properties to read "normal" instead of "Zoom". Change that and you will be back to being able to see the entire display.
Good Luck
Rich Lilja
Sep 20, 2013 | Sony KDL46EX400 46 in. HD-Ready TV
RCA entertainment series TV does not show the entire image
Check the picture settings. It sounds that the picture settings to TV is Zoomed.
May 29, 2012 | Televison & Video
The vertical screen cannot be adjusted. Watching football games the score cannot be seen at the top of the screen. changing vertical center and vertical size has no effect
You question shows its Sony KDL-46S2000 lcd tv so adjust screen format like zoom etc to adjust picture size best fits in screen.
Screen format option is available in Menu.
Dec 06, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
The pictures zoom beyond screen hence cutting some words/pictures when on video input mode, otherwise it is ok with tv mode!
hi and thank you for reading my input. i would go to my menu screen and try to adjust my zoom. i would also see what mode it is on such as cinema,natural,etc. this should solve your problems. thank you and please rate my solution.
Nov 17, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony 46" Rear Projection HDTV Bad Picture
Hello, I also have the kp53xbr45 and I am looking for a red bulb, where can I find one at a good price? Thanks
Feb 09, 2008 | Sony KP-53XBR45 53" Rear Projection...
I cannot reset the picture to Normal (which should fill the entire screen). f
on what dvd player also has zoom mode set it at 16.9 on all units once no zoom in or do u use dish hd page up down will adjust size also
Jan 31, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Sharp 32lf-92h picture problem
Any ideas on this problem?
As i have it now.
Oct 19, 2007 | Televison & Video
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
