Question about Sony STR-DE915
Have a str-d915 receiver. powers on but no screen display and no sound. anyone know what this could be. really like to try n fix it myself if possible.
4 Suggested Answers
SOURCE: STR DE435 PROTECTOR STR DE435
I have the same problemwith mine. the protector sign is on- I do not know why- and do not know what to do about it. Let meknow if you do or if you get assistance and I will do the same. My e-mail address is 1971CJS@Bellsouth.net
Posted on Feb 28, 2008
SOURCE: error 12 message on my sony multichannel av receiver str dg 510
error 12 is what you get if you autocalibrate and do not have the microphone attached.
Posted on Jan 01, 2009
mjjdesigns
  • 98 Answers
SOURCE: PROTECT DISPLAYED ON RECEIVER
This generally means you've got a short somewhere, and the received is trying to protect itself.
My suggestion is to disconnect all of your speakers at both ends, and reconnect them.
Most times this happens because a speaker wire is lose, and the positive and negative connections are touching each other, causing it to short out.
Posted on Mar 25, 2009
Sony str d915
Hi,you possibly have a faulty left speaker
Nov 02, 2013 | Audio Players & Recorders
My STR-DE345 has no sound from the center channel, and has not had it for quite some time. Any easy fix/diagnosis? Is there a part I can buy and replace myself?
The center channel on this model uses its own amplifier circuit that is independent from the others. It is usually a 5-9 pin IC attached to the heatsink. It is likely that this IC is defective and needs to be replaced. Unfortunately, I can not know this for sure without taking measurements inside the unit. There is no simple fix for this although this is an easy repair for a service shop. Please seek professional assistance to resolve this. Expect a parts cost in the $25 range.
Dan
Jan 13, 2011 | Sony STR-DE345 Receiver
Sony str-de845 powers on, relay clicks sound works for a few minutes then relay clicks again and sound stops. display stays on.
Hi there, can anyone help me? i cant seem to get my aiwa-d58 to get out of eco mode. no power, red light is on and every time i press the power button; the eco light clicks off and i no power supply to the whole unit. please help!
Jan 22, 2010 | Sony STR-DE845 Receiver
Only one speaker working on my str-de675 receiver
check your main board witch is under the powersupply. careful the caps hold charge and hurt really bad. check your digtal input board also.
Jun 02, 2009 | Sony STR-DE675 Receiver
Sony str de405 receiver...was working fine, now no sound
I have a problem with vintage reciever Sony STR-11L. Power transistors were replaced and I dont know what were original ones. Sound is no good and radiator is hot-I think problem is in replacement. Can anybody help me with?
May 14, 2009 | Sony STR-DE405
How to hard reset a sony str-DE898
I couldn't find anything about a Lock Code in the manual but here's the general setting-reset procedure:
Turn OFF the receiver
Hold down the I/0 for 5 seconds - "PUSH ENTER" appears on the display
Press ENTER
Apr 08, 2009 | Sony STR-DE898 Receiver
No Video or Audio on HDMI on Sony STR-DG800
The sony device may not be able to support the Toshiba. Make sure that is completely compatible and that you have the correct cables and setting to support everything.
Dec 31, 2008 | Sony STR-DG800 Receiver
Str-da777es
I know I'm 18 months late answering your question, but unfortunately I have the same problem. My son kept shutting my on and off same as your daughter. It blew the amp board that obviously powers the amps. Sad news is Sony stopped making the board, so there is no fix. Really bites, I loved that receiver!
Jul 29, 2008 | Sony STR-DA777ES 6.1 Channels Receiver
STR-DE845
I have this receiver and my audio is a optic cable to my cable box. When I play a dvd my sound works great my I can't watch cable. There is no sound. It has always worked untill I finished a movie and tried to switch to cable and then there was no sound. Can anyone help?
Nov 23, 2007 | Sony STR-DE845 Receiver
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
