Question about Drills
Bosch 11230evs rotates even when set on hammer only
    Champion:
  • 304 Answers
Could be the pin on the selector lever has bent or fallen out.
Posted on Feb 03, 2014
2 Suggested Answers
comax
  • 154 Answers
SOURCE: Bosch rotary hammer (model # 11230EVS) drill will not rotate
There is a clutch in the main spur wheel of the unit. These sometime begin to slip, on rare occasions they will slip to the point where the drill will not rotate. If you are interested the part number for this clutch is 1617000817.
Posted on Aug 06, 2009
The selector knob broken,how to remove it
There are different knobs the old models have a knob they must jumped out but there are rotary hammers and drill hammers they have a red button in the knob that must push in and rotate clockwise setting to the end of it rotate hammer or 1 further only hammering and then push the red button more then normal with something and turn a little more further until its end and pull on the knob and feel it comes free.
Dec 27, 2015 | Bosch Drills
Hammer drill won't hammer
Without knowing which model you have: Most Bosch hammer drills use a plastic connecting rod to attach the piston to the rotating spindle. These are a common failure item and fairly easy to replace.
Jul 18, 2012 | Bosch Drills
How to take apart Bosch 11230EVS to replace hammer piston
How do I replace the brushes in a boschhammer 11230evs?
Mar 02, 2012 | Bosch Drills
Bosch 11230evs only runs when turned sideways
I would guess it is either a safety feature or a defect. I can imagine the tool could be engineered to stop turning when it is being set down on a surface. If so, then the sensor must be installed backwards and the tool is off when it is upright.
You should easily be able to Contact Bosch online or by phone. Sometimes stuff is overengineered and it allows for more mistakes.
Dec 04, 2011 | Drills
Runs but doesnt engage rotary or hamer. the machine itself looks in great condition its called bosch buldog extreme.
there is a selector knob on the side that controls the tool functions for drill only/hammer with drill/ and hammer only. make sure it is in the proper setting. If it still doesn't rotate then you have a gear or a broken selector. If no hammer then you have worn o rings or a stuck ram. try the selector first and if still no change please be more specific if no hammer at all, or no rotation even when selector moved.
Mar 03, 2011 | Bosch SDS-plus BULLDOG Xtreme Rotary...
It won't rotate. It only hammers.
The 11316 Demolition Hammer is made to hammer only, it does not rotate the bit. It is for demolition with pointed bits or flat and scraping chisels. If you want to drill holes in cement you need a rotary hammer drill.
Dec 23, 2010 | Speed Bosch 11316evs Variable Sdsmax...
How do you remove selector knob on bosch 11255vsr
Rotate the selector to the 4 to 5 oclock position, or the 7-8 oclock postion, push the red button in all the way with a screw driver and pull the knob out. Certain model hammers you have to rotate to a slightly different position to remove the selector, you will have to try one, if it doesn't work try the other.
Dec 02, 2010 | Bosch SDS-plus BULLDOG Xtreme Rotary...
Jun 16, 2009 | Bosch 11247 Factory Reconditioned 1 -...
I have a bosch rotary hammer 11245evs and it was working when i put it away in its case, now it will not hammer. Drills ok. larry
They are filled with a special grease that comes from Bosch. It sounds like the impact bolt or the striker pin in the unit are not moving the way they should. These are the pieces that work together to create the hitting action. About all that can be done now is the unit has to be dismantled to get those to pieces moving again. Bosch makes what they call service packs for all thier hammers. They have all the o-rings and grease to get your hammer working again. A Bosch service center can supply you with the kit. Ask for P/N 1617000225, or they can take care of it for you.
Hope this helps
Apr 16, 2009 | Bosch 11241EVS SDS-Max Rotary Hammer
Bosch 11222EVSG hammer drill not turning
Couple things to look at, First is the selector in the hammer/rotation mode? Without a bit in it does the collar turn when in the rotation mode. Are you using the right bits for this tool. If yes to all of these I would look down the spindle and make sure that the pawl are in place (they lock to the bit for rotation) Let me know and we will dig deeper.
Mar 06, 2009 | Bosch 11222EVSG 1 1/8 Inch Grounded Sds...
Drills Logo
107 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
