Question about Maximatic Elite Platinum 8qt 13 Function Pressure Cooker Blue
It won't turn on. When You plug it in the cooker will not turn on.
When I plug in my pressure cooker in any working outlet the pressure cooker does not light up or turn on.
When the house breaker pops, that usually indicates a shorted heat element. The electronics inside may have a protection fuse on the board that blew too. Look at your warranty card for instructions on returning it for repair if the warranty is still in force.
Mar 20, 2017 | Crock Pots & Slow Cookers
I have an all-clad slow cooker that won't get any power
Oh thats a pitty these things happens all the time. These devices working under high temperatures, working once and then turn off until the end of time. Advice you to send it to service if you have guarantee. Else somebody with technical knowledge must check where the problem is by using a test light first then treatment begins.
Nov 05, 2012 | All-Clad 99009 Stainless-steel 6-1/2 Quart...
All clad slow cooker won't heat up.
I tried to locate the manual with google, and had luck to find this page, they have the manual!
Enjoy my help.
Sep 20, 2012 | All-Clad (HCOF8H2MZQ) 65Quart Slow Cooker
My cooks essentials technique pressure cooker will not turn on. It's like no power is reaching it. I've plugged it into outlets, but it won't turn on.
I had no power on my cepc800. Since parts are not available I had my husband tear it apart. If you are not electrically inclined don't try it....the problem in mine was a high temp resistor, which was bad. The problem was solved with a $2.50 resistor from our local electronics store.
May 21, 2012 | Select Brands Crock Pots & Slow Cookers
I can't get my 17quart pressure cooker to seal. I was looking for an online manuel so i could find out why.
Take the rubber ring out of the lid.
Wash it with warm soapy water.
Dry it.
Oil it with vegetable oil.
Now do you see how the rubber ring has a groove around it on the inside? Push your thumb into the groove and work it around the ring, you're trying to spread the rubber V out.
Put it back in the lid and take it for a test run.
In the future store your cooker with the lid upside down on top, keeping it closed will ruin the seal.
If it still won't seal replace the rubber parts, you can get a kit for your cooker from presto.
Regards
TickMagnet.
Aug 08, 2011 | Presto 01282 Aluminum Pressure Cooker Slow...
I do NOT know how to use i.e keep at pressure without burning stuff. This is my daughter's Sambonet pressure cooker, it has a strange looking style of lid lock down that is part of the pressurisation...
Pressure cookers rely on pressure and steam,
Do a dry run first...well not dry but with just water, (no food) especially if it's an old cooker.
Inspect for cracks or pinholes before you go ahead, a crack ANYWHERE in a pressure cooker makes it a bomb...or a flower pot.
Ensure all safety devices like the pressure regulator and blow out plug are in good condition and not plugged.
If some previous owner replaced the blow out plug with a bolt or something silly don't use the cooker till it's repaired.
Bring your pressure cooker slowly up to pressure over medium heat with an inch or two of water in the bottom.
When it starts to vent steam turn the heat down so the steam barely escapes, if it has a rocker weight it will wobble a couple times a minute.
Slow gentle heat is the trick. A cooker will run for hours like that without boiling dry.
A couple tips, use salt and spice sparingly, it's trapped in there and permeates the food.
Be careful with foods that expand on cooking like rice and dried things, they can get up and block the vents if they reach the lid.
TickMagnet
Jul 22, 2011 | Presto 01282 Aluminum Pressure Cooker Slow...
My Wolfgang Puck pressure cooker shows 'E4' in the display.
There doesn't seem to be any legit way of fixing this. I tinkered with the pressure sensors and valves, kicked the pressure cooker a few times, still the E4 error presented itself.
I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this.
The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook.
Pics of process:
http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
May 10, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
This is ridiculous. I just want the manual for the corningware sc 60 slow cooker so I can print it out. Why all the runaround. This should be simple
1. Turn off and unplug the slow cooker first.
2. Plug it in, but (yes, I know this sounds crazy) DO NOT turn it on.
3. Set your cook time and it will automatically set the temperature based on the cook time.
he The magic number is 7. Anything set for less than 7 hours will be cooked on high. Selecting a time more than 7 hours will result in cooking on low. Once the cook time has expired the cooker will automatically switch itself to warm until you turn it off. Follow these steps and you should be able to enjoy your cooker again! I don't know who was in charge of this type of setup for programming but they should be demoted at least - no wonder there are so many questions online about this one. Sure hope this helps you!
D
D
Nov 29, 2008 | CorningWare SC60 Slow Cooker
Maximatic Elite Platinum 8qt 13 Function Pressure Cooker Blue Logo
282 people viewed this question
Top Maximatic Crock Pots & Slow Cookers Experts
charles
Irene Tulloch
Are you a Maximatic Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
