Question about Kohler K-3360-G Revival One-Piece Toilet With 12" Rough-In, Seat, Cover, Br
How to adjust the water level in kohler 84679-aa
4 Suggested Answers
miket756
  • 2702 Answers
SOURCE: Can't adjust flush time for complete flush, low bowl water level
flush time depends on how much water is in it,
the water level flote has an adjuster on it, but i cant rember were it is,,, sorry
Posted on Oct 24, 2009
  • 159 Answers
SOURCE: i have a Kohler dual flush and it doesnt seem to
order a water pump. so the preasure of the water can suppy the requirements pressure of your water closet
Posted on Jun 26, 2010
SOURCE: The water level is too low in my Kohler toilet
check the (white) tube in the tank. it should connect to the top of the black reservoir. mine came loose and had the same problem. you can check the diagram on the inside of the tank lid.
cheers
Posted on Jan 27, 2011
I have a Kohler dual flush cartridge toilet and on small flush there isnt enough water being released to wash any paper away. We have two toilets like this and one flushes much more than the other. Can the...
not really as the flush time is set by the manufacturer in the design
what can be adjusted is the water level in the cistern
the more water , the longer the flush before the reset ( shut off)action is activated adjust that by the float screw ot water level adjust screw on the inlet stem
Feb 27, 2015 | Kohler Home
My kohler toilet does not have a ball Just a chain form the handle to the flap with a sponge type ball in the middle of the chain.How do I adjust it so I get more water flow when I flush
Adjust the water level in the tank. If the ballcock is float is horiz. adjust the screw on top (counter-clock wise to raise water level in tank) if the ballcock is vertical, adjust the water level by sliding the clip on the side.
Oct 30, 2014 | Home
How do I adjust FLOAT VALVE in a Kohler San Martine toilet tank ?
On the fill valve float there will be either a plastic screw or a metal bar with a metal slide clip on it. If its a screw, use a screwdriver to turn it cw or ccw to adjust water level. If its a clip, compress the clip between your thumb and forefinger and slide it up or down along the bar to set the float level. You need to test it after adjusting. Level should be 1/2" below top of overflow tube.
Aug 23, 2014 | Home
After installing a new flush valve, the water level in the toilet bowl seems to be much lower than it was with the old flush valve. Is there any adjustment for the water level in the toilet bowl?
Yes,there it is!You can adjust your water level at the flush valve..You can see the ball there you need to adjust that so that the water level of your tank goes to your desired level.
Jul 29, 2011 | Kohler 3386-6 Rialto Skylight Round Front...
I have a Kohler elongated toilet and tank. The toilet does not fill up all the way. What should I do.
Hi chanryan...
You need to adjust your float level in the tank.
Look on the arm of the float ball and there should be a screw that you can adjust the level of the tank water.
Turn the screw to raise the level of the water in the tank, to just about a 1/2 inch of the overflow pipe
If it will not adjust then you will have to replace the float valve (ballcock...is what it is called)
Please take time to rate me
Jul 04, 2011 | Kohler Cimarron 2-PC Elongated Toilet with...
Hi, I have a Kohler toilet with a fill valve. It is a 84679 AA Mod 743. It takes very long to fille. The angle stop and hose supplyu good pressure and volume. It appears there may be a partail...
Go to the Kohler web page and try to find your toilet. The numbers you have here are not jiving. They have pictures of all models. Once you get the Kohler Mdl. number, you should be able to obtain info on which fill valve you need. Most of the parts are not that hard to purchase.
http://www.us.kohler.com/onlinecatalog/category.jsp?section=2&nsection=2&nsubsection=3&category=13&nitem=cat13&brand=kpast&source=google&mat=exact&cat=branded&kwd=kohler+toilets
Apr 23, 2011 | Kohler Home
We have a 1.6 gallon single unit Kohler toilet that just started leaking at the top of the flushing mechanism (inside the tank). The toilet serial number is K3386DA - 20190. The flushing mechanism is...
http://www.lockeplumbing.com/detail.asp?c=Toilet%20Parts&s=Kohler&s2=Float%20/%20Fill%20Valve&sku=KOH-1068030&r1=WHE-USS25C&r2=&r3=
See if your filler valve looks like the one in the picture from the link above.
Aug 21, 2010 | Kohler Home
How to adjust water level in tank---Kohler Wellworth toilet
please make sure the water is off!
the fluid master has a slip ring at the bottom of the float base it pulls up then you can adjust the float up or, down and, snap it back down.
at the top of the float you will see a cross-headed plastic bolt; this is adjusted for fine level control using a large conventional philips screwdriver.
Jul 31, 2010 | Fluidmaster INC #B1F09 9" Faucet Connector
Oct 24, 2009 | Kohler K-11470-0 White Wellworth Complete...
Kohler K-3360-G Revival One-Piece Toilet With 12" Rough-In, Seat, Cover, Br Logo
93 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
