Question about HHP Computers & Internet
I have a 3220-1423kt scanner and it stoped working
My Epson 1240 has just stopped scanning the bottom half of the flatbed. It makes a crunching noise and goes back to the top.
The Track/chain that the scanner bar follows might have some debris/dirt whatever on it stoping it from moving further. Alternatively the motor might have a problem. you can take the cover off and blow that area with a con o' air. Make sure not to get dirt or prints on the scanner or the bottom of the glass
25630969-kdbydlvhgx3mczs4yctz3wk3-5-0.jpg Basic idea of most scanners
Apr 06, 2015 | Epson Perfection 1240U Flatbed Scanner
Pro 2021 police scanner won,t turn on worked fine just stoped
bad power conection or voltage regulator gone bad. their is a llarge resistor near power cord check them
Dec 19, 2014 | Radio Communications
My scanner will not transmit digital trunking channels
There may have been a change in the digital transmitting system
Oct 19, 2012 | Radio Shack Pro-2096 Base Scanner
Problem is coming from hp g2410 scanner
Try deleting that shortcut and get a new one from the Programs folder. Find the HP scanner folder and get a new shortcut copy to your desktop.
Sep 10, 2009 | HP Scanjet G2410 Flatbed Scanner
Rpm gauge and speedometer stoped working
It sounds like you have a faulty Instrument panel Cluster (IPC) Your local dealer will have to confirm this as independant shops don't have the scanner capabilities for this diagnostic procedure.
I hope this helps.
Thank You,
Roy
Aug 05, 2009 | 2003 Chevrolet Blazer
All channels locked after using win 96 on my pro-96 scanners
hello my name is kathy and i just had the same problem with mine.I know if you don"t use it very often and shut it off a lot you will loose the program. I first stoped turning it off at all and would just turn the sound all the way down. I went to each one and unlocked them, I had lost over half and the other was locked. I put them back in unlocked the ones the were locked, stoped turning it off 2 years ago and have not had a problem since. I hope you will let me know if this helped. k.ditterline@yahoo.com
Nov 28, 2008 | Radio Shack Pro-2096 Base Scanner
Scanner is not working
Use the following link to download the software.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=351125
Apr 29, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Scanning
This is all due to driver compatibility issue,please thry this,first remove all software n drivers for the scanner ,download driver from this site by selecting ur operating system,n install,do remember to reboot ur laptop after removing previous software.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=14003
do revert
thnx N
Jan 26, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Canon MP530 - "scanner error" mesage
I've some problem whit the printer and my firs check printer make only bips
Sep 17, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Computers & Internet Logo
42 people viewed this question
Top HHP Computers & Internet Experts
David Payne
David Payne
Are you a HHP Computer and Internet Expert? Answer questions, earn points and help others
