Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Paper feeding tray
Paper doesn't feed from the tray, but a single sheet of paper does feed from the bypass.The display shoes P.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 67 Answers
Try printer setting to the requisite tray number
Posted on Oct 20, 2013
Testimonial: "Thanks, I was using it in copier mode, and there is only a single paper tray. The bypass is a manually fed sheet of paper, which works ok."
  • 2072 Answers
SOURCE: paper feed problem
You need new feed components. Feed rollers and retard rollers or pads that stop multisheet feeds.
Posted on Jan 08, 2008
  • 2072 Answers
SOURCE: The paper will not feed through
It could be several items causing that. Lets go simplest to most difficult.Remove the paper tray completely, What you do is pull it like you were going to add paper, but give it a slight lift upward and it will come out. Look in there and you will see the feed tires they are "D"shaped and they should have some texture to the surfice. Take some alcohol and clean them a few times to remove all contamination. But if they are smoothe, they should be replaced. You have to run a lot of copies on them to wear them out though. Also try spinning them a couple of times to be sure the latches that stop them from multifeeding are not just stuck.
You know what, lets do this the right way. After you take the paper tray out. also take your toner cartridge out, then lift the machine and lay it on its back so you can see the peper feeder totally. But make sure you remove the toner before you lay it on its back. You may also want to remove the document feeder prior to laying it on its back. That way you can see the rollers batter, look into where the paper feeds and see if there is anything blocking the paper path. Who knows a small pirce of paper may be stuck in there, or a staple or paper clip.
Then check the paper tray carefully, press the plate down and see if it springs back up.
Once cleaned and inspected, replace the tray and toner and try and run the machine. If if still jams, you want to move the machine out fron the wall and remove the back cover. There are 6 screws holding it on. You will want to look near the bottom of the frame, there is a whits grar, cam type drive . It is white, about 2 inches in diameter and about a half an inch thick. There is a solonoid that engages to release the peper feed, run the machine and see if that assembly is realsed to feed paper. If not, the solonoid or the main board may be bad.
There are metal fingeres in the paper tray also that press right on the corners of the paper to stop multi sheet feeds, they may be slightly bent also. They are on either side of the peper when it is in the up position. You can try seeing if the move freely up and down when the tray is out.
Also when you have the machine on its side, look at the clear mylar strips in the paper feed to see if one of them are tucked under.
I suspect dirty or worn rolls, or something to do with the paper tray. That is mostly where mis feeds occur.
Please let me know and we will look more into it.
Posted on Nov 03, 2008
  • 2072 Answers
SOURCE: Paper Jam or Will Not Feed
Sounds to me you have worn out feed tires.
Google a business called ' the parts drop. Give them a call.
They will have what you need, and at a fair price.
Posted on Jan 10, 2009
SOURCE: Jam at top message will not clear and no paper in path
Hello Al_edee,
Try to look at the fuser, when it's cooled down, if there are remains of old or stuck paper in it or to exchange the fuser.
Kind regard,
Mark
Posted on Jan 12, 2009
  • 2072 Answers
SOURCE: Xerox Phaser 8400 Error code 07,010.43:99907
You manually rotated the aluminum drum? Since you did that, I would suspect you have the print head wiper blade stuck between the drum and print head. The code you are getting it caused by the print head not being able to move freely.
The jamming is probably due to a bad registration clutch. Common failure on that machine.
You can go to Xerox.com, there is under documentation and drivers a parts list for that machine. You can reference the wiper blade and get the clutch part number there.
Let me know what other information you may need. I will be glad to help you get it running again.
Posted on Jun 18, 2009
Paper won't feed from the tray, the display shows P. Opening and closing the tray restores the machine. A single sheet of paper will feed from the bypass.
The pick up roller need to either need to be clean or replace. Because of the price to replace the pickup roller it might be worth more to just get another printer.
Oct 19, 2013 | Xerox WorkCentre XD100 All-In-One Laser...
SCX-4216 "No Paper" message
Check this link it has a step by step solution that you can try http://www.fixya.com/support/t216317-no_paper_error
Hope that helps..........
Aug 07, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Paper jams when it leave the tray
This printer is new model so probably there is a problem with paper sensor at registration roller or next one paper sensor in fusing unit(it depends where the sheet stops). To be sure please first clean as you can the paper feed roller in tray and also check the manual feeding. If you can feed on bypass tray, then the paper sensors are OK. Look for problem in tray or rubber roller
pifonski
Feb 24, 2011 | Samsung SCX4623F Laser All-in-One Printer
Brother MFC-8840D printer w/false paper jam indication.
With my Brother 8840D I have had paper jams that when cleared would not delete from the display nor would the machine operate until I unplugged the machine for around eight hours. I guess it is a sort of reset or reboot.
Jun 06, 2010 | Brother MFC 8840D All-In-One Laser Printer
Samsung Scx-4216f wont pick paper out of drawer
Below would be the suggested solution regarding paper feeding problems;
If Paper does not feed into the machine.
• Remove any obstructions inside the machine.
• Paper has not been loaded correctly. Remove paper from the
tray and reload it correctly.
• There is too much paper in the paper tray. Remove excess
paper from the tray.
• The paper is too thick. Use only paper that meets the
specifications required by the machine.
Below is the suggested paper specifications;
Supported Sizes of Paper
Paper Dimensions* Weight Capacity**
Letter 8.5 X 11 in. (216 X 279mm)
• 60 to 105 g/m2 bond (16 to 28 lb) for the paper tray
• 60 to 120 g/m2 bond (16 to 32 lb) for the Bypass tray
• 250 sheets of 75 g/ m2 bond (20 lb) paper for the paper tray
• 1 sheet of paper for the Bypass tray A4 210 X 297 mm (8.3 X 11.7 in.)
Executive 7.25 X 10.5 in. (191 X 267 mm)
Legal 8.5 X 14 in. (216 X 356 mm)
Folio 216 X 330 mm (8.5 X 13 in.)
Hope this helps!
Sep 10, 2009 | Samsung Office Equipment & Supplies
Will not pick up paper from tray. Red light blinks indicating a paper jam. Prints fine if single sheet thru bypass slot.
Not picking up paper indicates either a worn nip roller (rubber on feed spindle) or you have a broken gear in the feed mechanism.
Aug 14, 2009 | Brother HL-2040 Laser Printer
Printer can't feed paper from tray
You may need to clean the rubber feed roller with a damp towel, water only, or if parts are broken or missing, a new paper tray, around $20.00
Jul 20, 2009 | Brother HL-5240 Laser Printer
HP paper jam
That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 03, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
Paper feed/jamming problem
suggest you bring your orinter to the nearest authorised repair center. There might be parts to be replace
Mar 23, 2008 | Brother HL-2040 Laser Printer
Automatic Paper feed
Check the feeder roller inside the printer for any foreign substance stuck to the roller, this may cause it not to grip properly. You can also try a few sheets at a time and make sure the paper tray is gripping the paper, but not too hard. If this fails, the roller may be out of place somewhat, try to reposition it. Let me know how you get on.
Sep 06, 2007 | Samsung ML 1210 Laser Printer
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
60 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
