Question about Amana RFS12MPS Microwave Oven
Heats but not hot enough - Amana RFS12MPS Microwave Oven
Reheat baked ziti
Reheat baked Ziti in a microwave. Heat it in 20 second intervals until it is hot enough. Do not overheat it and enjoy!
Jun 05, 2017 | Microwave Ovens
Should my microwave get hot underneath
Not hot enough to damage counter tops, but it could be easily expected to get uncomfortably warm. They don't have a lot of insulation in them as they really don't want the heat to build up inside the unit.
Aug 01, 2016 | Microwave Ovens
Please I need the wattage of GoldStar microwave Model ER-868 so I can heat a heat pad for a sick animal
Wattage really doesn't matter much for what you want to use it for. Start with 2 minutes and test. If it's not hot enough add 1 more minute
Jun 09, 2016 | Goldstar Microwave Ovens
The manual tells me to test the product by heating a cup of water for 30 seconds
Bernard,
I usually will test a cup of water for 60 seconds and it should be hot enough that you would not want to leave you finger in the water more than a couple of seconds. It would not be hot enough for most people to use for coffee or some other hot beverage but it would be hot enough to burn your finger if you leave it in there for very long. If it is still lukewarm after running for 60 seconds you probably have a problem with some of the major components and depending on the age of your microwave it might be cheaper to replace the microwave with a new one. Hope this helps you!
Apr 12, 2015 | Microwave Ovens
Maytag oven will not heat, no gas flow. Broiler works, clock and timer works.
You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface igniter will not come on - check igniter with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new igniter time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface igniter problem. The hot surface igniter often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the igniter. See this service sheet for the proper way and amp readings for the hot surface igniter system. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar igniter can glow orange-red and still be bad!! How a common gas valve works - click here.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 13, 2011 | Maytag Microwave Ovens
I have a Kitchenaid built-in microwave mod: kcms1555rss-2 . When you close the door it hums and gets hot on the inside. Open the door and it stops. It got hot enough to smell when I walked in the house...
call kitchenaid and let them know it stays on and heats i belive this unit has a new board to stop this issue. It isa safty isssue they should repair it free..dont forget to rate me Thanks
Jun 07, 2011 | Microwave Ovens
Not getting hot enough
Check at the backof this there is an air intake vent if that is clear you
will need a replacement magnetron
Feb 12, 2010 | Kenmore Microwave Ovens
No heating or power to microwave oven
You have a fuse in the back that's problem is blown
Mar 13, 2009 | Microwave Ovens
Microwave Keypad Is Hot
check blower fan, and maintained gap between oven and wall at last 2 feets. some heat comes to pad very heat may be some prolem. check every thing and reply me.
Aug 21, 2007 | Emerson MW8108P Microwave Oven
Amana RFS12MPS Microwave Oven Logo
18 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Gareth Cockram
Gareth Cockram
Steven Clarke
Steven Clarke
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
