Question about Krups XP 5280 Espresso Machine
Descaling with white vinegar still drips into bottom tray
The water is not flowing through the shot it is dripping minimally. What is the problem please
Fill the unit with white vinegar and let sit for about 10 minutes, and then start the unit and let the vinegar run through. You can stop it about half way through the cycle to allow the vinegar do better descale the insides. You can do this multiple times as needed. When finished, flush the unit with to cycles of clear cold water.
May 25, 2015 | Coffee Makers & Espresso Machines
Tip
Bosch tassimo T65 - water draining in to drip tray possible cause and resolution
I had a problem on my Tassimo T65 where water was entering the bottom drip tray through the small hole at the rear. It seems many people have this problem but after researching on line there is little help although I found on this sit how to take the coffee maker apart and from that thread the possible cause for my own issue.
So if your machine seems to be leaking from the small drain hole to the rear of the drip tray try this before you think it is either in need of specialist repair by Bosch at a cost almost the same as a new machine or before you start to take it apart and have a look yourself.
CAUSE - The water is coming from the drain hole because the pressure valve at the top of the machine is blocked with calcium deposits through prolonged use without descaling sufficiently.
SOLUTION - Purchase a good quality coffee machine descaler. Sit the whole coffee machine in a tray or large oven tray so you can collect the overflowing descaler throughout the process, it's not economical to waste this solution. Remember to clean down and dry the coffee maker each time.
Use at least half strength descaler do not water it down more than 1:1
Follow the descaling process by inserting the yellow disc and holding the start button down for 3 seconds.
Repeat this process several times, recovering the fluid leaking in to the tray and cup or container. If you start to see small lumps being dispelled in to the cup try to remove these for further descaling.
After several cycles you should notice that the leaking or flow of water from the bottom drain hole becomes less until it stops. To force the dissolving scale out of the pressure valve try running the normal clean cycle but with the descaling solution, the flow is longer and will help flush the restriction.
After a number of descaling and clean cycles the leak or flow from the drain hole will have stopped, if not continue till it does.
Note: I ran cycles for about 2 hours with periods of rest to allow the solution to do its work.
Now the leak or flow has stopped clean out the reservoir and replace with clean water and run at least 4 clean and rinse cycles.
i hope this works for you and now enjoy your coffee.
on Jul 02, 2014 | Bosch Coffee Makers & Espresso Machines
My Keurig B40 has three different size cup sizes available, but it dispenses the same amount of water for the medium size cup and the large cup of coffee. It's barely been used so It doesn&am
I realize you think it does not need descaling to to it 'not being used much.'
However you may have hard water and I would think descaling is definitely worth a try. There might be scale built up on the water level probes in you machine.
Descaling Details are listed below:
Brewer Model: Elite B40 ' Classic B44
Special Edition B60 ' Platinum B70
To begin, you will need the following:
• 48 ounces of undiluted white vinegar
• Large ceramic mug (do not use a paper cup)
• Access to an empty sink
PREPARE
Step 1:
Empty the water in the Water Reservoir.
Step 2:
Disable "Auto Off features."
FILL AND CLEAN
Step 1:
Pour approximately 48 ounces of the vinegar into the Water Reservoir.
Step 2:
Place a large mug on the Drip Tray Plate and run a brew cycle.
(DO NOT USE A K-CUP)
Just press the BREW Button. Pour the contents of the large mug into the sink.
Step 3:
Repeat the brew process without a K-Cup until "ADD WATER"
is indicated.
Step 4:
Now let the Brewer stand for at least 4 hours while still on.
Step 5:
Discard any residual vinegar and rinse the Water Reservoir thoroughly.
RINSE
Step 1:
Ensure the Water Reservoir is filled with fresh water.
Step 2:
Place a large mug on the Drip Tray Plate and water brew cycle. Pour the contents of the large mug into the sink.
Step 3:
Repeat brew process until "ADD WATER is indicated.
Step 4:
You may need to perform additional water brew cycles if you notice any residual taste.
Nov 20, 2014 | Keurig B40 Coffee Maker
I am descaling my Keurig for the 2nd time, it fills 2 cups w/vinegar and stops and won' start again, tells me its ready, help
A. Prepare
Step 1: Make sure you have 48 ounces of white vinegar on hand. You will also need an empty sink and a ceramic mug (Do not use a paper cup.)
Step 2: Empty the water in the water reservoir
B. Fill and Clean
Step 1: Pour the vinegar into the water reservoir and fill it to the top edge of the clear viewing area.
Step 2: Place a ceramic cup in the drip tray and run a brew cycle. DO NOT USE A K-CUP...just press the large cup button. Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty, pouring the contents of the cup into the sink after each cycle. Remember to open and close the lid between each cycle.
Step 4: Now fill the reservoir with fresh water and let the brewer stand for 4-hours while it is still on.
C. Rinse
Step 1: Ensure the water reservoir is filled with fresh water.
Step 2: Place a ceramic cup on the drip tray and run a regular brew cycle. Once again, DO NOT USE A K-CUP...Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the water reservoir is empty.
Step 4: You may need to perform additional brew cycles if you notice any residual taste.
Jun 01, 2014 | Keurig Platinum B70 Coffee Maker
Why is my Kuerig B60 coffee maker not filling the correct amount of water. ie. a cup instead of a mug or 2 instead of 3rd level?
Your b60 may need to be descaled. There might be scale built up on the water level probes in you machine. I have listed the directions below:
Brewer De-Scaling Instructions
PREPARE
Step 1:
Step 2:
FILL AND CLEAN
Step 1:
Step 2:
DO NOT USE A K-CUP
, just press the BREW Button. Pour the contents of
Step 3:
Repeat the brew process without a K-Cup until"ADD WATER"
is indicated.
Step 4:
Step 5:
RINSE
Step 1:
Step 2:
Step 3:
Step 4:
NOTE:
If "DE-SCALE" is still displayed after
completing the procedure, repeat the
descaling procedure above.
Apr 14, 2013 | Coffee Makers & Espresso Machines
Keurig b60 won't dispense water
PREPARE
Step 1:
Step 2:
FILL AND CLEAN
Step 1:
Step 2:
DO NOT USE A K-CUP
Step 3:
is indicated.
Step 4:
Step 5:
RINSE
Step 1:
Step 2:
Step 3:
Step 4:
NOTE:
Dec 14, 2012 | Keurig B60 Coffee Maker
Cant find my manual and I dont recall what descaling means. It is stuck on this and wont do anything. Please advise
According to the owner's manual, you sould empty the water resevoir. Fill the water resevoir with white vinegar (it says 48 oz). Place a ceramic (not paper) cup in the drip tray and run a travel mug cycle with no k-cup in the machine. Throw the vinegar out. Repeat this process until the resevoir is empty. Be sure to open and close the lid so the cup sizes flashes each time. let the brewer sit for 4 hours while still on (the vinegar's still inside). Rinse out the resevoir, fill it with water and run the cycles through until the resevoir is empty again. If there is any residual taste. repeat the rinse. If it still say descale when you're done, the book says to repeat the process.
Nov 28, 2010 | Keurig B60 Coffee Maker
Descaling?
With the selector buttons find Descaling and press OK
This process takes about 35 minutes
1. Empty the water tank, drip tray and grounds container.
2. Insert tray and grounds container, refill tank with with 0.5 Lt. of water and add descaling agent (not the pill or powder used for clean cycle) to tank. Make sure its completely dissolved.
3. Place a container or cup under the steam wand large enough to hold 0.5 lt.
Display says Descaling and press OK
4. Press the water button
Display says Descaling in Progress
after the descaling agent is exhausted
Display says Empty Drip Tray and Spent Grounds
5 Also remove rinse and refill the water tank to Max line
6. Press the water button again
after the machine stops
7. Empty the drip tray and spent. ground container and replace
Display says Rinse Press OK
Display says Appliance Ready
In essence go to Descaling Press OK and follow the directions as they are displayed.
Sep 07, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Descale
Aug 02, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Descaling light on
Per Pages 9 and 10 of Keurig Model B40 Use and Care Guide,
1) turn off the "Auto Off "feature
2) fill empty water reservoir with 48 ozs of undiluted white vinegar.
3. Place ceramic cup on the drip tray and run a brew cycle. Do not use a K-cup!
4. Press the large mug Button
- let Keurig coffee maker fill mug with vinegar & empty in sink.
5. Repeat brew process until water reservoir of vinegar is empty. (remember to open and close lid between each cycle so large mug Button will flash.
6. Rinse the water reservoir thoroughly and fill with fresh water.
7. FINAL STEP RINSE CYCLE
a) place a ceramic cup on the drip tray
b) run regular brew cycles WITHOUT using a K-cup.
c) pour rinse water into sink each time.
d) repeat brew process until water reservoir is empty.
d) perform additional rinse cycles if you notice any residual vinegar taste.
e) if the red "De-scale" light remains illuminated after completing descale and rinse cycles, repeat the descaling procedure above.
Otherwise - you're good to go!
Apr 16, 2008 | Keurig Elite B40 Coffee Maker
Krups XP 5280 Espresso Machine Logo
78 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
