Question about Epson Stylus DX4450 All-In-One InkJet Printer
Remove Epson DX4450 print head for soaking or cleaning
SOURCE: How to remove print head of epson stylus photo r1800
Had the same problem - but the print head is actually easy to remove.
1) Remove ink cartridges
2) Remove 3 Phillips head screws at the bottom of the cartridge housing. (looking down from the printer front - top left, bottom left, top right).
3) There are 2 small plastic tabs on a plastic bracket that secure the flex cable on the right hand side of the cartridge housing. Gently release the tabs with a small flat head screw driver.
4) Lift the print head straight up (don't pull on the flex).
There may be a release for the flex to separate from the print head. But I did not see one. Instead I poured 1/4" of Windex in the bottom of a small plastic container and soaked my print head for about 15 minutes (occasionally agitating).
Then put back in reverse order - be sure to seat the flex in the guide (top-back-right) of the cartridge housing before screwing down. Then run a cleaning or two to flush the cleaning fluid out of the print head. (I have a waste ink tank installed so I am not worried about dumping excessive ink into the waste sponges).
The differences was remarkable - though there was still slight banding - maybe should have soaked longer (1 hr perhaps?) - I may repeat if it remains an issue.
Additionally there were large solid deposits on the left side of the print head which were responsible for scraping heavier weight photo paper. These dissolved in the Windex too.
Posted on Apr 07, 2009
efs_perpends
  • 1996 Answers
SOURCE: epson stylus photo 2200 print head removal
Replace the cartridges.
Otherwise, it's unorthodox, but some users have found that this works in your situation. Remove the cartridge, cover the nozzle with a paper towel and use the pointed attachment of a vacuum to clean the dry ink from the cartridge. Be careful not to get ink all over. Then reseat the cartridge and print...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 26, 2009
  • 684 Answers
SOURCE: Epson CX4800 cannot clean the print heads
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
Posted on May 27, 2009
pineworks
  • 4041 Answers
SOURCE: epson stylus dx4450 printer does not print black.
Hi Yes you can try clean.
Ok it got to be the heads blockage
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on Helping.
All The Best: Pineworks
Posted on Feb 01, 2010
  • 164 Answers
SOURCE: print head clogged
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 08, 2010
Testimonial: "thanks v much for the well detailed procedure. If this works it will have saved me a few hundred pounds"
How to clean a epsom dx4450 printer
Depends where you want to clean it. It's a good idea to wipe the roller with a damp cloth sometimes, but if it is the print head then there is an article here:
https://files.support.epson.com/htmldocs/pho22_/pho22_rf/maint_2.htm
May 12, 2014 | Epson Stylus CX6400 All-In-One InkJet...
Yellow isnt working
Let's try a couple of things. First, have you tried a different yellow cartridge?
If you have, we can try cleaning the printhead. Remove the printhead and soak it overnight in a warm distilled water bath. This is the gentler alternative to the more aggressive head cleaning solutions. After the soaking overnight, blot the printhead being with a lint free cloth being careful not to brush the electronics. Reinsert the printhead and reinstall the ink cartridges. Try printing. This should clear the printhead clog. If the printhead is severely clogged, you may have to repeat the soak.
Let me know if this clears the problem.
Jul 10, 2011 | Epson Stylus DX4450 All-In-One InkJet...
How can i open an epson dx4450 so i can cleean it's print head?
Hi
try cleaning it from maintenance menu
in case i had help you pls vote me
Nov 05, 2010 | Epson Stylus DX4450 All-In-One InkJet...
White lines running through printed line
The white lines occur when the print-heads do *NOT* output coloured-ink when they should be.
Run the Epson printer-software to "clean-the-print-heads".
May 29, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Hello i changed the ink in my epson stylus dx4450 however the ink light is still on and it still wont print. i tried turning it off at the plug but still wont work
It seems that the connection on the cartridge and the printer are not proper. Remove the cartridge and clean the connectors on the cartridge and the printer. Also remove the tape on the print head.
Aug 28, 2009 | Epson Stylus DX4450 All-In-One InkJet...
Missing lines when i print
realigning your new ink... thats all... or clean the heads...
Jun 16, 2009 | Epson Stylus DX4450 All-In-One InkJet...
My epsom DX4450 only prints in black. Have cleaned heads done nozzle check and reinstalled it twice. Anybody help me
have you gone into the print setup >printer>properties>paper/quality and selected colour printing there ?? hope this helps regards JIm
Apr 29, 2009 | Epson Stylus Multifunction Inkjet Printer/...
When I print or copy there are missing lines of print.
Hi, one or two head cleans won't clear a badly clogged nozzle. Try doing 4 or 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with a nozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Others are available just try googling "inkjet head cleaning".
Note that head cleaning uses between 5 and ten percent of your ink cart's, if any are low on ink have some new ones ready. Epson recommends printing a colorful document at least once a month to prevent nozzles getting clogged, see the Epson online guide:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=lkuCfcvA9cwxY9S6wZhcOql4VsOeN1ay&tc=5#10
Hope this helps.
Please take a moment to rate this solution, thanks.
Mar 30, 2009 | Epson Stylus DX4450 All-In-One InkJet...
Epson STYLUS DX4400
Dump then program. Start your pc again wtih printer plugged in. Let it install program automatically.
Feb 21, 2009 | Epson Stylus DX4450 All-In-One InkJet...
Epson Stylus DX4450 All-In-One InkJet Printer Logo
337 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
