Question about SainSmart DSO203 Nano V2 Quad Pocket-sized Digital Oscilloscope
FPGA configuration error - SainSmart DSO203 Nano V2 Quad Pocket-sized Digital Oscilloscope
What does error 90 Mean on an Electrolux Ewf 1087
E90 is family error code visible to the customers. It is necessary to read the error in the service mode so please proceed with the following procedure for rapid reading of alarm codes:
Press and hold down START/PAUSE and the option button nearest to the START/PAUSE button for at least two seconds!
After that the display will show one of the following errors that are more precise:
E91, E92 - Communication incongruence between main board and display board (versions not compatible). Posible causes: wirings, main board or control/disply board.
E93 - Incorrect configuration of appliance. Posible causes: Incorrect configuration data; electronic board faulty.
E94 - Incorrect configuration of washing cycle.
E95 - Communication error between microprocessor and
EEPROM. Posible causes: Electronic board faulty.
E97 - Incongruence between programme selector and
cycle configuration. Posible causes: Faulty electronic board (Wrong configuration data).
Considering that this is a complicated fault, my advice is to contact an authorized service center.They have special equipment such as an interface that allows them to upgrade software in your appliance. If you are not doing anything on the appliance before the failure, the only thing you can check is the contacts between wiring and electronics.
Dado
Feb 22, 2016 | Electrolux Washing Machines
Trouble during the upgrad of lexicon MC-12
Try on a different computer , if it still get stuck at the same point bring the amp to sevice shop, they will reinstall the firmware
Mar 30, 2008 | Lexicon MC-12 Balanced Amplifier
Model EWF1048W. Won't start. What does error e94 indicate?
E94 - Washing cycle configuration error.
Incongruence of configuration values at the switching on of the appliance. Check that all the connectors are inserted correctly.
Possible configuration error. Replace the circuit board.
Dado
Dec 12, 2015 | Electrolux Washing Machines
Adobe acrobat x pro configuration error 16
you need to uninstall and re-install before install download it again from main site again it will work.
Jan 19, 2014 | Adobe Acrobat X Pro
My samsung washing machine SWF P10 front loader got its control card damaged due to a voltage surge.The company said that this card is no longer available with them;visual inspection shows charring of the...
Chip level repair can only solve the problem, Unfortunately, no one is available to do so. I have the same problem. The Samsung service people further cooked the card (PCB). Initially it was only flickering while running, now it shows all red lights and does nothing.
Sep 01, 2011 | Washing Machines
Have an error: security PAL not detected on a IBM 4400 printer
How do I fix a FPGA error on a 4400 thermal printer?
Dec 16, 2010 | IBM 4400 Thermal Printer
Canon IRC3200-RIP board not work and unknown brand
the box that you find at the back of the machine is called fiery you can configure that when you press the arrow key top right of the screen panel. you will the option of the fiery. make sure the power of fiery is connected
Dec 10, 2008 | Canon imageRUNNER C3200 Copier
Configuration error with w850i
Please what generates error.
Did you install pc suite it give configuration error.
Let me know at which level you get error.
I have w850i too it work fine with pc suite.
Please reply to this thread with explanation.
Nov 20, 2008 | Cell Phones
SainSmart DSO203 Nano V2 Quad Pocket-sized Digital Oscilloscope Logo
631 people viewed this question
Top SainSmart Computers & Internet Experts
David Payne
David Payne
Are you a SainSmart Computer and Internet Expert? Answer questions, earn points and help others
