Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
CE-200 - Vista
It seems as if the problem is really with installing Hyperfont. When it is installed and I start the program my pc stops telling me it has encountered a problem and won't open the program. I have installed the patch. Why do they give the option of installing XP service pack 2 for Vista though? Do I have to install this? Your help would really be appreciated
Futura software large design stitch
Posted on Oct 10, 2007
Trying to use my futura ce-200. original software hangs on Win7 machine, updated software just says: entry point not found... the procedure entry point splash textcolor@@yaxk@z could not be located in
http://www.futura-support.com/products/ce-200/software
Make sure you downloaded the correct update. Reinstall the original software. Now right click on the program file (.exe) file in the software folder (prob on c:, folder called Futura **). Mine is different than yours...so end of file will be different, so I put ** instead). After you open the file folder...right click on the program file & choose properties; choose Compatibility; Check the run as box (mine is set to winXP 2); and check the run as administrator box.
Try opening the program...if it opens...you can then do the update install.
May 15, 2014 | Singer CE-200 Quantum Futura Computerized...
COMPUTER CRASHED I NEED TO RELOAD CD BUT I DONT HAVE ACCESS CODE
There are now several versions of the basic Futura software and AutoPunch available on the market. The most current is version 1.0.0.2. To determine what version of either software you have, you will find this information around the inside rim of the CD at approximately 4 o'clock. Before loading any of the Options into your computer, check the version and then follow the steps below. The following steps will update your software so that you will now have the latest 1.0.0.2 version of the basic program and all options.
To load base software 1.0.0.0 with AutoPunch 1.0.0.0 or base software 1.0.0.1 with Autopunch 1.0.0.1
  • You must use bobbin part number 085128. This bobbin is specifically designed for the Futura CE-100 and CE-200.
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Turn on Futura machine and double left click on Futura icon to open program
  • Close program and turn off the machine
  • Install Autopunch and leave the CD in the tray
  • Download appropriate update for Windows Version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop download icon to install update
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program
To load base software 1.0.0.0 with AutoPunch 1.0.0.1 or base software 1.0.0.1 with Autopunch 1.0.0.0
To load base software 1.0.0.0 or 1.0.0.1 with Autopunch 1.0.0.2
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer- machine turned OFF)
  • Close software and turn off machine
  • Install Autopunch using Installation Wizard - leave CD in tray
  • Turn on Futura machine and double left click to open program
  • Type in Access Code from Autopunch jewel case and then left click on check mark to open program
To load base software 1.0.0.2 with Autopunch 1.0.0.0 or 1.0.0.1
  • Close program and turn off machine
  • Place Autopunch CD in tray but CANCEL Installation Wizard
  • Turn on Futura Machine and double left click to open the program
To load base software 1.0.0.1 with Autopunch 1.0.0.1 with Hyperfont 1.0.0.2 or Photo Stitch 1.0.0.2
  • Load Base software (have the machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Close program and then turn off the machine
  • Install the Autopunch program and leave the CD in the tray
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program*
  • Download appropriate update for Windows version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop icon to install update
  • Install HyperFont program - leave CD in tray
  • Type in Access Code from HyperFont jewel case and then left click on check mark to open program*
  • Install PhotoStitch program - leave CD in tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark to open program*
* Must open the program after installing each Option with CD in tray and type in Access Code before installing next Option.
To load base software 1.0.0.2 and adding all Options - Hyperfont 1.0.0.2, PhotoStitch 1.0.0.2, Autopunch 1.0.0.2 and Cross Stitch 1.0.0.1
  • Install Base software (have machine set-up for embroidery with USB connected to both the machine and computer- machine turned OFF)
  • Close program and then turn off machine
  • Install Autopunch program and leave the CD in the tray
  • Type in Access Code from AutoPunch jewel case and then left click on check mark*
  • Install Hyperfont program and leave the CD in the tray
  • Type in Access Code from HyperFont jewel case and then click on check mark*
  • Close Program and turn off machine
  • Install Photo Stitch program and leave the CD in the tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark*
  • Close program and turn off machine.
  • Install Auto Cross Stitch program and leave CD in tray
  • Download appropriate update for Windows version from the Futura-Support.com updates (Fut_sp2_Options.exe) and save to desktop
  • Type in Access Code from Auto Cross Stitch jewel case and then left click on check mark*
Dec 11, 2010 | Singer CE-200 Quantum Futura Computerized...
Problems with the CLEM drive and windows vista
I had the same problems, what I did was I also loaded the service update version 1.0.0.2 and everything is working just fine.
Jun 15, 2009 | Singer CE-200 Quantum Futura Computerized...
Futura software on winds vista
well i fixed the problem. if anyone wants to know how, just send me $9.99 (fiya price) and i will be glad to share.
Jan 11, 2009 | Singer CE-200 Quantum Futura Computerized...
Cannot install and get the Hyperfont to work on Vista
Search for troubleshooting utility in your Futura folder, launch it and send report to Singer. It is quite difficult to determine the root of the problem without your pc configuration and Futura folder content info.
Aug 28, 2008 | Singer CE-100 Futura Computerized Sewing...
Can't load Hyperfonts on my pc
Hello I have the same machine Futura CE250, But I just have the the Autopunch software. I dont know why this situation. What about if you try uninstalling and reinstaling the software? my email frias.hector@hotmail.com Best regards and good look.
Apr 23, 2008 | Singer CE-200 Quantum Futura Computerized...
Software not opening with Singer Futura on Windows XP
Bit out of my league can I suggest you talk to a computer expert.
My limited knowledge tells me while trying to update, your previous software package has been corrupted.
Mar 12, 2008 | Singer CE-100 Futura Computerized Sewing...
Vista unable to install Futura software
I found a solution that seemed to work for my setup (Vista-Futura 200): Go to the Futura support site www.futura-support.com . Choose "Service Updates" from the left-hand Menu. Choose "Quantum® FUTURA™ (CE-200) Owners running Windows XP Service Pack 2 operating system WITH one or more of the Options (AutoPunch, CrossStitch, PhotoStitch, and HyperFont) installed". Look for the bullet-point list in the explanations. It says there: "If you own the AutoPunch Option and you could not successfully install it, download the Service Update by clicking here." Select the highlighted link, download the patch and install it. Worked fine for me, I hope it helps you, too.
Nov 03, 2007 | Singer CE-200 Quantum Futura Computerized...
Other brands of Software
You can only use the futura software, autopunch, hyperfont and cross stitch
Oct 29, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
168 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
