What does code WWF00F000-WIVVCM mean? All i know is that I lost radio connection without touching the switch (was online working) and system says turn in on in order to get wifi (which was what I lost all of a sudden). This is on a T430S (product 2356L3G with BIOS G7ET91WW (2.51)). My T420S is running online on the same infrastructure without a hitch.
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 225 Answers
Please contact service center
Posted on Oct 21, 2013
rachelgeek23
  • 155 Answers
SOURCE: Dell Inspiron 6000 PC Notebook, No Wifi Radio Signal
Open Intel Proset Wireless or Dell wireless utility from start>all programs. Make sure the the checkbox for 'enable radio' is checked.
Posted on Jan 02, 2009
  • 191 Answers
SOURCE: WiFi Keeps connection keeps switching off.
go to my computer propetes then go to hardware then device manager then network adapter enable if it is disabled
Posted on Mar 23, 2009
jennifer720
  • 830 Answers
SOURCE: i have a acer aspire 5003WLMi and my wifi is not
Hello and thank you for using Fixya.
This could be caused by two seperate issues:
1. The actual wirecard that is inside the laptop has been damaged or gone out. This can be caused by overheating or dust. Try getting a can or air, unplug the laptop and blow the dust gently to remove dust. If overheating is causing the issue, try letting the laptop cool down a few hours.
2. Driver issue - This can also be caused by a missing or deleted driver. You can visit the manufacturer's website and redownload the driver free.
Posted on Dec 21, 2009
podita
  • 324 Answers
SOURCE: I have a dell Inspiron 9300. Everytime I switch on
You need to update the drivers asap, and ensure your service pack is uptodate too
Posted on Mar 29, 2010
  • 43 Answers
SOURCE: It came with the system
You should be able to download one from here: http://www.mediafire.com/?7tvtl3n027mxjmy
If that doesn't work, a search of the solutions on this web site will yield one that may work.
Posted on Nov 14, 2010
Renault grand scenic espace radio shows ERROR code
Was the battery power lost to the radio?
Jan 18, 2017 | Renault Cars & Trucks
The memory settings are lost at switched off.
Many portable radios require batteries that keep clock and oher functions - including memory presets. Without knowing the brand and model of your radio I can't get into any more detail than that. Look for a battery door or the manual online with google.
Google
Oct 15, 2015 | Audio Players & Recorders
WWF00F000-UJ7W2I
It is a data read error test your hard drive and repair
Feb 24, 2014 | Lenovo/IBM ThinkPad T430s Series Laptop...
ST - Is that the "Standby function"? - how to put it off?
On radio systems, ST means STEREO signal lost... check antenna.
Apr 30, 2012 | Cars & Trucks
Track control pop on what do that mean and can I trim it off
Your traction control switch may be located on center IP fascia. below the front a/c control switch. Pls check your manual. You can turn it on or off and it will indicate visually on the insrument panel cluster. Normally the default mode is off,(traction light off) meaning the traction system is enabled and operational. If the light comes on while the engine is running and even without touching the switch, it only means that your traction control system have been disabled because the system has detected a fault; you can still run and proceed carefully in good brakes without the traction control system..However' you still need to have your vehicle scanned for codes to know the specific cause.
Feb 18, 2011 | 2007 Chevrolet Tahoe
I want to on fm without Head phone...i need code.
If you mean Nokia 2310, I don't think it's possible to play radio without headset connected to the handset. I don't believe, nokia has ever developed such a model and moreover it's impossible to play radio on nokia phones via bluetooth. If you mean other model, do let me know. Or is there any other application installed on your phone to run the radio? But in fact the handset needs the headset to run radio, so that i'll act as an antenna. Somebody uses the cut-out jack of the headset to play radio. You can try a trick, play the radio, put on the speaker (loudspeaker), then remove the headset, if it's working you are lucky. But even with Nokia N95, it's not working.
If you are sure that you are asked a code to access the radio without headset, let me know with more details.
Thanks.
Good luck.
Thanks for using FixYa.
Aug 18, 2010 | Nokia 2310 Cellular Phone
After changing the battery I lost the radio code and I don't know the number as I bought the Jaguar second hand
i have a 2004 jaguar x-type and i replaced my battery and the radio is locked and i dont know the code. i bout the car second hand and the code that the dealership has isnt working. what can i do to get the radio unlocked?
May 03, 2010 | 2004 Jaguar X-Type
Need advice on changing a battery on a 2000 VW jetta
I change the battery on my TDI by undoing the nuts in any order, positive first and then neg, or vice versa. If you happen to have a long wrench that can connect terminals, be very careful not to touch the other one, undo the neg first then. When you work on the positive pole do not touch any metal parts of the body, if you have not released the neg yet, otherwise you will see fireworks with the following fuse replacement.
When the batteyr is disconnected from the terminals the radio code will be lost. If you don't know your original radio code, you will have to go to the dealer and pay $105 for the code. Without that code the the radio will not work unless you have installed other than VW CD player
Jul 16, 2008 | 2000 Volkswagen Jetta TDI
Computers & Internet Logo
114 people viewed this question
David Payne
David Payne
