Question about GE Dryers
The power on/off button does not work - it is out of place
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 47 Answers
Are you sure that it's the power button? Make sure it's plugged in and you have current going to that wall outlet. Then make sure the circuit braker for that part of the house has not switched off. If you have power to the wall outlet, then you'll have to open up the machine to gain access to the switch/button. If you don't think you can do that, then either a friend or a repairman will have to help you. It should not cost much to repair that problem, but check with the repairman 1st, to see ALL the charges that would apply.
Posted on Oct 19, 2013
Computer won't power on
One of 2 things come to mind. Either the power supply if fried or your button is busted. You can check the buttom by opening you units case and removing the front panel. Be careful removing as to not bust the tabs that hold it in place.
Now the start button could be busted either of 2 parts, the front panel or the actual button wired to the unit. Check to see that the nub from the panel is busted or not. If not then your problem may very well be the button wired to the unit.
I don't know the innards to your unit but the button may just sit in place with plastic nubs or screwed in.Make sure you have a back up Button ready before removing as to remember where it wires to exactly.
Most experts will tell the average user not to turn on a unit without placing all panels back in place but that's hog wash if you ask me. Do make sure all wires are snug though. I don't replace the cover until I know it works. (unless it is the panel button. Don't attempt to unplug or plug-in any wires while the unit is on.
I have shorted units by doing doing so but then I was distracted and didn't realize at the moment. Anyway if switching the button for a new one does not work, your power supply is then most likely no good. Unplug make sure to get same exact size with same hook ups sometimes best go with the same model brand etc. Remember the wire placing.
Removing the power supply can sometimes be a little tricky. To start there should be 4 screw on the outside back. Inside may or may not have any screws. Power supplies can run some money cheapest I have seen Is about $60 or so new. A start button should only be a few $. May check with repair shops to see if they have a usable used one.
Apr 11, 2014 | Dell Inspiron 531s Desktop Computer
My phone power button
Depending on the phone the power button needs to be replaced.It's possible that the power button can be re-adjusted.The spring is crooked or fell out of place.
Apr 05, 2014 | Samsung Galaxy Prevail
Power button doesn't work
I'm having the same problem. The power button won't stay in. I've tried gluing it in (hot melt glue), which worked for about a day before it came loose. I might attempt some epoxy to keep it in. If that doesn't work, I'll have to crack it open and will probably short the power switch leads (will probably require soldering).
Nov 15, 2013 | ASUS RT-N66U Dark Knight Double 450Mbps N...
Power button broke gfdn240el1ww
There are two main pieces to the front panel for the GFDN240EL1WW dryer-- the plastic panel and the circuit board. The actual replacement part is: Control Panel WE19M1687. The panel can be purchased for from places like partselect.com or repairclinic.com or Amazon or even EBay, etc. for $100-$200+.
The power button is just a piece of plastic mounted to another piece of plastic; it is not electronic. When pushed, it presses against the circuit board, which then turns the unit on/off. When the power button breaks, it typically means the little plastic button has broken off from the plastic panel. Most likely, the problem is the mount point for the button and the button is actually re-usable.
A cheaper quick-fix is to:
  • Remove top screw from back of the front panel
  • Remove main front knob from the panel
  • Remove screw from behind the front knob
  • Grab both sides of the front panel and push/pull up to remove the panel
  • Disconnect the block connector (power) from the circuit board after removing the panel
  • Locate the power button and mounting position
  • Inspect to see if it looks like you can glue the button back into place
  • Buy a small tube of loctite Stik'n Seal Ultra Universal Adhesive
  • Put some Stik'n Seal on the button mounting point for the power button (be generous)
  • Press the button onto the mounting point and hold for a few minutes
  • Add more Stik'n Seal around the edges of the mounting point and the button mount after you have held the button in place long enough so that it sticks
  • Let the whole thing dry for several hours (instructions on the adhesive say 24hrs
  • If you are worried about the button staying seated while the adhesive sets, you can always try tape it into place
  • When dry, replace the front panel by reversing the steps above used to remove the panel: connect the power block, slide the panel back into place, replace the front screw and knob, replace the top screw in the back of the panel
Jan 23, 2013 | GE DBVH512GFWW Dryer
Advent t9307 power switch not working
Your laptop's power button sits directly on top of a device called a power button board. This is a small circuit board where all power and control buttons interface with your laptop's motherboard. The repetitive use of the power and control buttons can damage the power button board. Repairing your power button means removing and replacing the power button board, which requires partial disassembly of your laptop.
1.Power down your laptop. Unplug the AC power adapter and all external devices from the computer. Close the laptop's LCD panel and place the laptop face down. Rotate the laptop so the front opening edge is facing you. Remove the battery pack from its compartment on the laptop's bottom side.
2.Flip the laptop over, and pull open the display panel as far as possible. Use a thin, flat-head screwdriver to pry the keyboard cover from the laptop. The keyboard cover is the plastic piece situated above the keyboard assembly that houses the power button board.
3.Lift the keyboard cover out of the laptop slightly, and disconnect the cables extending from the power button board to the motherboard. Remove the keyboard cover from the laptop.
4.Place the keyboard cover face down on a flat surface. Remove the Phillips-head screws fastening the power button board to the cover, and remove it. If your speakers are situated inside the keyboard cover, disconnect the speaker cables from the power button board before removing it.
5.Place the new power button board inside the keyboard cover. Align the screw holes on the button board with the holes on the keyboard cover. Replace the Phillips-head screws fastening the button board to the keyboard cover. Reconnect the speaker cables to the button board, if necessary.
6.Reconnect the power button board's main cable to the motherboard. Place the keyboard cover back inside the slot above the keyboard assembly. Press down on the cover until it snaps into place. Replace the battery pack and reconnect all cables.
Sep 06, 2011 | Computers & Internet
My power button is not working means my laptop power button is not working proprely i mean its not Restarting
what kind of problem thoes you mean you press power button and your system shuts down in place of restarting
Jan 04, 2011 | Acer Computers & Internet
Hi, I have purchased the model aspire 5738. The problem is the power saving button at top-right corner does not work and also the key fn+f2 is not working. Please help........
I assume that you purchased this used? If you bought it new, find the receipt and return it.
If used, I'd suggest finding a new keyboard and installing it. I'm gonna take a leap here and tell you that the power-saving button is on the strip above the keyboard with the start button and speakers? This piece typically needs to be removed to get to the screws that hold the keyboard in place. Look to see if the wiring that powers the p-s b is in place. Check this by powering up the computer with this panel removed. This will tell you whether or not the wiring is the problem. If the wiring is working, then check the back of the button on the panel to quarantee that the button on the panel reaches the button on the motherboard, or whatever circuit board the p-s b is placed on.
Dec 18, 2009 | Computers & Internet
Hi my printer has te E2/E7 error code on it and i tried resetting it !!! well unless i am doing it wrong!! it isnt working!!! this is how i am doing it with the printer off press the resume button, while...
This is the procedure but not each time waiting for the carriage to return to original place.Just press resume button 4 times consistently.Then press the Power button and the printer should turn off, if not, press the Power button once more.Your printer should respond as normal.
Nov 08, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Power button gone
the best help u can get is from the service center of the camera.
else do one thing.
as am from india i dont know what place is the HUB to buy any kind of electronics items near your place.
if u go to that kind of place where all kinds of electronics goods like computers, digicams, electronic components, etc etc...
there they would take the power button from any other old camera and fix it in yours.
but one thing is u dont need to prefer for a new button. old one will work fine. even inn service center they have old buttons. so try in service center first. then try in shops.
Dec 20, 2007 | Fuji FinePix A345 Digital Camera
Dryers Logo
47 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
