Question about Kenmore 600 7965 Dryer
How and what do I have to remove to be able to replace a hidden switch lid on a Kenmore 600 washer?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 47 Answers
1st, you'll have to remove the top section that has the controls by removing the screws from the back that attach it to the main body of your machine. Then, you should find the screws or other devices that keep your lid attached to the machine, and be able to remove it, gaining access to that "hidden switch".
Posted on Oct 19, 2013
2 Suggested Answers
  • 1891 Answers
SOURCE: I have a Kenmore 70 Series Washer. The lid switch
Bob your an the right track.. remove the two screws ( unplug washer ) pull sw from mount and the wires will folow. they are hooked to a wire clip . with it in hand you can see if sw is cracked or broken .. the new sw will come wire& plug/ you can splice it or remove wire harness and reinstall as you took it appart . the 70 series has a lift up top / two clip in front / use a putty knife . ..mm
Posted on Dec 04, 2009
Testimonial: "Was able to replace the sw & harness all in 1. Only had to splice grnd wire because I was not able to raise the the top of the washer as u suggested."
My washer stalls at the end of the wash cycle and I can hit the lid with my hand to restart it
Sounds like your lid safety switch is bad. Replace the switch. If this is a unit with a hidden lid switch, left rear, you may only need tighten your lid hinge screws.
Jan 01, 2015 | Kenmore Washing Machines
How to remove top of kenmore oasis washer to replace lid lock mechanism
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 18, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Lid switch on a 20802 kenmore washer
Check the video at the following link and see if it is of assistance to you in changing out the lid switch. Sure hope so and best wishes.
http://www.youtube.com/watch?v=fC8SY3cU1Yc&feature=PlayList&p=A8EAB62928245279&playnext=1&playnext_from=PL&index=61
Sep 25, 2009 | Kenmore 24032\24036 Top Load Washer
How to replace kenmore elite washer model 110 16962503 lid switch
Let me offer you a generic solution for most of the Kenmore washers :-
There are 2 screws that secure the console to the cabinet top. The are located in the front or rear corners, and on a Kenmore, may be hidden behind the end caps. Remove the screws, and tilt the cabinet backwards. Remove the 2 gold clips, and disconnect the wiring harness. Tilt the cabinet forward, and off of the base. The lid switch can now be accessed from inside the cabinet (I sit inside).
Hope i helped you.
Thanks.
Aug 14, 2009 | Kenmore Washing Machines
I have a Kenmore Oasis HE 27082 and the lid lock bolt broke. How can I replace it?
5
6
7
You can access the lid switch at this point.
Mar 22, 2009 | Kenmore Washing Machines
I need to replace lid switch on Kenmore washer.
remove trims from edges of control panel
remove screws from under trims
rais and flip control panel over backwards(hinged at top) do not dislodge air hose to level sensor
remmove brass clips from washer body top, not position for reinstall
disconnect lid switch connector cable
lift and remove entire body
turn upsidie down
change switch
reassemble in reverse order
~20minutes
Oct 02, 2008 | Washing Machines
KENMORE 80 SERIES
Open and close lid, listen for 'clicking' sound. If no 'clicking' sound, replace lid switch. If this washer has a hidden lid switch, check the lid hinge screws and make sure they are screwed in tight.
Jun 01, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series
First thing is to remove the 2 screws from the console, they may be hidden in the front or bacl of console. After removing screws, lightly push the base of the console towards the front of the washer and pick up. This will expose your lid switch connection. Using a jumper wire, jump out the black and white wires then try advancing your washer into spin/drain. The culprit will usually be the lid switch assy.
Apr 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 60 series washer
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Dec 07, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore 600 7965 Dryer Logo
67 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
