Question about Dishwashers
Aeg favorit 40740 sensor logic dishwasher Not heating up
FYI: I ran in a similar situation with my Ikea dishwasher last week.
It started did some stuff but ended early and cold.
In the end it was just because I forgot to refill the soda.
The drain was all clogged together. A quick cleaning fixed my problem.
Only afterwards of course I noticed that an LED was on and there where some white deposits on the dishwashers lid. There was also still some water when I opened the dishwasher.
When I was reading about similar problems, it also happens often that some solderings of the relay go bad. A more or less practical person can check and solve this rather fast. (Because I didn't notice the clogged drain at first, I verified mine in let's say well below 30 min, they seemed fine)
I hope you get your problem solved.
Posted on Oct 21, 2013
SOURCE: AEG dishwasher not heating
Had simlar problem. It was the Program module. If yo open the program module you may see a burn track. Resoldering also ddid teh thrick
Posted on Nov 09, 2008
SOURCE: AEG Favorit 40650 dishwasher is
Remove the controller from the top of the door. Extract the main PCB from the plastic case. You will probably see a burn mark on the inside of the case adjacent to the relay on the back of the PCB. Examine the back of the PCB for burn marks around the relay pins. Resolder the relay and any damaged track.
Posted on Nov 11, 2008
SOURCE: AEG DISHWASHER, DOES NOT HEAT WATER.
I had this same problem on our AEG dishwasher. The reason was on the controller board. There is one relay switch which drives the heater element.One of the legs of that relay box was disconnecteds from the circuitboard. Check this out.
Posted on Dec 09, 2008
  • 132 Answers
SOURCE: Wont heat or dry dishes
USUALLY THER IS A SENSOR ELEMENT FOR HEATING TEMPERATURE MAY BE FUALTY ..
TRY IT ..
THANK YOU
Posted on Jun 14, 2009
BIKER T
  • 909 Answers
SOURCE: AEG Favorit dishwasher AAA shows Error code 10
Normally if washer doesnt complete cycle, its because the element has tripped the over temp.th/stat.(underneath), or is faulty. otherwise 1 of the 2 boards are faulty. Often the board at the bottom front left.(behind the kick panel.)is the issue. Roaches seem to accumulate on the bottom board and disrupt the circuit. If you have a mechanical timer, wiggle it side to side and note if there is a difference.
Posted on Sep 16, 2009
Aeg dishwasher dont worm the water
Could be:
- heating element
- thermostat or NTC sensor
- wiring
- electronic or timer
Dado
Jul 05, 2014 | AEG 24 in. Favorit 3A Free-standing...
I30 message on aeg favorit 50879 u
Activated Anti-flooding system, means water leakage in the buttom of dishwasher. Could be also: faulty Anti-flooding microswitch, floating sensor (styrofoam) blocked mechanically, wiring diagram, electronic.
Dado
Jun 17, 2014 | AEG 24 in. Favorit 40850 Free-standing...
Problems disconnecting the wastepipe on an AEG Dishwasher
Pour some bleach into the stinky backwash. I know that this is not good for the environment but it will take the stench away while you get a new dishwasher. Sorry but you have plumbing problems out of my range.
Oct 25, 2012 | AEG 24 in. Favorit 80800 Free-standing...
AEG Favorit Integrated Dishwasher failing to heat the water. has the element gone? and how do you get at it?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Mar 23, 2011 | AEG 23 in. Favorit 50750Vi Built-in...
Water not heating on AEG Favorit 40850.have replaced heater but still not heating.any suggestions
I too have had this problem. I switched to the hottest setting from the economy one and it heated again. Once I switched back it was OK for sometime but has started to do this again.
Jan 30, 2010 | AEG 24 in. Favorit 40850 Free-standing...
TRY IT ..
THANK YOU
Jun 14, 2009 | AEG 24 in. Favorit 40630 Free-Standing...
Sep 25, 2008 | AEG 18 in. Favorit F54850 Slim-Line...
AEG Favorit 50730 Dishwasher
The dishwasers have heat (inductive) elements in line with the top sprayer hose and is about +/- 15 cm long and has an electrical push on clip at the side of the device.
Oct 26, 2007 | AEG 24 in. Favorit 50730W Free-standing...
Dishwashers Logo
111 people viewed this question
Top Dishwashers Experts
Owen Barnes
