Question about Fisher Washing Machines
Replaced the control module on fisher paykel washer, now it just beeps
  • Fisher Expert
  • 554 Answers
Did you follow the sizing procedure that come with your control module. On the 8 wash progress lights can you tell me witch ones are on when its beeping.
let me know the model of the machine.
Posted on Dec 14, 2013
4 Suggested Answers
SOURCE: Fisher & Paykel GWL11 Top-Load Washer troubleshooting
I've had my washer for about 8 years. I experienced the same problem - pump stopped draining the machine. I called F&P and "Patrick" told me that I need to 1) unplug the machine, 2) tilt up the front of the machine, 3) spin the pump (plastic blades) until they turn freely (usually counter clockwise) but I turn it both ways till it turns freely, 4) plug the machine back in and press the buttons to get it back where it was - this has worked every time to get the machine going again. I do a lot of "dog laundry" and I'm sure the rugs/dog hair cause the problem. Hope this helps!
Posted on Nov 16, 2008
SOURCE: Fisher & Paykel washer IW712: fault code 105
Fault codes sheet is located under the dryer control cover.
Fault Code 105 Communications Error Time Out - I&A
Communications failure between the sensor module and display module. (loose wire). 1).Visually check the contacts on the RAST (edge) connector at each end on the harness between the sensor and the display module. 2). Replace sensor module and/or display module and/or harness.
Posted on Dec 12, 2009
  • 343 Answers
SOURCE: what is error code 136 on a fisher & paykel IW...
136 fault is 'motor stall'...Quite often this is a broken wire to the motor. However it could also be a Motor fault, or Rotary Position Sensor problem. Water damage can cause this fault as well. After a visual check for broken wires or water damage, and if your machine is in good condition, you should consider a tech....Good luck...Nomess
Posted on May 24, 2010
Intuitive type. error code 241 appears what does this mean and can i fix it myself
Hi i googled error code on fisher and paykel and found this link-->
http://www.searspartsdirect.com/washer-repair/error-codes/fisher-paykel-aquasmart-top-load-washer-error-codes.html
If you scroll down the page in the link the error code 241 says
"Motor control module failure", Unplug the washer and replace the motor control module. OR
"Display module failure", Unplug the washer and replace the display module...... Good luck...
Mar 11, 2016 | Fisher and Paykel Washing Machines
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
Service error 60,IW509NZ
60. (00111100) Motor Control Memory Check Fault
On power up, the Motor Control Module has checked its memory against a known reference and found differences.
Primary Source: Motor Control Module Module. Action: Replace Motor Control Module.
Jul 08, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykal MW512 turns on multiple beeps then turns off
This kind of problem is usually related to a faulty display module, or faulty motor control module (Computer isnide of control panel compartment)
Without spares to change and test with, you wont be able to diagnose 100%
Usually when there is a problem, a series of lights go solid on the control panel and the machine beeps to alert you to a problem and this is a fault code, but if nothing is showing at all, then I have to lean towards the display module underneath the touchpad. Especially considering it wont illuminate.
Nov 22, 2012 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel Smartdrive MW058K error code 106
106. (01101010) Display Module to Motor Control Module Communications Error
These faults are reported when the Display Module detects an error in the communications
between the Display Module and the Motor Control Module.
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Jul 23, 2012 | Fisher and Paykel Fisher & Paykel Washer
My fisher & paykel GWL 15 washer, began to intake water in a few intervals ( one second ) in and out.Then it stop and make a beep every seconds and the first light at left is on( in washer proces
It could be fault code130
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Tertiary Source: Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
Apr 26, 2012 | Fisher Paykel EcoSmart GWL15
Fisher and paykel GW509 won't power up, pump not blocked, plug loose?
62. (00111110) Phase 5 - Pump Over Current
The Motor Controller module has detected an excessive pump current.
Primary Source: Pump.
Action:
Replace Pump.
Secondary Source: Motor Controller module.
Action:
Replace Motor Controller module.
107. (01101011) Phase 2 to 6 - Motor Controller module Reset Error
The Display Module has detected that the Motor Controller module has reset when
it should not have. This can be due to a Motor Controller module supply
disturbance or microprocessor failure.
Primary source: Motor Controller module.
Action: Replace Motor Controller module.
Red, Blue, Yellow go on the motor
Brown , White go on the pump.
Apr 13, 2012 | Fisher and Paykel Fisher & Paykel Washer
My Fisher and Paykel IW810AU has stopped mid wash full of water and just beeps constantly and flashes message I need Service Fault 105. Have turned it on and off at the wall with no change. Please help.
Hi, the faults 105 is reported when the Display Module detects an error in the communications between the Display Module and the Motor Control Module.
The primary source of the problem is the Pump and you have to measure resistance of pump. If resistance is less than 33 ohms, replace pump.
May 16, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Spin Led stays on and beeper beeps
this spin light that is on is a fault code no:1 which means the electronic motor control has a memory problem solution replace motor control module ... hope this helps..:0)
May 24, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
