Question about Samsung SP-R4232 42 in. Plasma HDTV
Screen flickers - Samsung SP-R4232 42 in. Plasma HDTV
My aspire 5830t screen flicker at startup
I suspect the backlight or inverter may be faulty. Check on flea bay for replacement prices.
Dec 21, 2013 | Computers & Internet
Lg tv gray screen main menu screen flickers
tats something in the board its self youll have to take that to a tv repair man
Dec 06, 2013 | LG Televison & Video
Hp g6000 screen
Please explain the events that lead up to your screen flickering ... in detail, from the time you turn the laptop on. Does the splash screen flicker?
Sep 07, 2013 | Computers & Internet
My laptop screen flickers in and out, screen goes black
Hello there,
The reason the screen flickers is simply because the module of the laptop is faulty. The module is what connects the screen to the main board, it is like a flex for the screen. Once you can have it replaced, the screen will stop flickering.
All the best Elect_Comp
Sep 13, 2011 | Acer Computers & Internet
Acer Laptop Screen Flickers & Jumps
Please connect the laptop to an external monitor. If no flickering on monitor screen, from my previous experience, this is more likely loose connection of video cable connected to the LCD. So talk to Acer support again and require the replacement of LCD.
CompQ
May 11, 2010 | Acer Aspire 6930-6082 Notebook PC
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
Acer notebook aspire 5102 WLMi screen flickers
Hardware, sound like the cable that attach to LCD panel was losing...
Nov 17, 2008 | Computers & Internet
Flickering screen of my lifebook s series
This sounds like a loose connection. If you can press on the back of the lid and it flickers or stops flickering, then it's definitely a connection problem. You will need to take the bezel around the screen off, the screws are hidden under small sticky tabs or the small rubber bumpers. Then take the screen loose and check the connection on the back. Replace the tape on the cable, if there is any.
Aug 02, 2008 | Intel S6240 Notebook
Screen flickers
yes i have had this problem before
the propper signal isnt getting to the screen from the mother board
has anything been spilt on the screen or the computer its self
i would suggest taking it to a tech they should be able to fix your problems
Jul 19, 2008 | Computers & Internet
Lcd Flickering
Sounds like the driver board for the backlight is going bad...is there a spot on the screen part of the case ( usually at the bottom) that feels much warmer than the rest?
Mar 16, 2008 | Gateway 450ROG Notebook
Samsung SP-R4232 42 in. Plasma HDTV Logo
18 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
