Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
Hoshizaki undercounter 15" tophat cubes Condensation seems to be forming on the outside of the water bin. The condensation is dripping into the ice storage compartment causing the ice to melt.
  • 45 Answers
Are you sure its condensation and not water flowing over the top due to being unlevel, or pan cracked
Posted on May 22, 2014
4 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: Water leaking onto ice and outside panel on Hoshizaki KM-500MAE
Remove the cover where the persons finger is and check to make sure that it is not covered with ice. Sounds like your machine iced oup and you will need to clean the coils and possibly replace the thermostat
Posted on Feb 12, 2009
farfield
  • 462 Answers
SOURCE: Ice Cubes won't drop
Something is holding your Ice Slab at the bottom from your description.
Some causes are
1 Dirty - scaled up evap, or just dirty w muddy covering,
2 the vacuum breaking holes are stopped up If it is making a sla whith the evaporator warm no ice take a flashlight and hold it where its shining to the back of the evap and look for the light on th cube forming slots next to the ones your shining the light into Upper corners of each hole must be open.
3 The slab is freezing uneve most like cause is a stopped up distributor tube at the top thats feeding the water down the evaporator.
4 On some models thay had a closer fitting water curtian (the cover in front of the slab) and the top of the sheet touched this and caused the slab to stay uprite and continue the "slide" forward.If your curtian is of the older style and has metal hooks on it with verticle slots n the curtian look at the slots and see if the slots are worn making the whole curtian slide down ward I have seen this several times.4B On some older models there is also a plactic coated wire diverter on the bottom infront of the evaporator. If the palstic coating is gone or the bottom or is not even, the slab could hang up there. 4C If you have the newer plastic pins make sure thay are seated in the mounting properly.
5 Nickel plating could be comming off (any copper color on the lower 1/3 of the evaporator?).
6 I have seen some of the horizontal plates them selves be loose and not in flush try pushing and pulling on them especially the ones at the bottom. ANy that are loose and comming out is your problem.
This lengthy extrapolation is by no means all of the possibilities but most of the common ones. If this helps you solve your proble please rate me accordingly. If it leads you to the correct and completed repair WOULDNT WE MAKE A TEAM?? And Good luck to you.
Posted on Mar 18, 2009
bobicehouse
  • 1524 Answers
SOURCE: Too much water over grid and ice cubes or melting cubes
Change the float.
Posted on May 28, 2009
I have a Hoshizaki Machain and it is leaking water above the door on the left side running down to the left leg when standing in front of the machin, what cause this to leak?
IF you are talking about a freezer, make sure the unit is level as the condensate pan may be overflowing. Also, if the door does not seal properly, it can cause "Sweating" as cold air is escaping and causing condensation at the door. Start with that first.
Sep 10, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Machine runs for 10 minutes than switchs to harvest before cubes are formed
Usually a condition of low water in the tank. Other condition is the float switch is set wrong. Could have clogged water filters causing low water condition.
Aug 14, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Km500mae never shuts off
this is easy to fix first you need some food grade hose next put this hose in the bottom of your ice bin then run you water through this hose to the machine fit as much hose as you can in the bin floor and start the machine at night and the other thing you may wish to do is get a remote condenser
Apr 22, 2010 | Hoshizaki Freezer Commercial Ice Machines...
3-door undercounter refrigertor worktop surface
the coils that deliver the cold air are building up condensation. anything that gets cold in the outside should be insulated so as to reduce condensation. hope this helps
Sep 15, 2009 | Everest Refrigeration Freezers
Feb 12, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Please Heal
starving for water. clean or replace water filter or adjust water float assembly that determines how big cubes are. probably not getting abundant water during timed fill sequence. no water equals little ice.
Sep 20, 2008 | Hoshizaki Freezer Commercial Ice Machines...
KM 280MAH
Check the condenser if it is restricted in any way it will decrease ice production. Check for water overflow from the sump. Any more water than necessary entering the sump will also cause a decrease in ice production.
Sep 04, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Ice Maker
check condenser condition can be dirty, cleaning the coils with coil cleaner for ice machines(i suggest you take all the ice out of bin first) i'd go with that first. check if it works for you.
Mar 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
111 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
