Question about Kitchen Ranges
Stove top is working bot the oven - Kitchen Ranges
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number?
Posted on Oct 26, 2013
SOURCE: Amana gas range ARGS7650 oven not working, stove top working
check clock has not accidently been switched to Auto this can also happen if someone has interupted the power supply
Posted on Dec 26, 2007
aborcass
  • 2651 Answers
SOURCE: premier 30 inch gas stove oven does not light
do you hear any clicking when you try to start the oven portion of the range? if not lets try this, open the lower drawer so you can see the burner bar and mechanism for lighting the bake bar. as your watching the mechanism turn on the oven (nothing should happen as per your issue) while oven is on try lighting one of the top burners, any one will do wanna check if that lites the spark and in turn lites the oven pilot.if that does infact work you have a bad spark switch for the oven control
Posted on Oct 29, 2008
tatunka
  • 85 Answers
SOURCE: oven not working (lighting) on magic chef stove top/oven
look at the burners in the oven,they usually go bad where they hook to the unit,it will look like a peice is missing.if this is not the case, a wire is loose in your breaker and you're running on 110 instead of 220
Posted on Nov 14, 2008
  • 126 Answers
SOURCE: GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Posted on Jan 02, 2009
RepairClinic
  • 32 Answers
SOURCE: I have admiral Stove top burner is workni but oven is not working
This may be due to a bad main clock/electronic control but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Admiral Stove Parts: http://www.repairclinic.com/Admiral-Range-Stove-Oven-Parts
www.RepairClinic.com
Posted on Feb 03, 2009
Why would there be no heat from frigidair oven elements?
Make sure the oven timer is set properly, if its turned off, the oven will not go on. Also check if the oven has separate fuse, it may have blown.
Aug 24, 2014 | Frigidaire Stove/Oven/Range Black Glass...
Need schematic to hook up my new oven control on a whirlpool wrp 37680 stove ,,kids screwed up my set up over the week it took to get part
Could not find that model. Please check on machine, Does the control have 6 connection points on it? 2 on top sides 2 bottom sides and 2 on bottom? If so The top two are the power Bk and Rd. the left bottom is bake and pilot. Bot.left is broil Bot rt is the other bake Left bot is broil and pilot.
Nov 22, 2010 | Whirlpool Kitchen Ranges
WE have a GE Stove top Range. The burners aren't
If you have power to the stove as in the oven light works and the clock works but the burners and oven will not work you only have 120 volts coming to the stove. The stove requires 240 volts for the burners and oven to work. Check the service panel for a blown fuse. There will be 2 fuses in the fuse holder. One of them is blown. If that is not the case then one of the wires has come loose either in the service panel or in the outlet behind the stove. Use a multimeter to check the input voltage at the outlet.
Apr 25, 2010 | General Electric Stove/Oven/Range Chrome...
Water spilled down the stove top causing the oven
ater spilled (4-5 cups) on the stove top running down into the stove control panel face (where you view oven temp, timer, etc). No water ever dripped into the oven or oven window. The stove top still works but the oven, warming drawer, clock are all non responsive after three days. No buttons on the control panel work at all. What repair is needed?
Jan 06, 2010 | KitchenAid KDRS807SSS Dual Fuel (Electric...
Can't start oven. Stove top works fine. Maytag
top burner burnt out we replaced it with a new one and it still doesnt work please help? Ron
Jul 09, 2009 | Kitchen Ranges
Does stove-top need downdraft if microwave has oven-hood combo?
We have a stove with no downdraft, and a microwave with a hood above it. It works just fine. I expect you could keep your downdraft and put a microwave without a hood above it, and that would also work. I don't think, however, you can buy an above the range mocrowave oven, that slides in on brackets, which will not have a hood.
Jan 08, 2009 | Microwave Ovens
Stove top works oven wont heat on 465
the ignitor needs replacing, that's the glow that you see. it's not getting hot enough to open the safety valve.
Dec 07, 2008 | Whirlpool GS460 Gas Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
