Question about Victory URD-27-SBS Stainless Steel
Samsung RS 277 ACPN refrigerator temp light flashing on and off; showing a temp of 36
Refrigerator temperature light is flashing
Replace the temperature sensor. Here is the part to order.
The sensor is located on the coils in the freezer.
Nov 24, 2012 | Samsung RS2556 Side by Side Refrigerator
SAMSUNG RS275 REFRIGERATOR SOLUTIONS
Yes. check the thermostat. mine done the same thing.
Sep 01, 2012 | Samsung Refrigerators
How do I increase the refrigerator temp in a Samsung fridge RF267AE. The reccommeded temp is 38 however mine is currently at 36 and items in the back are freezing
you should only have to press the button up to change the temperatures, if that does not work the display board on the front will need to be replaced to fix the issue, let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Samsung RF267AE (25.8 cu. ft.) Bottom...
My Sub-Zero is flashing error code 36. What is this?
Diarmait --
Technical Service Manual for the SubZero 600 series can be downloaded at:
[https://docstore.fedex.com/subzero]
Username=subzero
Password=subzero
Write back if you still need help.
-- SWT
Aug 23, 2010 | Sub-Zero 650 / O Bottom Freezer...
SubZero 650 - fridge 36 to 50 deg, vac condensor light flashing
Hi!! you have a seal system problem.A leak in the evaporator..
Dec 26, 2008 | Sub-Zero 650 / O Bottom Freezer...
The display unit keeps flashing on the fridge side on my samsung RS20CCVS.
When the temperature indicator flashes indicate then the temperature has ridge a level lower the the set temperature for example if you set you fridge side to 36 degree and and has fail to stop from getting cooler and has ridge 34 degree. some times those friges fail to calibrate them self tray by unplugging you dirge for 30 seconds and replug it then the board will auto calibrate for the next 24 hours If this problem comes back again that meas than your defrost element on the fridge side is bad.
Dec 05, 2008 | Samsung RS2578BB Side by Side Refrigerator
Samsung refrigerator rs 2534ww
Samsung freezer.
The freezer temp will not go back to the temp it was originally it keeps dropping back 15 degrees below to what i set it.
Sep 04, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Victory URD-27-SBS Stainless Steel Logo
57 people viewed this question
Top Victory Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Victory Refrigerator Expert? Answer questions, earn points and help others
