Question about Goodman GPC1342H21A Air Conditioner
How much freon will a Goodman air unit (model # GSZ130301AZ) hold?
  • 107 Answers
108 ounces is factory charge
Posted on Oct 19, 2013
4 Suggested Answers
  • 2418 Answers
SOURCE: i have goodman CKL49-1, air is not blowing, the
Your evaporator fan motor has quit. You need to find out if it is a relay or the fan motor. These systems come in various different setups. Updraft (vertical) or lay down (horizontal) you have to gain access to the motor and get it out. Turn off all power to the unit, look for any breakers at the panel. open the panel usually the same panel to access the filters. The motor and squirrel cage fan, will come out as one. look closely for rails at the top to slide the motor and cage out. Your wiring should unplug from the top close to the capacitor. you then can unbolt the motor - take pictures so you can reassemble it. Take the motor to a local HVAC store for a match. Be sure you get a new capacitor to go with the new motor.
Posted on May 04, 2010
  • 53 Answers
SOURCE: goodman air conditioner tag model is CK36-18,
sir you have a 3 ton unit
Posted on May 17, 2010
  • 9 Answers
SOURCE: looking for freon capacity for 5 ton goodman
check low side which is the bigger of the two, make sure you tighten the hose good. your reading should be 65 psig.If not add refrigerant/r22 . if r410a 110 to 115.
Posted on Jan 14, 2012
On a cpkj 48-1B Goodman heat pump I am having condenser fan issues. runs full spedd for a while then cuts down to barely running, Even after changing the motor and capacitor.
Does the condenser utilise head pressure control to maintain head pressure? if so is the unit fully charged...r22. r410 Freon.If the unit is an older model. the fan motor only runs at 850 r.p.m design flaw. The newer units now run the fan at 1075. R.p.m. I have installed many Goodman split systems and was having problems similar to yours. Hope this. Helps you
Jul 11, 2015 | Goodman Heating & Cooling
Why is suction and discharge lines of Goodman WMC24-1A split ac system freezing up.?
Low on freon, dirty evap, dirty filter or maybe restricted at the metering device
Jul 20, 2014 | Goodman Heating & Cooling
Bad condenser unit GOODMAN
it is a 3 ton condensor you still can buy r22 freon condensors new but they have nitrogen charge and its expensive to charge I recommend to go with 3 ton goodman condensor which is new 410a puron and also change indoor coil and flush the line set so you dont endure the high cost of new copper lines these new systems come with 10 years warranty and the r22 systems come with only five years
Feb 26, 2013 | Heating & Cooling
I have a goodman Model CKL 36-1K . It says Factory Charge oz R22 . Does that mean it uses R22 freon? The guy who sold it to me says it uses 410a and was only 2 or 3 years old. The serial # is 040637071 ....
Hello, the unit is a 3 ton and was built in 2004. 0z R22 stands for R-22 refrigerant. Not sure why he told you 410a but if the unit says R-22 than that must be used.
Jul 06, 2012 | Goodman CKL36AR36 Air Conditioner
My AC unit model is CPLE60-1. It is running, blowing cool air but not cooling house. Any Suggestions? and what is the life expectancy of this unit?
Your Goodman unit is a five ton and should last 15 to 10 years with proper maintenance. Parts do wear out though during the normal life of piece of equipment.
Cooling problem may be due to low charge, broken ducting, or other low airflow problem. Need to verify freon charge and then go from there.
Jul 27, 2011 | Goodman CKL36AR36 Air Conditioner
1 1/2 ton goodman outside unit made a hissing
Hello Scott,Your new ac is OVERCHARGED with freon.Shut it off,let it cool down and recover/remove freon.The compressor has an internal pressure valve that makes the (hiss).It will stop when the charge is adjusted.Call them back to do it.
Jul 31, 2010 | Goodman CKL36AR36 Air Conditioner
Looking for freon capacity for 5 ton goodman package unit, cannot read serial or model number.. unit is 1998-2000 model ,, we just replaced the accumulator and we are not sure how much freon to put in.....
Apr 14, 2010 | Goodman GPC1342H21A Air Conditioner
Goodman GPC1342H21A Air Conditioner Logo
91 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
