Question about whiterodgers White Rodgers 1F95EZ-0671 Emerson Blue Easy Reader Thermostat
Blue easy reader thermostat 1F95EZ-0671 .... My unit no longer displays the "HEAT" option. and how do i reset it to the factory settings, i want to run it manually. The manual does not tell you how to go from program mode to manual mode
Won't let me put in seperate set points for cooling and heating. I reset to fac setting, it used to let me have 2 settings.
www.ask.com/mfg.name/make/model#/
/setup_procedures/
/program_instuctions/
/optional_settings/
/discription-of-settings/
/additional_settings/
by reviewing your information that you provided you state that the unit in a non-programmable unit, that means you have to use the pre-set options, they cannot be changed, only someone that is a programmer, if you want a programmable unit than you should buy one, because every time something goes wrong you have to re program the unit. good luck
Sep 17, 2015 | Robertshaw 9500 Digital Non-Programmable...
Tip
Lux Thermostat 500
The Lux 500 Thermostat is an affordable programmable thermostat that gives you a very easy way to customize your heating and cooling temperatures to your schedule. The programming of this thermostat is easily the simplest that I have found in a programmable t-stat.
The Lux 500 series thermostats are a great economical way to reduce energy and utility expenses by raising or lowering your temperature settings a the times you set. The installation is so easy that most any DIY’er can install this thermostat. It has an easy to read display and the rotary dial makes the programming very user friendly.
A few of the other great features of this unit are, a keyboard lockout, and an air filter reminder.
This thermostat can be used on any 24v AC or 750mV single stage conventional heating/cooling system. Single stage heat pumps without auxiliary heat will also work with this thermostat.
Here is a summary of the features of this thermostat
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
  • 5 - 2 Day programming
  • 4 Periods per day
  • Large easy-to-read display
  • LUX patented user-friendly Speed Dial®
  • Filter usage monitor and alert
  • Default Energy Star approved program
  • Temporary Temperature Override
  • Temperature Hold
  • Keyboard Lockout
  • Temperature Calibration
  • Swing Settings #1 - #9
  • Fahrenheit or Celsius temperature Scale
  • 12/24 Time Format
  • Low Battery Warning Indicator
  • Mercury Free
As you can see this thermostat will give you a lot of great features at an affordable price.
on Jan 16, 2010 | Heating & Cooling
THT - 160B DVD player
Contact the mfg of the player for the hidden code or sequence that will restore your unit to factory defaults.
Sep 10, 2017 | Televison & Video
How to reset password on Sony Ereader. Daughter set it and forgot it. Unable to use. Thanks in advance, Tim
This is the only way if you can't remember the password.
Here's the procedure for resetting the device back to factory default:
Note: Performing this procedure will delete any content you have stored on the Reader.
1). With the reader off, using a paper clip or similar device, press in and hold the Reset button on the back of the unit for 5 - 10 seconds.
2). Release the reset button and power on the reader.
3). While the reader is booting, press and hold both the Volume Up and Mark Buttons. Continue holding until you see a screen asking you to confirm that you want to reset the device back to factory default (Press Button 5). Note: I had to hold down these buttons for about 60 seconds to get the confirmation screen. Also about half way through this process, you should see a blue light flash momentarily around the lower left Page button.
4). After you have confirmed you want to set the device back to factory default, the reader will turn off. Turn the unit back on and it will go through its initial start up which takes a minute or two.
Hope this helps, Thanks for using FixYa
May 15, 2011 | Computers & Internet
When the mode button is pushed, I only receive the option of dehumidifying, or just fan. The manual claims it has a heat option but it is not available. A friend of mine has the same one and they have the...
Sorry to read about your problem, I hope this helps you out.
Their has to be a model difference issue . I have checked the Manuel and have put a copy of the section, for modes. and their is no heat only mode.
Your unit uses heat anyway, so i really do not know how, heat only would help you. I would say to look at the sticker on your friends model, and see if the numbers are exact.
Default Setting:
When the unit is first connected to a power supply, the electronic circuit board will automatically default to the following factory settings;
Mode: Dehumidifier Humidity Set Air Value:60% RH Fan Speed: = Low
NOTE: In the event of a power failure or the unit is switched 'Off', the most recent settings are retained and restored once the power is switched "On"/resumed.
IMPORTANT NOTE: Depending on the ambient humidity conditions, when power is restored or switched 'On' the dehumidifier may not start automatically under the factory or custom (see page 7) default setting. This is an indica- tion that the ambient RH% level of the surrounding envi- ronment is lower than the current default setting and it may be necessary to select a lower set RH% value.
DRY MODE SELECTION: 1. The unit does not have to be switched on (opera- tional) to select/set a program. All programs can be selected with the unit in the "off" position.
2. Press the MODE button until the Dry symbol is shown in the mode area of the display. Note: Each time the MODE button is pressed, the setting will alternate between DRY (dehumidifier) and FAN (only) mode.
3. Press the or cursor buttons to select the desired RH% operating value. To select CONTINUOUS operation,pressthe buttonuntilthesymbol"--" appears in the SET AIR display. During CONTINUOUS mode operation, the humidistat (control) will be by-passed and the compressor will operate non-stop regardless of humidity conditions.
FAN SPEED SELECTION:
4. Press the fan symbol on the keypad. Each time the button is pressed, the mode selection will alternate between "High Fan" and "Low Fan" speed options. The fan speed you select will appear in the LED display; either a 4 blade fan symbol for 'high fan' or a 3 blade fan symbol for 'low fan' will be shown in the display area.
5. When all settings are complete, press the I/O button to start the selected operation (MODE) and the blue opera- tion light will illuminate.
FAN ONLY MODE SELECTION:
1. Press the MODE button until the fan blade symbol is shown in the mode area of the display. 2. Press the "Fan" symbol on the keypad. Each time the button is pressed, the mode selection will alternate between "High Fan" and "Low Fan" speed options.
3. When all settings are complete, press the on/off button to start fan mode operation and the blue operation light will illuminate.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Danby DDR586R Dehumidifier
New heat pump system freezing, questioning wiring.
W1 and E on stat need tied together. When W1 comes on wire where all heat elements come on. On the outside unit defrost board set the 45-60-90 to 45 and see if that takes care of the frost problem.
Jan 03, 2010 | Heating & Cooling
Gas heater short cycles
At your indoor unit, look at 1 of the front panels and see if there is a clear, plastic view port. Look through it and try to see a red flashing led. Count the flashes and look at the factory data on the front of the unit. That should give us a trouble code and lead us in the right direction. Also make sure air filters are clean.
Aug 25, 2017 | Honeywell Electronic Programmable...
Hunter 44100A programmable thermostat
Yes you will need the orange (o) wire for the reversing valve in your heat pump. T-stat color code is red (r) for 24v power from transformer. Blue (x or c) is the common or the other 24v power from transformer and this will power your programmable t-stat. Orange is for the reversing valve that will switch your heat pump from cooling and heating. Green (g) controls your inside blower. Yellow (y) brings on your outside unit. White is your backup heat.
Sep 28, 2008 | Heating & Cooling
whiterodgers White Rodgers 1F95EZ-0671 Emerson Blue Easy Reader Thermostat Logo
110 people viewed this question
Top whiterodgers Heating & Cooling Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
rdjagger
Are you a whiterodgers Heating and Cooling Expert? Answer questions, earn points and help others
