Question about Epson Stylus Photo 1400 Printer
Epson 1400 pizza wheel - Epson Stylus Photo 1400 Printer
Epson printer 1400, is printing vertical blue lines through my prints. How can I eliminate them?
If the lines are vertical to the direction of the printhead movement, you need to clean the paper rollers and the small "pizza wheels" of your printer. Also check for any traces of stuck paper in the paper path. I recon you ars not using genuine inks, right? Try to slow down your print speed by selecting a best quality setting.
If the lines are parallel to the printhead movement, your printhead is either clogged our stuck.
Jan 07, 2014 | Epson Stylus 1400 InkJet Photo Printer
What is a double wheeled pizza cutter?
a double wheel pizza cutter is a pizza cutter that has 2 wheels - one behind the other. The advantage of the two wheels is that they go through the pizza in one motion and you don't have to go back and forth to get a clean cut through the pizza.
Feb 28, 2013 | Home
Epson R1800 pizza wheels
Did you mean the star wheels?. Why??
Feb 17, 2013 | Epson Stylus Photo R1800 InkJet Printer
What is the difference between a pizza wheel cutter and a pizza rotating knife?
A pizza wheel cutter is a metal wheel that rotates through the pizza so you can cut it even when it's hot. A pizza rocking knife is a thick metal blade with handles that you can use to rock backwards and forwards through the pizza to cut it.
Jan 10, 2013 | Home
Why does my epson 1400 keep loading paper straight threw instead of printing?
I have had this problem several times. The culprit is the feed wheel which can get covered with paper dust and it loses it "bite". Epson sells cleaning sheets that are tacky and when run through the printer remove this "dust". I have also resorted to taking a piece of scotch tape and carefully sticking it to the rubber take-up wheel and then gently removing it to pull the paper dust off with the sticky tape. Another problem can be because of not setting the paper type correctly. Check to make sure that the paper type set for the printer is the same as the paper you are feeding.
Nov 09, 2011 | Epson Stylus 1400 InkJet Photo Printer
Epson photo 1400 ink & paper lights keep flashing after I print. Then I have to shut printer off and re-start.
I read another epson thread somewhere and it said this:
"All you need to do is run the printer a few times with no paper. While it's "printing", use a soft cloth (I used a monitor cleaning cloth) and your index finger to clean the rubber wheel that pulls the paper through. The wheel is on the right side in the area where you feed the paper.
After hours of struggling with this tonight, it is now working perfectly. Guess I'm going to have to invest in a stash of monitor cloths..."
Hope it helps...
Sep 16, 2011 | Epson Stylus Photo 1400 Printer
Why does my epson stylus 1400 leave streaks in the print?
The tracking wheels (spiked wheels) can pick up ink and lay it back down. They can also accumulate debris that collect ink and put it down in the form of streaks. This is especially true if you use dusty or moist papers (or frosting sheets).
Oct 11, 2009 | Epson Stylus 1400 InkJet Photo Printer
Epson Stylus Photo 1400 Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
