Question about Soleus Heating & Cooling
My mica pannel electric heater was working fine until today i tried to turn it on and it wont come on. is there a fuse or something that can b reset?
  • 499 Answers
Typically the thermal safety or fusible link opens up, the switches usually outlast the limits, It is typically not an economically viable alternative to repair them if not done DIY.
Posted on Oct 19, 2013
Ac problem
jump the low or high pressure switchs this switchs are located on the a/c lines of tje compresor not run check power to the compresor if you have power maybe the compressor is gone check the a/c control pannel to and take a second opinion before expend money
Aug 04, 2012 | 2006 Kia Sedona
Optimus H-4338 The warning light came on and now the heater will
there's no reset, but unscrew the 3 screws in the back. Cut out white sleeve that covers the red & white wires. Take the fuse out from beginning to end. Attach the white & red wires directly. The fuse is not needed. Wrap w/ electrical tape. You, me and everyone that has bought this heater had the same problem. I called customer support. This is what they told me.
Dec 09, 2009 | Optimus H-4436 Electric Heater
Display screen wont turn on. Breaker was not tripped. cant ge them the screen to turn back on. irst time the problem came up. They havebeen working great until today.
Do the oven work at all, if it does not you will need to turn the breaker off and back on, it may need to be reset, it will appear fine but it will indeed need to be reset.
Nov 14, 2009 | GE JKP27 Electric Double Oven
Dryer won't dry
Without a meter there is not much you can do but a couple things to try , 1st turn the breaker off , when turning it back on push the breaker switch firmly in toward the panel then check for heat . the breaker may be running only half power and not supplying the heater [bad breaker] , the next thing is the temp. fuse on the heating element case. take the ;arge back panel off of the unit , you should see the element case on the right , it should have 4-6 red wires going to it , the fuse is located at the top of the case , remove the 2 red wires from it and slide them together then use electrical tape to tape them carefully power unit back up and test for heat , if it is working now you most likely have an exhaust problem , check the airflow where unit exhaust. let me know if you have any other questions.
Phil
Apr 11, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore Elite HE3 front load dryer no power
Yes. Remove the kickplate and check the continuity of the thermal fuse located on the blower housing.
Feb 23, 2009 | Kenmore Dryers
Furnance will not come on
No Blink? no call for heat. Check thermostat. Jump out thermostat. Check the fuse in the cabinet as well as in the breaker box. Do you have an emergency switch that may have been turned off? Make sure the door interlock switch is closed and working.
Jan 29, 2009 | Goodman GMS90703BXA Heater
All pro 200t
It may be a reset switch on the heater. Usually located near where the electric supply goes into the unit.
Jan 10, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Microwave stopping working
check the fuse on the microwave. if its busted, something shorted out in the oven that tripps off your breaker. it could be your inverter.
Feb 19, 2008 | Microwave Ovens
Heating & Cooling Logo
187 people viewed this question
Top Soleus Heating & Cooling Experts
Coss
Dennis Boxerman
Harjeet Singh
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
