Question about Garden
Why does my Briggs and stratten 6.5 mower is spitting what looks like gas with a little oil., looks to be coming from hose above the carb......Is it shot ?
  • 7,482 Answers
Hi bowmunster
Sounds like you have dirt/debris in your carburetor jets, fuel passages or a diaphragm that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a lacquer thinner type cleaner to clean and dissolve the lacquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the lacquer thinner because it can dissolve the plastic parts and render them unusable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.
The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Bud
Posted on Oct 20, 2013
4 Suggested Answers
  • 211 Answers
SOURCE: my lawn mower will not turn off
Hi
From under the flyweel comes a wire(probably black).check it.It is connected with the off position of the trotle.
best regards savumihai71
Posted on Dec 22, 2008
  • 166 Answers
SOURCE: Briggs & Stratton Quattro lawn mower
A lot of time when the small motors on these push mowers surge it is a governing spring that is weak or broke. It does not hold enough tension and causes the valve to fluctuate. I have fixed this many time for a relatively cheap amount (under $5).
Posted on Jun 16, 2009
rycgl
  • 1545 Answers
SOURCE: I need a free copy
Workshop (repair) manuals are available for ALL of the Briggs and Stratton engines. They usually cost money though. The free downloads are only for the owner's manuals. You can do a search for Briggs engine repair manuals. There are many, many of them available.
Posted on May 22, 2011
I have oil/gas combo coming out of the valve cover on my 17.5 hp briggs/stratton riding mower. what should i look for?
check for gas in yuor oil if does replace needle and seat in carb then chang oil filter if it has one make sure to clean bowl well on carb let me know what happen
Sep 03, 2014 | Garden
I have a huskee lt4200, engine is a 420cc OHV.
Check for gas contamination in the oil....if the oil itself it gas free....its likely a blown headgasket.
Aug 05, 2013 | Briggs & Stratton Garden
Briggs & Stratton Vertical OHV Engine 18 hp blowing white smoke engine run great but a lot of smoke and also have oil being spit out of the black hose that come from engine to the carb.
Check your oil.
If it is overfilled, milky, or smells like gas. Your going to need to change that ASAP. It sounds like the float has stuck in the past or is still sticking, and it has flooded the crankcase with gas, which has mixed with the oil. And because it is overfilled it comes through the breather hose into the carb. This also explains the smoke most probably because the oil is spewing in the carb through the breather and being burned.
Jul 05, 2011 | Briggs & Stratton Briggs Stratton Intek V...
How much oil to put in a 6.25 briggs and stratten
They hold APPROXIMATELY 20 ounces. Put in around 18 oz and start checking the dipstick and adding a little until it gets to the full or MAX or whatever it says on your particular engines stick. Each time you ad a little, give it a chance to drain down or you will get a false reading
Sep 20, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Gas coming out of exhaust is it the carburetor and why
carb. float stuck open
Need to remove carb. replace float needle valve and possibly the needle valve seat,
change your oil also
saturated with fuel
May 23, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Weird under load symptom briggs 17.5
a couple other checks would be to dump the carb resevoir where the float is, water under the float could be accumulated and closing the fuel off, due to density. out here on the farm we never use the gas to the last drop from the can. also the linkage between the motor fan blade, (govenor) might have been connected to the carb incorrectly. or a bad switch interlock on the mower blade.
some briggs motors are hooked wrong straight from the factory, where the throttle linkage is concerned. ( and the little spring is pretty hokey too)
May 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
