Question about Cycling
How do you replace the wick in "The Giant" table lighter made by Galter?
  • Delete this
    Delete this Oct 19, 2013
    ? Not sure how cigarette lighter gets classified as Bicycle?
I have a ZIPPO and it wont light.How can I fix it?
Does the flint-wheel go around? Is the spark healthy? is the lighter filled with avgas? That should be all you need to know.
If there's a problem, Zippo lighters have a life-time warranty.
Feb 15, 2015 | Cars & Trucks
Replaced the flint, filled with ronsonol lighter fluid. I do get a sparkfrom the flint to the wick. But it does not light. Tried a match to light wick, it lights and burns. Back to the flink spark, no...
How high is the wick? It can be adjusted by pulling from either direction. Try soaking the cotton til you can see the fluid fill the compartment, or til it drips out the wick. Be sure the fluid has evaporated and the lighter is dry, before you try to re-light it.
Jan 08, 2014 | Cars & Trucks
I have a small propane reddy heater with an electric ignitor if power is out can i manually light it
Yes, you can. Use either a butane grill lighter or a long stick match. Make sure the control knob is in the "light" position and the wick is in the right position. Light the long stick match or butane grill lighter, press the control knob in and while holding it in, touch the flame of the match or butane grill lighter to the wick and the wick should ignite. Once it ignites, quickly remove the match without knocking the tip off into the heater.
Jan 31, 2011 | Reddy Heater-40,000 BTU Kerosene w/T'stat
Fixing a dunhill lighter with a small leak, can I pack this or do I need to take this in to a shop? many thanks, Jayson
I have a Dunhill Rollalite petro lighter and the wick is barely protruding out of the nipple / port. Everything thing I've read states to use tweezers to extend it but how is it done when there's nothing to crab? Are the wick replaceable and if so how is it done port how to extend it? Thanks
Feb 08, 2010 | Dunhill Facet DQV911AL Wrist Watch
Dyno-Glo RMC-95-C7 kerosene heater. replaced wick
once the tank gets low(on E) put the heater outside and let the remaining fuel burn completely out. This will burn off the residue build up on the wick and make it easier to turn off manually. do this often. i also use an old toothbrush to "fluff up" the wick. if the residue is too hard for the toothbrush bristles, flip the toothbrush over and break up the residue with the back side of the toothbrush. once all (or nearly all) of the residue has burned off you may see some smoke when you ignite the wick again. also, it may smell for a bit. I always light and shut off the heater outdoors. I mounted a dolly (table withe 4 wheels) under the heater to make transporting it easier. hope this helps!
Jan 02, 2010 | Dyna-Glo Heating & Cooling
Fixing Rowenta lighter
Pull apart in 2 parts...
Apr 06, 2009 | Sport & Outdoor - Others
Kreisler Lighter Repair
Found out through Colibri Lighter Co,that Kreislers' are no longer made & that there is no one to repair lighter I have
Mar 10, 2008 | Audio Players & Recorders
Electric starter
I have a different make and model, but many of these use a similar design. A battery pack (2 x D or C cell) is mounted on the kerosine tank. The batteries are used to heat a coil. The coil is pressed by an external button against the heater wick. Pressing the button also engages the switch, heating the coil until it glows red hot.
1. Open the burner chamber of the unit and confirm it has a wick installed (this is a used heater--who knows it's condition). Close the chamber.
2. Make sure the tip-over protection hasn't retracted the wick. Generally the tip-over protection is reset by a lever on the base of the burner.
3. Adjust the wick all the way up. A knob on the base of the burner does this.
4. Fully depress the electric starter until the coil touches the wick.
5. When the kerosine on the wick ignites, release the starter and adjust the wick to the desired level.
If the electric start coil does not glow, check the batteries. If the batteries are good, the starter coil may be bad. These are also
replaceable.
Nov 08, 2007 | Corona 23-DK Compact Heater
Cycling Logo
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
